Thanks to everyone for all the information that was posted on the site for the Z2 upgrade. Hopefully, I can help some of you who were trying to save some of the settings from your old Z1. This was important to me as I had close to 100 entries in my address book.
After searching the site I could not find any information on how to save address book settings, history, recent calls list, route information, route history, etc. So, for anyone who is interested, here’s what I did when I upgraded my Z1.
To make this work you should first follow AFmagnums instructions on how to do the upgrade. Be sure to save an image of your existing HDD before starting the upgrade. Once that is complete you can follow the steps below to restore all of your information. In my case I used a new 60G Toshiba HDD instead of the existing Z1 drive but this will work with your existing drive as well. Also, I used Norton Ghost to do all this but Acronis should work as well. So, here’s the steps…
1) During the upgrade you should have made an image of your original Z1 drive. This image will be used to restore your settings. You should re-install the HDD and let it go through the update process. When this is done all your address book settings will be removed.
2) Power down and remove the HDD. Install it in your PC.
3) Using the old image from the Z1 restore the MSV (music) partition and the User partition to the newly upgraded HDD (if you have already moved your music then no need to restore the MSV partition). That’s the last two partitions on the HDD. If you left them at their original size that’s the 9.308GB and the 572.8 MB partitions. In my case I increased the MSV to30GB and expanded the User partition using the remaining space on the HDD.
4) That’s it! Now re-install the HDD to the Z2 and you will see all your information restored. Note that the Z2 will actually update the address book to Z2 format. The original address book was in the Z1 format.
From what I can tell this is what is restored:
All your music (this was explained in an earlier post, I moved music and all the user info at the same time).
Custom Backgrounds
Bluetooth info, telephone call history
Log Files
Guide info
Language
Location
Stock info
Search info
Volume settings
Route info, route studies, trace history
Address book, memory, favorites, history, images
