AVIC Z1/Z2/Z3 Upgrade to AVIC Z3 w/2009 Maps
By AFMagnum · Aug 20, 2007in Hacks/Mods💬 535 posts👁️ 186,645 views
Page 4 of 22
Posted Sep 11, 2007 · 05:25 UTC#76
Not sure if it to late for you, Nim.....
try this to make a boot cd
http://www.ultimatebootcd.com
It worked for me :)
not sure about you other problem...sounds like you might be on the right track
Posted Sep 11, 2007 · 11:54 UTC#77
Thanks to everyone in this tread I have completed the Z1-Z2 upgrade using my original hard drive.
I was able to keep my music by not overwriting the last 2 partitions.
I have not notice any enhancements, other than map, by upgrading.
Did I only do a map upgrade any kept it a Z1 by keeping music? Or is there no real difference?
To my disappointment the maps in my are are worse than before. Can you safely switch back to the Z1 image if you want to?
thanks again
Posted Sep 11, 2007 · 12:46 UTC#78
Newvet, hopefully u were able to edit the parameters of the Z1 HDD to permanently keep the drive unlocked, and more importantly, hopefully you made yourself a backup of the Z1 before recovering the Z2 image.
If so, you can reconnect the HDD back to your computer and use Acronis to recover the backup you created onto the Z1 HDD.
If you did not permanently unlock your HDD, you will have to repurchase a license for Repair Station from AFF Laboratory.
If you did not create a backup, you will have to get a hold of the original Z1 image.
Navyute,
I will keep that in mind for the future, thank you. Hopefully I won't have to edit the HDD until next year for the 2008 maps. In that case, I will repurchase the unlocking license and keep it unlocked then. Thanks.
Posted Sep 12, 2007 · 02:47 UTC#79
So say I purchased a new Toshiba 60 GB drive and connected it to my PC to upload the Z2 image onto it. What steps do I need to follow? I'm guessing I really only need to unlock the drive permanetly and put the image onto the new drive. Is this correct?
Posted Sep 12, 2007 · 03:27 UTC#80
The only step you do not need to follow is unlocking your HDD. You just have to remove the security settings on it. So do all steps, except step 4, in the beginning of this thread to your new HDD.
You shouldn't have to spend a dime on anything other than hardware ..... The new HDD and the adapter to connect it to your computer.
Posted Sep 12, 2007 · 03:34 UTC#81
The main difference is whenever the instructions say "AVIC Z1 Hard Drive" you will use your Toshiba 60 GB drive instead. Also, as navyute said, you do not need to do step number 4. On top of that, you can skip step 6 as well.
If you are using a new drive, you don't need to backup your old drive since you'll still have the original intact.
Posted Sep 12, 2007 · 03:42 UTC#82
AFMagnum,
I've never given you thanks for taking time to provide us with great instructions on how to upgrade. I followed them just as you wrote them and all worked as published.
THANK YOU! :D
Posted Sep 12, 2007 · 05:07 UTC#83
...The bypass however does not work as I am locked out of almost all menu items.
I have completed the original parking-brake -> ground for the Z1 which worked like a charm and I prepared for this upgrade 2 days ago by moving the MUTE wire to the bottom right pin of Connector #2 and grounding it...
Update: So I spent some time taking apart the Avic and organized all the wires neatly. I took the MUTE wire off of a bolt that was supposed to be grounded and spliced it with the proper ground wire. So thats now a secure, permanent ground. However, as I was organizing the wires, I followed the parking brake wire from the Avic and when I reached to the end of it, it was not connected to anything, nor was it ever.
I did not know the parking brake did not need to be grounded to complete the first generation Z1 bypass. So I grounded this to the same ground wire as the MUTE wire and the Z2 was bypassed successfully.
Thanks again to AFMagnum and ducatiboy and everyone else who contributed to make this possible! :)
Posted Sep 12, 2007 · 16:05 UTC#84
AFMagnum,
THANK YOU! :D
No problem. I'm just glad everyone is able to complete the upgrade!
Posted Sep 12, 2007 · 17:21 UTC#85
Maybe I misread this somewhere, but I thought I still had to flick the lights on/off on startup in conjuction with the 2-wire bypass AND the bypass software.
What a relief to no longer need to flick the lights on every startup!
Posted Sep 12, 2007 · 18:33 UTC#86
Posted Sep 12, 2007 · 18:34 UTC#87
Posted Sep 12, 2007 · 20:45 UTC#88
Ok,
Hopefully this will be the last question. I have the Z1 and it's not yet installed. I will do the Z1 to Z2 update via a new drive. However, I will do it AFTER the install to make sure everything works when installed. I want to do the 2 wire bypass also.
Here is what I plan to do, please correct me if I'm wrong.
1. Install the Z1
2. Do the 2-wire Bypass
3. Put the Z2 image on my new hard drive using the sticky http://www.avic411.com/forum/viewtopic.php?t=9446
4. Install the Hard Drive & turn on Z1.
Since the files to create the Z2 image are already bypassed I shouldn't need to anything else.
Hopefully after that I should have a working bypassed Z2
IS THIS CORRECT?
Posted Sep 12, 2007 · 21:44 UTC#90
cgcmgr, you don't need to post that twice in the same section.
http://avic411.com/forum/viewtopic.php?t=10014
My bad. I knew I posted, but couldn't find where the post went. Sorry, for that, but thanks for the help!
Posted Sep 15, 2007 · 20:39 UTC#91
I can recommend do net restore whole z2 image, but first two partitions into your old z1 drive. This will allow you to keep all your music and user settings.
Is this possible? I am thinking that the Z2 image contains special attributes in these 2 partitions that are different from the Z1. Can anyone confirm this?
Has anyone tried to restore only the first 2 partitions? Any success on keeping your music while upgrading to the Z2 image?
Posted Sep 16, 2007 · 03:36 UTC#92
Yes, you can just resore the first 2 partitions and save your music, address book, etc.
-G
Posted Sep 16, 2007 · 04:42 UTC#93
Thank you everyone for all your help!!!
NEED HELP ONE LAST TIME!!!
After I converted from z1 to z2 i can still use the XM NAV Traffic but it only shows traffic reports on all freeways for about 20 min. and then it goes away. This happen to me everywhere i go.
PS
The XM Radio works fine and i have strong signal pretty much everywhere but the NAV Traffic only works for about 20 min.
ANYONE???
Posted Sep 16, 2007 · 18:58 UTC#94
The FTP and Torrent sites appear to be down. Any one have a link to another place to obtain these files?
Posted Sep 16, 2007 · 23:41 UTC#95
One more question. I see four partitions. I know I am only going to restore the first two to avoid erasing my music. Do I need to restore the "MBR and track 0"?
Posted Sep 17, 2007 · 22:35 UTC#96
I am not sure if you "have to" restore the boot and MBR, but it definately works if you do, and it only takes about 1 second.
-G
Posted Sep 18, 2007 · 12:14 UTC#97
-G
I went ahead and restored the first 2 partitions and DID NOT restore the MBR. Everything seems to work fine and I kept all of my music and settings. Looks like either way will work.
Posted Sep 18, 2007 · 15:57 UTC#98
PS
ANYONE???
I have also noticed my xm nav traffic icon vanish from time to time after the Z1 to Z2 upgrade. I Don't know why. Never happened on the Z1 software.
Posted Sep 18, 2007 · 16:14 UTC#99
Thanks Dtomcat.... I wish there was real people in Southern California, but unless I'm friends with Stephen Spielberg or I'm invited to a party with Angelina Jolie, no one in SoCal will help me for the simple offer of drinks- which I would gladly pay anytime.
I appreciate your Florida hospitality.
Mark
did you get someone to help you? i'm in San Diego, i would do it for you if you just send me a drive... you can PM me if you like
Posted Sep 21, 2007 · 03:04 UTC#100
Any from or near El Paso, Texas? I decided to buy one that was already upgraded, but I am going to try one with a 120gig, just to see if it works. BTW I am new to the forum, but have seen your post for a while. I would like to thank all the posters, for their info. I hope I can contribute. I'll let you all (Y'ALL) if the 120gig hdd works.
Page 4 of 22
