AVIC Z1/Z2/Z3 Upgrade to AVIC Z3 w/2009 Maps
By AFMagnum · Aug 20, 2007in Hacks/Mods💬 535 posts👁️ 186,645 views
Page 6 of 22
Posted Oct 13, 2007 · 00:27 UTC#126
To clarify, I just want to put the Z2 image on a blank hard drive without migrating any Z1 data...
Posted Oct 13, 2007 · 00:43 UTC#127
Sure that's fine.
Posted Oct 13, 2007 · 00:54 UTC#128
Does this image contain pre-defined partitions?
Do I still need to connect the hard drive as a master to the secondary IDE channel to restore the image?
Posted Oct 13, 2007 · 01:10 UTC#129
Yes, the image contains the predefined partitions and MBR.
No, you can connect your drive to ANY port to restore it even USB , BUT be carefull to eject the drive before removing it because the write back cache may be full.
File size reported inside WinRAR:
Packed: 9,075,464,753
Size of each file on my computer:
Z2Bypassed.part01.rar - 1,024,000 KB
Z2Bypassed.part02.rar - 1,024,000 KB
Z2Bypassed.part03.rar - 1,024,000 KB
Z2Bypassed.part04.rar - 1,024,000 KB
Z2Bypassed.part05.rar - 1,024,000 KB
Z2Bypassed.part06.rar - 1,024,000 KB
Z2Bypassed.part07.rar - 1,024,000 KB
Z2Bypassed.part08.rar - 1,024,000 KB
Z2Bypassed.part09.rar - 670,760 KB
If your file sizes do not match this amount guess what? they stopped short of dowloading the whole file and you either need to resume the Download or restart it.
I am going to test this image on the stock drive then i will install it on a 80gb toshiba mentioned in this thread.
Posted Oct 13, 2007 · 02:43 UTC#130
Ok, Cool....thank you.
I'll be putting this onto a 160GB seagate drive....is there a way to increase the music storage partition using this image?
Also, I assume no one has tried to do this with a hard drive over 80GB?
Posted Oct 13, 2007 · 17:21 UTC#131
Success! Z2 image restored to a Z1 factory drive.
One thing to note though:
When restoring the Z2 image to your Z1 drive:
First, restore the entire Z2 image first.
Second, go back to your Z1 Image and restore your last two partitions to retain your music and system settings.
You could also restore the Z2 MBR, and Partitions 1 and 2 seperatly to accomplish the same thing. but i was not successful when trying that procedure.
I would gladly put this Z2 image on a supplied drive for anyone, I have a valid image, thanks to BigFloppy
If you are in Southern California, and need an image put onto a drive PM me I would be happy to do so for you.
Thanks to everyone who contributed to this thread and all the info i gained by READING the WHOLE thread. I dont think anyone can emphasize how important it is to read the entire thread before asking a question, because most questions are answered. :P
Posted Oct 14, 2007 · 01:29 UTC#132
No dice on te 160....I got an error stating it couldn't use the Hard drive. My guess is that the internal firmware of the device has a max limit to what size hard drive it supports...probably limited around 120GB since Geko483 was able to get an 80GB to work...
Since this is windows automotive, probably limitation like windows XP....
Posted Oct 14, 2007 · 14:48 UTC#133
I have only used the original drive, I have not yet recieved my 80gb yet but ill be putting that image on there when it does arrive. Others have succeded in putting this image on a 60gb and 80gb Toshiba drives.
I am trying to customize the buttons and other things but it looks like they are embedded :(
Has anyone done the Firmware upgrade in addition to this software upgrade??
Posted Oct 21, 2007 · 01:33 UTC#134
Just did the install on a new 40GB toshiba MK4032GAX. Been driving around town for a couple hours and it's been working great. No hiccups and no freezes. Got it off ebay for 34.99 plus 9.99 shipping.
Posted Oct 21, 2007 · 17:20 UTC#135
Success i have put the FTP image onto a 80gb Toshiba drive and then added all my other albums and settings info.
Now all i want to do is expand the partition size to allow more content.
WHat programs are you all using to expand the partition size that have been SUCCESSFUL?
Posted Oct 23, 2007 · 16:05 UTC#136
is there a way to upgrade the z2 software without using the original hd ?
I want to get a new hd and load the z2 image on from the ftp site provided, what are the steps involved to do this if i am not going to use the z1 hd ? or is this not doo able without unlocking the hd and a making a image of the original ? thanks.
Posted Oct 23, 2007 · 16:41 UTC#137
i have the 60gb toshiba drive and im trying to find out how to expand the partition, does anyone know? :(
Posted Oct 23, 2007 · 23:34 UTC#138
I just finished doing my Z2 upgrade. I took the toshiba 60gb hdd, turned off security by putting it in my laptop, and then restored the z2 image onto the drive thru a external harddrive case. I didnt have a desktop to make everything easier. I then did the 2 wire bypass, and everything is working great. Thanks to everyone here. :D
Posted Oct 26, 2007 · 03:58 UTC#139
OK, you guys are the shiznit! I went out and purchased a new drive, then downloaded the images from AFMagnum's post, and slapped the drive in the Z1 (now Z2) and XM came on as soon as I turned the key and provided power, the two updates ran and I am up and running! Although I had one of the original bypass circuits installed I am missing some menu commands, that is tomorrow's project (2 wire bypass). I used a 60GB Toshiba drive and left all the partitions from the z1-z2 bypass image the same, so no extra space increase (no biggie, had something like 95% free on the 30GB drive). A quick question though, when I go to the settings then hardware settings I am showing that it is now version 2.000, do I need to run that firmware update that Pioneer put out? Thanks again, you guys are the HEAT!
dc
Posted Oct 28, 2007 · 07:37 UTC#140
Thanks for the help. I am finding the Norton partition disc. I think this program able to expand the music storage. Someone please correct me.
Posted Oct 28, 2007 · 08:44 UTC#141
Hey folks, I just wanted to thank everyone here, I did the upgrade put the image on a Toshiba 40 Hard drive... Everything is working Great no problem at all... Thanks Again.. Kurtis :D
Posted Oct 29, 2007 · 00:41 UTC#142
Has anyone been collecting UnitSerial Numbers, activation codes, and whatnot... if we had 4 or 5 of them we could almost certainly work out a SN generator
Posted Oct 29, 2007 · 15:21 UTC#143
My experience with Z1 to Z2 Upgrade;
1) My Z1 was professionally installed. I took it in to get the latest bypass done, right after I installed the latest bypass upgrade software. This install is so well done, you can't even get to the rear of the unit to access any wires. They did the 2-wire for free (actually a couple of pizza's). I wanted to verify that this functioned before moving on to the Z1-Z2 upgrade.
2) .RAR download was fine using XP Pro. I did interrupt my downloads several times with no problems when restarting the downloads – no corruptions.
3) I downloaded all the software. but for some reason I had to "purchase" Acronis Disk Director, which I find a great piece of software and worth it. I could not get it to work as i needed on the trial version.
4) I chose the upgrade route on the Hard drive and ordered from NewEgg the Toshiba MK6034GAX - 60GB, which means I did not unlock my old drive.
5) I purchased the IDE hard drive adapter from Fry's Chain for $6.99.
6) I did everything as described. All went well with the following exception.
> I could not get the screws loose on my Z1HD Caddy. truly funny... I do major auto repair, and have rarely encountered this kind of difficulty. I used my dremel to cut them out. and replace them with new screws. The down side is that the cut-off screws remain in the original HD. hope I never need to reinstall that one.
> I could not tell when I had defeated the password locking on the new HD. This has been mentioned on this thread. I tested it on another computer to verify.
7) I installed new HD. and everything was fine. BUT here is were I veer away from some of the guys here,
8) I was also surprised to see many of my settings intact - my av settings, xm stations in memory, map settings, even my Bluetooth connection, etc... I did not reset anything because all appeared to work. This reset is recommended by others here.
9) to this day (2500 miles after upgrade) it is flawless. I must add that my system has been flawless from day one. My Avic is one of the very early models - I live for tech, so i got it early 2006.
10) I used Photo shop to create a simple splash screen using a Volvo logo, Volvo photo and text " Volvo Navigation Loading.....". I like the factory look and did not want a splash that said " look at my aftermarket system". It is important to look "factory" IMO
11) I removed the pioneer disclaimer files (renamed the files .old but left them in place). So now only my Splash screen shows up.
12) I have no restart issues, I have never performed a "hard reset" or any other reset.
13) The new Hard drive is noticeably quicker. Of note - the "beep" after the Z2 asks for verbal input is instantaneous - I used to have to wait one to two seconds to get the beep..... niceeee !!!
14) "DOWNSIDE"..... I need to reinstall all of my music and phone book entries because I did not unlock my original hard drive and retrieve it.
finally, 15) can someone do a step by step on resizing the hard drive partitions...... this was not clear to me. and I ended up with several extra partitions and had to do everything over to get back to square one. People have tendencies to say " just do A and end up with Z" when they have a clear understanding (I too am guilty), but others may not see it as clearly.
ALSO, please watch for a new thread (if one doesnt exist) in the general section regarding the AVIC obvious omissions and oversights - you know - the things this system should or shouldn’t do.... that are painfully obvious to us users. I am going to pull some of these together and post them. Pioneer are U listening.
Posted Oct 29, 2007 · 16:47 UTC#144
First post, so please bear with me if I plant this in the wrong place...
"gparted" is an open-source program that you'll burn to a cd, then you can resize your partitions without wiping anything out. Yeah, ya still gotta have the 2.5 to 3.5 cable, and DISCONNECT ALL YOUR HD's in your pc before running DBAN!!! Leave only the new hd connected. Both programs (gparted & DBAN) will self-boot in order to lobotomize & resize your 2.5". I put my replacement drive in place of my XP drive in my laptop if I don't have access to a pc. NO OS needed to run the programs so far...you can use a 98SE bootdisk after running DBAN, although out of over a dozen laptop overhauls I haven't needed a bootdisk.
"DBAN" (Darik's Boot And Nuke) will totally wipe out EVERYthing on a drive, including data in "sector 0" (where the hd reads its lock code from. After running DBAN, load your d/l'ed z2 image into it.
Google for the 2 prog's above, enjoy...
...just my 2 cents worth.
Posted Nov 01, 2007 · 02:58 UTC#145
:!: hey I am willing to pay for a updated hd for a z1. I will suppy the hd if you would tell me what kind I am in jax fla. would like to use either a 80 or 120 gig hd I will pay via paypalI think I kcan pay about 75.00 plus the hd or name a reasonable price. would like a large partition for all the music. I would attempt to do this but my job requires me to do a lot of road trips in country and abroad. Please help :lol:
Posted Nov 01, 2007 · 03:01 UTC#146
btw here is my email [email protected] 8)
Posted Nov 05, 2007 · 20:02 UTC#147
Hey there,
I am dumping the Z2Bypassed.tib Acronis image onto a new TOSHIBA 60GB HD, but I wanted to make sure I expand the right partition during the process as the "original" image is from a 30GB HD, and mine will be 60GB.
Looking inside the Z2Bypassed image with Acronis, I see 4 partitions as follows:
[ 17.52 GB FAT32 ] [ 572.8 MB FAT32 ] [ 9.308 GB FAT32 ] [ 572.8 MB FAT32 ]
If I a not mistaken, the 9.308 GB partition ( 3rd one in the image ) is the one that takes the music and should be expanded to take up the almost 30GB difference from the stock HD to the 60GB replacement, correct?
EDIT: Update! - YES the 9.308 GB partition is the one that needs to be expanded! - Worked a charm!
Posted Nov 05, 2007 · 20:43 UTC#148
Any of you guys who have successfully done this in the Boston area? I would gladly pay someone for their time and expertise so i don't screw it up!
Posted Nov 09, 2007 · 03:18 UTC#149
which files are these?
Posted Nov 09, 2007 · 20:42 UTC#150
Anyone in the mid atlantic area (i am in maryland) who can expand ther gb. on my Z1, upload backrounds, firmware, and any other updates to my unit. I will gladly come to you, and pay for your services. I am not good with computers, so me attempting these things is out of the question. Thanks.
Page 6 of 22
