well if the sun is hitting the screen then it gets to hot to run the screen. Also it could be a wiring issue a lose wire will cause it too.... I had that happen... but for the most part I keep my sun shade over it and it stays cool and works everytime...
Z1 Freezes on start up
Honestly, I'm getting quite pissed off! Why should we find a workaround for a system that supposed to work? This is ridiculous!!! Wouldn't you guys agree?
Anyhow, now I'm also beginning to doubt that this is due to hot weather. Yesterday morning I was going to get some gas (temp is 75 at most). I left my car on the ACC to listen to the music while watching my money leaving my bank account penny by penny... When I finished pumping, I started my car and system never came up.
A few weeks prior to that, I went back to my installer and they double checked every connection and it all checked out.
My system is completely unbypassed (other than the grounded E-Brake) and it does not have the latest CDDB update. System was manufactured in March of 2007.
dimaj
I;m kinda concerned that 2007 unit would do this. Figured the older ones would since they were working out some bugs perhaps.
Keep us updated!
I've hadn't had that freeze issue yet.
dimaj
That is the exact scenerio that I was talking about. It doesn't like to get booted off of such a short power cycle. At least those are my findings so far. Now that I found the issue for me, it hasn't been an issue as far as locking up. But I still get the song jumping to the next track while in library mode on some songs.
I'm having the same "freeze up" issue with my Z2.
Freezes on the Pioneer blue screen and the "Pioneer starting car navigation" black screen.
Mostly happens later in the day.
I wonder............. if the power was supplied to the HU from a ignition switched relay, that way it's power isn't interupted while the harddrive is trying to start up or if it's just heat related. ![]()
bdmpastx, but I couldn't boot it up after that as well. I did many many many 1st level resets and still no luck. turned off my car for couple of mins and still no luck...
dimaj
I have a little request...
Next time your system freezes, could you run HDD diagnostics?
Just go to the Service Screen and on the second screen there are some HDD tests... do a read test.
when my system didn't start up, HDD temperature was 43 - 44 degrees and it failed on some address...
dimaj
hey guys,
sorry to hear about your z1 freezing up at start-up. it happened to mine, got fustrated, finally sent in to pioneer for service. sent it in couple days ago and won't know til next week. by the way, my z1's warranty expires next month. well, i hope they fix mine for good and know what's the problem behind it. i can't wait to get it back and keep you all posted.
I got my system back yesterday afternoon and so far so good. It got replaced by the installer. Those guys probably hate me by now...
Anyway, I'm going to run a few more checks (park it on the sun for a few hours, etc) and will let you know about the results.
dimaj
I had the same problem with 2 Z1s and had them both swapped under warranty. Now I am stuck with a Z2 as a replacement. When I called Pioneer tech they said that this didn't seen to be a big problem because they have not heard much about it. I knew they were full of it.
so the bottom line was they couldn't fix your z1 and had them replace with a z2. i think they knew what the problem was but won't disclose the information. i think it's a recall product.
my z1 should be done sometime this week. can't wait to find out what's their resolution.
I have to disagree, this issue was on my Z2. If it was a recall product, they would have to recall most of the Z2s as well.
Today I parked my car under sun with closed windows and it was close to 90 degrees outside. When I got back to my car, Z2 loaded fine, but I wasn't able to enjoy it b/c it was tooooooo hot ![]()
dimaj
i got my z1 back from pioneer today. i have not yet install. this is what they wrote in the service comment: NTF, RESET UNIT. i called pioneer to find out what does it mean. he said my z1 is no-trouble-found (NTF), only a reset is done. all my mp3s are gone. they tried to duplicate the problem and didn't find any.
he also mentioned to connect my z1 to a regulated power supply and try a different ground source.
well, i'll let you guys know when i get it installed soon.
I'm sorry, but this is BS!
Who did you buy your unit from? Can you still exchange it with them? Or maybe buy extra warrnty through them and then exchange it immediately?
I'm really dissapointed with Pioneer!!! I will NOT recommend ANY Pioneer products to ANYONE!
There's a problem with units and they are not willing to work with their clients on a solution instead they take an easy route - NTF shit! I understand that they are trying to protect their assets, but still they have to at least try to work it out!
dimaj
BS is right. i have a feeling that i'll be sending it back to pioneer on a same problem.
Well, I live in Houston and I got my first freeze today when I left work. Same story as everyone else. It was hot today, started the car and got the Pioneer screen.
I pulled over and turned the car off and restarted...nothing but Pioneer screen. I hit the reset button...same thing. I then held the reset button down for 10 seconds and the unit started working again, but the GPS thought I was still at work.
I got to my kids day care, shut the car off and restarted and everything was fine...including GPS location.
I'll start using a sunshade and hope this doesn't happen again.
That should definately "cure" the problem, but why do you have to use a sunshade to make a $2,000 system work?????????? That just pisses me off!
When you send it back, tell them to put it in a hot room for a few hours while it is off. I'm pretty sure that they are NOT going to install it into a car, but by leaving it in the car under hot sun (with sun shining DIRECTLY at the unit) should prove them wrong (hopefully)
dimaj
Yeah, it irks me as well, especially living in the South where its generally warm year-round. However, there is no consumer right in this country. I can say this definitively after having been one of the original owners of an Omnifi (google it if you don't know the story). That thing sucked and was released by Rockford so that the retail consumer could beta test it. If this is the only real issue I have for two to three years and keeping it out of direct sunlight fixes the problem I'll be satisfied.
I guess you're right... I'm just hoping that whatever I buy will work as advertised, but me being in the software development world, I know that's not practical... ![]()
However what I find even more bizzar is that people have been complaining about this issue (both Z1 and Z2), sending it back to Pioneer for repairs and Pioneer would not hear them out and try to investigate deeper to make sure this won't happen again! All they do is just send it back with comments "not reproduced". I guess what's bothering me the most is that usually when a company releases a faulty product and somebody complains about it, they do the best the can to make sure that client is happy. From what I've been reading here, people are getting units they sent out with words "not reproduced"...
dimaj
I am having the same boot screen problem with my Z1. I live in Arizona and a couple weeks ago it started for the first time. Now it's happening more often as the heat is increasing here.
I park my car in the garage at home so when I leave for work in the morning it has never frozen up yet, but when I park in the parking garage at work, when I leave for lunch, or when I leave for home at night it happens frequently now.
I also did the CDDB update discs, but like I said, I haven't noticed any problems at all until summer started here. It seems like it's definitely related to the heat, but who knows.
It's installed in a 06 VW GTI, so the American car ventilation theory doesn't apply to me.
I have submitted a support ticket to Pioneer asking for any resolution. I'll update if I hear anything back, but from listening to all of you, it doesn't sound promising.
I don't remember anything like this happening last summer.
Also, does anyone know if that is just a standard 2.5 inch Hard Drive that's in that slot behind the faceplate?
JT
Behind the faceplate there's a Toshiba mobile hard drive. It is the same as a laptop (2.5") but it can withhold much higher vibrations and temperatures.
I have read someplace here on the forums that Pioneer works only with Toshiba drives...
dimaj
Toshiba 4032 GAX. $44.95 at Chief Value online. This HDD is 40GB and 5400RPMs ![]()
I live in the southwest with daily temperatures >100 degrees F and have had no start-up problems with the unit "freeze up" using this HDD
search it on this forum and get some more info.
For those who are having Freeze Startup issue,
I was curious if there is any correlation with how much HDD space is used.
Can those with the freezup issue chime in on terms of how much % is taken up my music files?
I have 95% space free (only 5% used). So I'm wondering if the more songs I put, the more suceptible i am to system freeze.
Thanks.
I'm at about 70% free space. I believe there are some on here that have done a complete refresh and they still have problems. I think the problem is heat related no matter how much disk space is taken up.
Because there is an internal temp monitor, does anyone know if the software automatically shuts down the HD at a certain temp?
I don't think that HDD gets shut down... But I think that it starts to mis-read and throws a lot of reading errors. As a result, OS can't finish boot-up process and freezes at the point where it was left.
As far as a HDD usage, I had about 20 albums when I first started to experience these problems. Then with a lot of pain in my heart I did a complete reset (removed all my addresses, music library and phone book) and still had some issues.
dimaj
