big problem
By fresh · May 02, 2007in Problems/Troubleshooting💬 33 posts👁️ 6,393 views
Page 2 of 2
Posted May 04, 2007 · 16:47 UTC#26
i guess. what are my options for gettin it sent out for repair? contact pioneer? i woner how much that will cost...
Posted May 04, 2007 · 20:05 UTC#27
thing is shouldn't i get the hardrive error message? i checked the hardive with a computer and it was detected and looked working? i wonder fi theres a fuse or bios reset inside the z1?
Posted May 04, 2007 · 20:21 UTC#28
Are you connecting this HDD to a laptop directly? Is it possible that your laptop gave it its password?
Posted May 04, 2007 · 20:35 UTC#29
i connected the hard drive to a PC. using this connector.
Posted May 04, 2007 · 20:41 UTC#30
Did you make certain that the black wire on the power wire lined up with th "B" on the connector?
Posted May 04, 2007 · 20:47 UTC#31
on some of those connectors the power wire can be removed and put on reversed, so they put a letter "B" on it to show proper connection + /-.
Posted May 04, 2007 · 21:13 UTC#32
If the problem is only with your HD, then you might consider buying and automotive grade drive and copy someone's iso image onto it. Might be cheaper/easier than Pioneer.
Posted May 04, 2007 · 22:52 UTC#33
i dont know if its the hard drive for sure though. the harddrive seems to be fine, since it was recognized by my computer. and it was readable...... why am i noty gettin the error message when i start the screen??
Page 2 of 2
