AVIC-Z2 Pre/Post-June Bypass Files
By Hyperite · Jul 22, 2007in Hacks/Mods💬 951 posts👁️ 310,660 views
Page 17 of 39
Posted Sep 05, 2007 · 21:26 UTC#401
I'll take my car back in and have the installer redo the bypass.. and sorry about the type o ... I'm not really big on doing spell checks!!!
Thanks again
Something you might want to try. Hit the little recessed reset button to the right of Eject. And then drive around again and see if the unit is bypassed. If the parking brake message pops back up again, then the bypass was not performed correctly. If it stays away, then you just needed to get rid of that message.
This is a long shot, cause most likely (from experience seeing what has happened here) the bypass was probably not done correctly. But if it wasn't, and then the message popped up and then they fixed the bypass, that message will come up every time you start the car till you reset it, it's the only way to get rid of that message.
Posted Sep 05, 2007 · 22:49 UTC#402
First and foremost thanks to all who figured this out.
My installer said this coulden't be done and a friend of mine found this forum and sent it to me.
I was hesitent on putting software in my new Z2 but I had to do it.
Did it this sun. with the 2 wire bypass and worked 1st time.
I have a question, Is there a way I can get rid of the "driving while watching a dvd bla bla bla" message??
Posted Sep 05, 2007 · 23:28 UTC#403
At this time, we don't have a way to remove the nag screens. :(
Posted Sep 06, 2007 · 00:05 UTC#404
I updated my Z2 with the dowload. It ran fine but now will only load the start screen. It will not do anything else. I am fucked. Any suggestions? A hard reset? :evil::evil::evil::evil::evil:
Posted Sep 06, 2007 · 01:03 UTC#405
Sure, does pressing the reset button do anything? Do any of the buttons work?
Posted Sep 06, 2007 · 14:57 UTC#406
This also happen to me over the labor day weekend. I drove from NYC to NC (8 hours). The next day my Z2 would just stop at the Pioneer Splash screen and freeze. If you insert a cd it would play. I pressed reset a couple of times and it would just freeze at the pioneer screen. Once I turned the truck off and let it sit for a while than start it back up, the Z2 would come on working. Has anyone seen this b4. Help would be greatly appreciated. Thanks
Prior to this weekend it has been working fine. I did the bypass about a month ago.
Posted Sep 06, 2007 · 18:43 UTC#407
well the only thing i can think of is that ur getting the heat lock out. my system does that too. i havnt yet done the bypass myself, but my system will freeze on the splash screen when it gets really hot outside. ws it really hot where u were at??? its possible that when u were done driving the car was left in a really hot place and the system wouldnt boot up because of the heat. this happens to me all the time when it gets really hot inside the car, and my system isnt bypassed. i was told to run the ac in the car for a while till it cools off and then restart the system and that shoul fix it.
Posted Sep 07, 2007 · 00:07 UTC#408
thanks all for figuring out the bypass.. I stop in today and found out that my install has only installed my z2 and no others.. and also I found out that he only did a 1 wire bypass just the ground from the parking brake.. not the second so this weekend I'm going to have him set up the second wire bypass and hopefully it will fix my problem.. once again thanks all for the help.. and great job for figuring the little bugger out!!
Posted Sep 07, 2007 · 05:40 UTC#409
I am attempting to bypass my z-2. I have downloaded the needed files and burned them onto a cd, I am now ready to "2 wire bypass" but I need a little clarification. Method 2 states that it will only work with z-2's, again I have followed all the steps for this method (1-4) but when I follow the posted link the 2 wire bypass instruction state that these instructions are for z1 units. Never, in the entire article, does it state that these instructions can be used for a z2. Am I just looking too far into this or can this wire bypass only be used for z1's. Do I need to do the 2 wire bypass to complete the process or is that only for the z1's? Sorry about the repetitiveness here but like a lot of novices out there who bought the Z-2 thinking that the local stereo guy would be able to bypass the unit, it would be well worth any trouble out there to get my z2 bypassed. I just want to enjoy the simple things in life like letting my girlfriend watch here "Charmed" Season DVD's while driving down the coast of sunny Southern California.
Posted Sep 07, 2007 · 07:15 UTC#410
It works for the Z2 also, just follow those instructions
Posted Sep 09, 2007 · 04:10 UTC#411
I'm going to call Pioneer and see what they are willing to do about my unit freezing at the startup screen. This only happens every so often.
Posted Sep 09, 2007 · 04:44 UTC#412
Help. Can someone tell me who can do a good install in a C5 in New Mexico.
Posted Sep 09, 2007 · 23:55 UTC#413
I just completed Method 2 and it worked like a charm.
Big thanks!!!
Posted Sep 10, 2007 · 13:07 UTC#414
I had to have my entire system removed (Viper 5900, AVIC, AMPs etc). 1st shop did a bad install had electrical issues. Had reinstall done by a shop with a great rep and also pioneer dealer.
Install is great, except I am getting the parking break error. I did do the reset, while parked. No affect on the error. I also do not have full functionality of the system while driving. Note:I did while on the previous(bad) install. I'm guessing the wiring of the parking break was not done right. I plan to copy the instructions down and have them verify/check their work in that area.
Anything else I should look for? (BTW, HD still shows the upgrade occurred)
Posted Sep 10, 2007 · 14:26 UTC#415
If you reset the Z2 with the little recessed button to the right of Eject...and if you are still getting the parking brake error, there is a problem with wire #2. The parking brake sense wire (light green) is fine. Check connector 2, that wire that you relocated and grounded is not grounded or not installed into the connector correctly. That's what causes the parking brake error to pop back up. And eventually, within 100 miles or so, you will start to get that error and it will lock you out while moving. So you will want to fix that.
Posted Sep 10, 2007 · 16:28 UTC#416
ok I be sending my unit out tomorrow to Pioneer for service b/c its freezing at the startup screen. Is their anything that I should do b4 i send it to them, remeber i did the bypass. If they see the bypass files do you think they will void the warranty? I think they are going to replace my hard drive
Posted Sep 10, 2007 · 19:13 UTC#417
also if these guys replace my hard drive, I take it that I will have to reinstall the bypass files, correct?
Posted Sep 10, 2007 · 23:17 UTC#418
Generally when they replaced the hard drives, they loaded the latest software (on installed a hard drive with the latest software) if you wanted it or not. So if they keep doing what they did in the past, chances are good that your new unit (if they replaced the drive) would have the update already. But there is no guarantee.
Posted Sep 12, 2007 · 12:17 UTC#419
WOW Thanks alot...I originally had a Eclipse AVN-5435 and have had that for well a few years now.....volume control was messing up so I decided it was time for a new unit...have a buddy that has a shop but the thing is he is on the other side of town and if anyone knows how Houston is they would understand...Well he told me he knew how to bypass the Z2 so I decided I would purchase one..got to thinkin of it and just googled Bypass for Z2 which lead me to this site...wasnt for sure how hard this was goning to be but man was it easy..worked first try (had to hit the retry button about 10 times at 35% to take finally) but I dont get the parking brake warning and all my functions are fully available for use..Thanks really appreciate this...One question I was trying to dl new background images on the unit and the upload from cd wont pop up to be clicked...the pictures I downloaded were JPG. I put in a seperate folder called pictures and then I did a dummy folder with .xls, .pdf, .word, and even some main folders...did the disk not read because of these main folders that I threw in there to take up the 100mb needed? or did I do something else wrong?
Frank
Posted Sep 12, 2007 · 13:54 UTC#420
WOW Thanks alot...I dont get the parking brake warning and all my functions are fully available for use..Thanks really appreciate this...
Well, you are very welcome alot! :)
Frank
It sounds like the files you put on the disk were ok, but what did you use to make the disk. You can't use windows built in burning program. You need nero or some other 3rd party software. They say in the instructions not to use the built in windows software and you post had lots of stuff but not what you used to burn.
Posted Sep 12, 2007 · 13:58 UTC#421
Sorry Roxio is what I used.
Posted Sep 12, 2007 · 18:11 UTC#422
Then I would make sure there are not any extended characters in the names. Make sure they are 8+3 file format. And tell roxio (I don't use it so I don't know how, but I think it can do it) to use ISO 9660 format and mode 1 and things like that. Get down to the most absolute compatible cd format. It should work if you have the jpgs in the PICTURES directory (or whatever the manual says they should be in).
Posted Sep 12, 2007 · 19:18 UTC#423
For what it's worth, used Roxio, slowed down the right speed and it worked fine. I did put pictures in the Picture folder. Both the backgrounds and upgrade CD worked fine in my system after burning with Roxio (Vista 64Bit PC).
Only non default was slowing to 4x speed. Recommendation on 8.3 naming format is a good one. Remember, not to use spaces in any names or labels.
Posted Sep 12, 2007 · 19:37 UTC#424
hmmmm alright I will try those things if not I'll just use my laptop at the house and use the program I use to burn there (i forget the name right now) but my Bypass CD worked just fine. Thanks again.
Posted Sep 13, 2007 · 05:11 UTC#425
I am currently trying the 2 wire bypass. I snaked the "mute" wire that was not being used from connector 1. I am going to install that wire in the noted connector 2 spot (bottom right corner) but this wire needs to be ground and I can't find anywhere to ground it. I was wondering if I could "piggyback" it onto another wire that is already being grounded. And if I can which wire that comes out of either connectors, 1 or 2, or my power supply is the one that is being grounded? Is there a specific color? In looking at my wires I see that the "ACC" wire is already being "piggybacked". Is this the wire that connects to the accessories or is this a ground wire? I am guessing that the ground wire is black but I was wondering if somebody could possible lend a friend a hand or a hint. Anything would help. Other my next choice is to ground it to a metal strap that held the old stereo in place. I have a 2006 Taheo Z71 if anybody knows what I'm talking about. And if you don't think that's a good idea I am VERY open to suggestions. AGAIN, ANYTHING would help but the correct way to do this would be best. Thanks a guys!!!!
Page 17 of 39
