A little more 4032GAX info for Mazdaspeed
I chose this particular HDD because it is a Toshiba and because it is widely used in the portable DATA storage units that you would connect to USB ports. That tells me that the movement / vibration and environmental issues may have little effect on it's performance.
below are the Tech. Specs.
HenryJ
General
Device Type: Hard drive - internal
Width: 7 cm
Depth: 10 cm
Height: 9.5 mm
Weight: 0.1 kg
Compatibility: PC
Hard drive
Form Factor: 2.5" x 1/8H
Capacity: 40 GB
Interface Type: ATA-100
Connector: 44 PIN IDC
Buffer Size: 8 MB
Performance
Drive Transfer Rate: 100 MBps (external) / 55.7 MBps (internal)
Seek Time: 12 ms (average) / 22 ms (max)
Track-to-Track Seek Time: 2 ms
Spindle Speed: 5400 rpm
Reliability
MTBF: 300,000 hour(s)
Non-Recoverable Errors: 1 per 10^13
Seek Errors: 1 per 10^6
Manufacturer's product description
Toshiba's line of hard disk drives delivers the right product to meet the needs of the portable PC and non PC market. Built with the performance and reliability characteristics that have made the company a world-renowned leader in the hard drive industry, Toshiba's line of hard disk drives supports fast data transfer rates and seek times while delivering the right product for both PC and non PC markets.
Expansion / connectivity
Interfaces: 1 x ATA-100 - 44 PIN IDC
Compatible Bays: 1 x internal - 2.5" x 1/8H
Environmental parameters
Sound Emission: 28 dB
Min Operating Temperature: 5 °C
Max Operating Temperature: 55 °C
Vibration Tolerance: 1 g @ 5-500 Hz (operating) / 5 g @ 15-500 Hz (non-operating)
Sound Emission: 25 dB
HenryJ
