AVIC Z1/Z2/Z3 Upgrade to AVIC Z3 w/2009 Maps
By AFMagnum · Aug 20, 2007in Hacks/Mods💬 535 posts👁️ 186,645 views
Page 8 of 22
Posted Dec 07, 2007 · 16:07 UTC#176
Okay maybe i missed something i have a couple of days off from worka nd i was going to attempt this. I ran into two problems if anyone can help. First I went out and purchased and ide adapter but when i went to put it in my computer it wouldn't plug in. Apparently the adapter i have is a 30 pin and the cable from the pc is 29 pin even on the motherboard is 29 pin. Secondly i don't see a diagram on the hard drivve that shows which place to put the jumper. I tried to take the metal plate off but the screws started to strip and i didn't wanna mess them up anymore. Thankx.
Huh? If I remember right, the 2.5" hdd has 43 pins and the IDE cable has 39 pin holes. The 2.5 to 3.5 adapter that you need matches both.
What jumper??
If you can't remove the screws, look at my post earlier in this thread on how to make it easy with a dremel tool .....or buy a replacement plate. :wink:
Posted Dec 10, 2007 · 20:37 UTC#177
Hey Guys,
I have all 9 .rar files downloaded. I then ran the win rar and now have an 8.8 GB .tib file as apposed to the 9.4 GB .tib file. My .rar files 1-8 are all 1,024,000 kb (.97 GB). The 9th file is 670,760 kb (655 mb).
What is wrong here?
Duke
Posted Dec 10, 2007 · 22:09 UTC#178
Try a different FTP client.
are you just clicking the links when you download it, or using FTP in Explorer? Maybe try FlashFXP...
See page 9 of this thread..
Yes, the image contains the predefined partitions and MBR.
No, you can connect your drive to ANY port to restore it even USB , BUT be carefull to eject the drive before removing it because the write back cache may be full.
File size reported inside WinRAR:
Packed: 9,075,464,753
Size of each file on my computer:
Z2Bypassed.part01.rar - 1,024,000 KB
Z2Bypassed.part02.rar - 1,024,000 KB
Z2Bypassed.part03.rar - 1,024,000 KB
Z2Bypassed.part04.rar - 1,024,000 KB
Z2Bypassed.part05.rar - 1,024,000 KB
Z2Bypassed.part06.rar - 1,024,000 KB
Z2Bypassed.part07.rar - 1,024,000 KB
Z2Bypassed.part08.rar - 1,024,000 KB
Z2Bypassed.part09.rar - 670,760 KB
If your file sizes do not match this amount guess what? they stopped short of dowloading the whole file and you either need to resume the Download or restart it.
I am going to test this image on the stock drive then i will install it on a 80gb toshiba mentioned in this thread.
Posted Dec 10, 2007 · 23:36 UTC#179
I just did a drag and drop. The rar files are identical to what was posted. My only difference is in the post un rar size.
I think I'll just try the image that way. I just have to disable security by loading drive with the boot disk and then download a free partition tool to open up the 3rd partition for more music storage.
I'm also going to check on changing the boot screen.
Posted Dec 11, 2007 · 04:28 UTC#180
That's exactly what I've got. The tib file is 9,278,202 KB.
It's working great.
I remember others reporting the smaller size also earlier in this thread. Not sure if it worked for them but would think that even if it works, something has to be missing. :?
Posted Dec 12, 2007 · 20:04 UTC#181
Thanks to all who answered my questions. I upgrade to a 40gb hard drive and everything seems to be working. After the upgrade I checked the hardware settings and I now have
V 02.0000 and CDDB 07-01-0010 is this the latest version? Thanks.
Posted Dec 18, 2007 · 14:42 UTC#182
Is no one hosting the Z2 image any longer? I need help finding it, bc I'm now ready to do the update and new HDD...thanks to all of the people who made this possible thru trial and error....this upgrade now looks to be feasible for the avg joe.
Posted Dec 19, 2007 · 20:49 UTC#183
Sorry guys, System took a dump yesterday, it's back online now though
PLEASE try and limit your connections into the server to 1 at a time, there are lots of people trying to get the files and the more bandwidth you use for yourself, means other people have problems getting files as well
Be courteous and everyone will get their fair share
IF I see multiple connections from the same IP address from now on, I'll ban that IP address
You've been warned!
Posted Dec 19, 2007 · 22:02 UTC#184
First off, I have to give much thanks to all of you who have contributed.
I'm not too proficient with computers, but I'm no dunce by any means. My strong point is with car audio, so I was kind of caught off guard with the whole upgrade process since the majority is done with a computer.
I bought a 40GB Toshiba hard drive off eBay since Newegg only has the SATA drives, I believe. I bought the 2.5" to 3.5" IDE adapter off compusa.
I followed the instructions and everything was fairly straightforward. I did, however, run into a few problems when I connected my hard drive to my motherboard.
I wasn't aware that I had to initialize and format it in disk management first. After removing the security features, I started up windows and freaked out when my computer didn't list the drive. I saw that Windows found new hardware, but was confused when it didn't show up in My Computer. I chalked it up as to having a garbage computer, so I ordered an external case. It was $12 from newegg. You can get cheaper ones, but this one was pretty decent. When that arrived, I tried hooking it up to my USB port and still had the same problem. Windows found the mass-storage device, but didn't display it in My Computer. Anyway, after a little research, I found out how to initialize and format it. I thought I would run into problems because I formatted it as NTFS, but it didn't seem to make a difference.
I know most of you already know this, but I assume that there are some that don't (like me). For those of you having the same problem here's what to do:
go to Start --> Run --> and type in "compmgmt.msc" (be sure to exclude the quotation marks)
Under "Storage" go to "Disk Management"
Scroll down and find the new drive. Right click and select "Initialize" then right click and "Format"
BE CAREFUL WHEN DOING THIS BECAUSE YOU MAY ACCIDENTALLY FORMAT THE WRONG DRIVE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
After it was done formatting, I used Acronis True Image to restore the .tib file onto the new HDD. It was straightforward and fairly simple. It took a little over 15 minutes I believe. If your replacement HDD is more than 30GB, you can resize the music partition. I used Acronis Disk Director to resize the 9.08GB partition. Once again, very straightforward.
I removed the hard drive from the Z1, but had problems unscrewing the plate like many others. I tried a jewelry screwdriver, but there wasn't enough torque. I used a Cobalt 6-in-1 screwdriver and used the smallest Phillips head. Also, locating a T8 screwdriver was a pain. I just wanted the T8 head without having to buy the whole set.
I swapped the hard drives and powered up the car. It updated without a problem.
The unit is a lot quicker when using the keyboard for a POI search. I haven't had much time to fool with it, but it seems like it's working great.
Thanks everyone.
Posted Dec 19, 2007 · 22:04 UTC#185
Oh, if anyone needs help installing a Z1 in a Chevy HHR, let me know. The install shop did a terrible job putting mine in, so I had to redo everything.
Posted Dec 19, 2007 · 23:07 UTC#186
well, it's happened... multiple connections from same IP address, I kicked them off the server this time
YOU HAVE BEEN WARNED, there's enough bandwidth if people respect
1 connection per IP address
NEXT TIME IT WILL BE A TOTAL BAN
Posted Dec 20, 2007 · 03:34 UTC#187
Thanks BigFloppy,
I've finally got it downloaded. The first page said it is supposed to be 9.4gb after uncompress, but I only have 9.278gb after uncompressed. Am I missing something?
Thanks....
Posted Dec 20, 2007 · 03:37 UTC#188
Haven't done the upgrade myself yet, sorry
yeah, yeah, yeah... I'm a slacker I know
BUT at least the files are still available aren't they
Posted Dec 21, 2007 · 02:57 UTC#189
I'm thinking this uncompressed state has something to do with a version or the different computers. Something is not right.
I've downloaded it two separate times and both times all 9 zip files equal 8.45 GB and not 9.4. However, each file separately is identical to what was posted here as the "supposed to be" size.
I'm going to move forward and try it this way.
Duke
Posted Dec 28, 2007 · 23:03 UTC#190
WOW, this was soooo easy. I'd like to thank the folks who made this available.
Bought a new HD and 2.5" adapter. Connected on 2nd IDE as primary, used windows to format it. Use True Image to restore the downloaded image and from there it was plug and play... :mrgreen:
Rock on !
Oh ya... after unpacking the image was 8.8 gigs on my SUSE 10.3 Linux desktop.
Posted Dec 29, 2007 · 04:40 UTC#191
I'm planning to purchase an already upgraded drive from Ebay (like this one http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... Y.m238.lVI) but want to copy over my music and user data. So do I still need to follow all the steps to unlock my Z1 HDD and use Acronis to copy the last 2 partitions?
Posted Dec 29, 2007 · 05:20 UTC#192
Don't NEED acronis, but yeah, still need to unlock.
Posted Dec 29, 2007 · 06:25 UTC#193
This may sound stupid....so i just copy and paste?
Posted Dec 29, 2007 · 18:45 UTC#194
Yep! :D
Posted Dec 29, 2007 · 19:03 UTC#195
I just did the upgrade for my Z2. I took out the 30G and put in the new 80G.
I have noticed when I went into hardware info menu and saw 26% used space and the blue bar is all most to the end. I did not have anything on it yet. I have expanded the MSV to 55.5G. Is the Z2 having problem to recognize the bigger MSV partition?
Thanks...
Posted Dec 31, 2007 · 13:12 UTC#196
Think we're on for a record... 26 users downloading :shock:
You guys are killing my bandwidth
Posted Dec 31, 2007 · 17:46 UTC#197
People can use the news groups... much faster to dnload.
1) www.binsearch.info > advanced > query= 'avic' > max age of post: 200 > specifiy alt.binaries.test
2) search > create .nzb file, save to desktop.
3) Import your .nzb file to SuperNZB app to dnload the image. http://www.techsono.com/supernzb/index.html
4) You'll need to know your ISP news server address... typically news.your_isp.net or .com. You will also need to know you login ID PW, typically the same as your email handle and PW.
Note: This dnload is 224 files ~50 MB each totaling 10+ gigs... so dial-up is not a option.
Also note some ISPs will cap your dnload capability to ~2gig so you may want to verify this before starting.
Posted Dec 31, 2007 · 21:52 UTC#198
Sounds like a plan! Thanks wrxsti03 for posting how to get it from the newsgroups
Sorry guys, the FTP server has gone offline for a month (at midnight USA Eastern Time) while I pay thru the freakin nose to get me a logo created for my next great adventure
I did put a request up both here (has now been deleted due to lack of response) and on the FTP for help from the Graphics Guru's here... requesting help designing a logo for my new venture. Unfortunately, it landed on deaf ears... so I've gotta close the FTP for the leech account to help me pay for a "Graphics Guru" to ream me no end
Those of you with private logins into the server will still have full availability while the leech account is out of comission (to conserve bandwidth)
HAPY NEW YEAR TO ONE AND ALL
FYI: Stats for This month are:
#Logins 21092
Last Login 12/31/2007 11:54:37 PM
Last Known IP XXX.XXX.XXX.XXX
Files Downloaded 17926
KB Downloaded 3,045,697,088.26
Download Failed 9418
BigFloppy
Posted Jan 01, 2008 · 12:08 UTC#199
Could someone please either provide the .torrent files, or re-upload the .rar/par files to usenet?
Seeing as how BigFloppy no longer is making them available at the moment, having the .torrent files or having the full .rar/par files available in the newsgroups would be nice . . .
Thanks in advance!
Posted Jan 03, 2008 · 03:42 UTC#200
It is faster! Took me under 6 hours using http://www.giganews.com, the files might be there for another 30 days, other newsgroups already deleted the files.
Page 8 of 22
