hi. need some hard drive help!
By oilersrule · Aug 06, 2007in General💬 3 posts👁️ 571 views
Posted Aug 06, 2007 · 17:41 UTC#1
hi guys! im new here and i was wondering, is it possible to upgrade the drive in the Z1 from the stock 30gb ??
the drive already in the unit is a MK3029GACE and i assume the MK4036GACE replaces it, but i want something larger. those 2 drives are for "automotive" purposes Toshiba said, but i see no others with similar model numbers for larger drives. can i simply use ANY larger sized drive as long as its a Toshiba 2.5" ??
Posted Aug 06, 2007 · 18:13 UTC#3
Hmmm.. thanks for the links
seems that no matter how large a drive you put in there, there is only a limit (1000cd's) of what you can put. Then again 1000 cds are a lot, so wouldnt that take a lot more space? Anyone ever try a 80 or 100gb drive?
