XessReality said:
Ok guys i know i'm new here and you guys are definatly way beyond me on hardware tech, but i have been browsing through some of the exe's and i found more than a few referances to usb support.... not just the os, but a hardware adress ???possibly??? that is the point where i start to get over my head.
Also, maybe someone w/navtraffic can confirm that the data connector that is only used for the traffic updates and data portion of xm looks a whole lot like it could be a usb interface in some sort of obscure connector. Side note to that thought, if memory serves me correctly the special plug for bluetooth was labled bluetooth on the back panel or instructions, while the data cable for xm was refered to in the manual in a more generic way...no spacific referance to xm...
maybe nothing, maybe something
The search for USB is why I took the whole thing apart. I too think if they have USB it will be inside one of the connectors.
If you look at the lines of code you found with USB in the pathname you might notice that some of these reference files I think we are using. This also leads me to believe that some of the flash memory is seen as a usb drive or all the flash is referenced as USB and it is set to boot from USB.
You will also find references in the exe files to HTTP addresses and where items get downloaded for updates. From this I think the code can or has lived outside the Z1 as I don't believe they wanted to build web access in it.
