AVIC Z1/Z2/Z3 Upgrade to AVIC Z3 w/2009 Maps
By AFMagnum · Aug 20, 2007in Hacks/Mods💬 535 posts👁️ 186,645 views
Page 2 of 22
Posted Aug 22, 2007 · 14:50 UTC#26
Ill pay some one $100-$150.00 to do this for me.
Any Takers?????
I can help. PM me
Posted Aug 22, 2007 · 15:48 UTC#27
I can recommend do net restore whole z2 image, but first two partitions into your old z1 drive. This will allow you to keep all your music and user settings.
Posted Aug 22, 2007 · 16:15 UTC#28
Is this possible? I am thinking that the Z2 image contains special attributes in these 2 partitions that are different from the Z1. Can anyone confirm this?
Posted Aug 22, 2007 · 17:58 UTC#29
Music & user data is universally stored between the Z1 and Z2. You can restore just the map and application partitions.
Posted Aug 23, 2007 · 15:12 UTC#30
Also, can someone elaborate on the changes with this update? There is only a brief, vague description in the first post of this thread.
I edited the original post to include a link to Pioneer's CNDV-700HD Upgrade Manual that has complete details as to what changed between the Z1 and Z2:
http://www.service.pioneer-eur.com/pees ... 0HD-EN.pdf
Posted Aug 23, 2007 · 20:05 UTC#31
but be warned... 99% of people who are upgrading the HDD are expierencing a REBOOTING issue. so look into that before making a decision!!
Which rebooting issue is this? I just had my Z1 repaired (new HD) due to the unit rebooting over and over on startup. No mods.
Posted Aug 23, 2007 · 21:01 UTC#32
just do a search and you'll see... People who are upgrading to drives with a faster RPM's and some with larger storage are experiencing a LOT of reboots from every 3 minutes to hours! Just do some research before upgrading your HDD.
Posted Aug 27, 2007 · 04:17 UTC#33
If I only have a laptop computer is it still possible to do step 3?
I know prolly a bonehead question
Posted Aug 27, 2007 · 07:29 UTC#34
SUCCESS! Thanks AFMagnum!!!!! Now IF we can just figure out how to put your own mp3s on it rather thantaking forever to rip..
Posted Aug 27, 2007 · 10:13 UTC#35
I want to thank you so much for posting this info on upgrading the z1. I think the $ 250.00 pioneer is charging is a bit high. I would think they would keep the price reasonable for the owners of the z1 units since they are costly to begin with. I am a computer repair technician and computer builder. After I upload the new data to my Z1 HD...I am going to purchase several more exact replacement hd's. Then I will set up these hd's and swap them to anyone that wants to do a simple and quick upgrade to their Z1 and a reasonable price. If anyone is interested...I will post more info later.........(if this works), I need to test it out completly first, so we won;t have any problems. Has anyone tried this yet? Does anyone have any suggestions for this.
later
mike
Posted Aug 27, 2007 · 17:02 UTC#36
I'm in the same position as you and only have a laptop. This won't work on drives connected via USB or Firewire. I had to use a friends desktop in order to do the upgrade.
The security software will not be able to see the drive unless it is connected directly to the motherboard.
Posted Aug 27, 2007 · 20:46 UTC#37
Quick question on this. OK, so here's what I am getting out of this. I have a pre-Jun 06 Z1, so the DB mod comes out and the 2-wire method goes in. I got all the instructions for making the new drive. I will of COURSE make a backup of the Z1 drive. Has anyone had any problems with the upgrade and reverted back to the Z1 image with any success? I'm tring to gauge the reversability of this upgrade. Also, if I am having the "freeze on bootup screen" issue, associated with high heat (I live in NE Florida where a typical summer day sees 90+ degrees), will a new hard drive of the same size and speed fix anything, or is it in another piece of hardware?
BTW... Thank you very much DucatiBoy for the couple of years of excellant lockout override. I was one of your first customers and by far your happiest!
Posted Aug 27, 2007 · 23:14 UTC#38
I have done this. Maybe I have the wrong version of Acronis or whatever, but I made backups with my version of Acronis and Ghost. Then when I reimaged the drive, the new image didn't work for me. So I'm thinking it was my old version of acronis, but I did successfully reload my Z1 image back (a couple times) and it always worked. Don't take my failure loading the Z2 image as much, I didn't have the same version of the program and I didn't really try too hard to get it to work (just no time) but I always could bring it back with my backup image (I think cause I made the backup Z1 image and restored it with the same program, the Z2 image here is made with a newer version of Acronis and maybe something in that is why it didn't load for me).
This I can't help with. I haven't followed this.
You are very welcome, glad I could help when I could. It kept me rather busy for quite some time. :)
Posted Sep 02, 2007 · 00:35 UTC#39
Hope this is the right place to post this question.
My computer only supports SATA. I guess IDE is becoming a thing of the past for new computers.
What recommendations does anyone have on what adapters to purchase?
I'm also wondering how I should connect the hard drive to the motherboard, since SATA does not use slave and master on the same cable.
Thanks for your help!!
Posted Sep 02, 2007 · 02:02 UTC#40
PATA and SATA are completely different
You would probably need to
a) find another computer that is older and supports PATA
B) possibly buy a PATA controller card, install it in your new computer. I honestly don't know how well this would work, but it just might...
Good luck.
Posted Sep 02, 2007 · 02:04 UTC#41
I would think that if I were in this situation... I would get one of these:
http://www.newegg.com/Product/Product.a ... 6815280002
I have so much IDE stuff from my Tivos and Replays and xbox, etc... I know SATA is taking over, but I need to keep around ATA things.
Posted Sep 02, 2007 · 22:40 UTC#42
Dumb question:
If these instructions are followed to upgrade z1-to-z2, does the image already include the 2-wire-bypass over-ride files or do we still have to use the 30mb image from the other sticky to update the z2 to be "bypassable?"
Recommend editing the original thread to mention whether torrent/ftp images are already "bypass-ready."
Posted Sep 03, 2007 · 01:55 UTC#43
Dumb question:
The files themselves are called Z2Bypassed...
Posted Sep 03, 2007 · 02:22 UTC#44
Dumb question:
LOL, thanks, didn't catch that.
Posted Sep 03, 2007 · 13:54 UTC#45
FYI, for anyone thats familiar with newsgroups I've attached NZB's for the image to this post.
*edit* my apologies. my original submission, avic.zip, was missing some of the files. Their are now two attachments to this post. If you downloaded avic.zip, you can download "missing.rar." Its an nzb containing the missing files.
If you need the entire download, grab avicZ2image.rar.
Missing.rar
AvicZ2Image.rar
Posted Sep 04, 2007 · 21:28 UTC#46
Getting ready to process your Z1-Z2 upgrade step by step instructions but have a question about the TIB file size. I've uncompressed the 9 files 4 times already to make sure but my file size does not equal the 9.4GB you mention in your writeup.
In File Explorer w/ Details as my view choice the following is shown:
Z2Bypassed.tib 9.278,202 KB TIB File 7/31/2007 9:30PM
When I right mouse click properties on the uncompressed Z2Bypassed.tib file I show:
Size: 8.84 GB (9,500,878,848 bytes)
Size on Disk: 8.84 GB (9,500,880,896 bytes)
WinRAR shows (for any of the 9 files selected):
Z2Bypassed.part01.rar - RAR volume (number 1), unpacked size 9,500,878,848 bytes
BTW the first 8 files are noted to be 1,048,576,000 in size while the final 9th file is 686,857,644 in size. I believe these are correct from reading the various postings of these uploaded files.
Am I missing something? Never got any error messages or issues and all 4 times uncompressed the same. Not sure if I should proceed until hearing from you on this dilemma.
Finally, thank you for taking the time to write up these instructions and to all that created and uploaded the bypass files. You guys are great and very much appreciated.
Posted Sep 04, 2007 · 21:40 UTC#47
Well did Mike ever successfully do the Z1 - Z2 upgrade and deside to cell Hard Drives with the disk already setup?
I think that would be the only way for me...other then a KEY generator.
Duke
PS. Anyone working on either of the above? That would have a lower level of risk for the rest of us "average Joes".
Posted Sep 04, 2007 · 21:43 UTC#48
If I process this successfully I might consider the HDD prepared in advance sell. I'll wait to hear about my postings first, give it a try and post the results for the interested parties on AVIC411.com
Posted Sep 04, 2007 · 22:17 UTC#49
I am at work right now so I don't have access to my uncompressed image at home...
Still I ran QuickPar using the .PAR files included with the Z2 Update file. If it comes back 100% perfect, then you got it. I would strongly recommend you run the check against the .RAR files before you uncompress and use that file.
Posted Sep 05, 2007 · 00:36 UTC#50
Thanks I did as you suggested. In WinRAR there is a "Test archive files" under the Command menu. All tested 100% perfect, so I can safely assume that the master Z2BypassFile is good to go :)
Once again, thank you much!
Page 2 of 22
