Posted Nov 01, 2007 · 15:44 UTC#26
Torx bit is a T8.
Hey thanks, I must have every other size torx bit. but that one.nyskinsfan said:Torx bit is a T8.
Passat 05 said:'Had the same problem removing the screws that hold the HDD to the mounting plate that others have reported.
Here is a quick way to overcome:
Grind a slot into the screw head with a dremel tool and immediately, while the screw is still hot, use a good fit flat screwdiver and the succer will come out without effort. :) :idea:
Add to FAQ at the top of this thread. :?:
zeeker78 said:So, if i follow your method i will be saving the $42 to unlocked the hard drive right?
What i mean is, if i buy a new hard drive i don't have to pay the license to unlocked the new hard drive, right?
Thank you
Zeek
tsiawd666 said:Thought I'd add what I learned about the process as I have only seen the methods I've mentioned a couple times and not listed in the main faq page.
I used the 80gb Toshiba Drive as Newegg was out of 60gb and sent the 80gb instead. To unlock the drive I took out the drive from Dell Latitude D810 laptop and put it in, and used the Magic ISO 2.0 bootable cd with MHDD. Using MHDD I disabled the security features. Once this was accomplished, I used a usb 2.0 2.5" hd enclosure to connect to my desktop pc (which had the z2bypassed iso) and used Acronis True Image to restore the drive. I disabled the copyright overlays by renaming the files, and placed a few additional bitmaps on the drive. So far everything is working fine.
I tried to use up the free space for the Music MSV partition but didn't have luck using Acronis Disk Director. When I try to resize or expand it won't let me increase the size past the image's 9gb initial sizing. I tried some trickery with swapping locations with the last one so that the MSV partition was adjacent to the drive's free space, and then increasing it, which worked in Acronis, but the AVIC-Z1 of mine wouldn't read the hd. I simply restore the image again and just left the partition sizing alone to verify everything else was working, which it did.
The key things I wanted to stress since I don't see them mentioned enough are:
-Used laptop with bootable Magic ISO + MHDD CD to permanently unlock my HD
-Used USB 2.0 HD adaptor to restore the z2bypassed image
chrisb009 said:I have noticed NewEgg quit carrying the 60 GB drives mentioned. What drives are being used that work well and do not exhibit the dreaded reboot issue? BTW I am looking at the Toshiba MK8032GAX 80GB 5400 RPM 8MB Cache ATA-6 on the NewEgg site.
gmschiller said:Crap, crap, crap. I know better! Anyway, I got impatient and got sick of waiting until I could go buy a new drive. I decided to take the plung and unlock the stock drive. I didn't need the data, so I went ahead and used the wizard.
The unlock wizard seemed to work flawlessly. Everything was fine and it said it was successful after it was done. I downloaded the magicboot v.2 and tried to disable the security. I can't get it to "see" the drive! So, I boot all the way back up... still can't see the drive! So, I pop it in my USB adapter (Sh!ts and giggles) still no partitions, but I can see it in the device manager. :evil:
What gives? Anyone else run into this. I have tried it on 3 diferent computers varying in age and motherboard chip sets. I'm in the sa diego area close to Miramar. Anyone close enough and want to take a look? Just wondering. I think I might try usiung the CD rom Magic boot this evening. Maybe the USB floppy drive I have doesn't work with this procedure. :?:
CaptainInsaneO said:
Hey, I live in Carlsbad, fairly/somewhat close to you.
Anyways, your problem COULD be that your drive doesn't have a drive letter. Try right clicking My Computer, and click Manage. Then go to the Disk Management snap-in, and find your drive in there (if it shows up in Device Manager, it'll show up here). Assign a drive letter to the drive. You should be able to see/access the drive in My Computer now.
If you need more help, PM me.
