An alternative for iPhone users
By Cathaldub · Jan 18, 2015in AppRadio, AppRadio 2, AppRadio 3💬 73 posts👁️ 29,131 views
Page 1 of 3
Posted Jan 18, 2015 · 16:13 UTC#1
Since extensions has been abandoned I'd considered two things.
1. Buy an android phone and use AppRadio Unchained, I actually did this and bought a HTC One M8 but I didn't like the Android system as a phone and decided to sell it and bought a iPhone 5S.
2. Upgrade my AppRadio 2 to an AppRadio 4, but with mixed reports on the unit/carplay, and the cost envolved.
I decided to try something else before I abandoned my AR2.
I bought a cheap Quad core android HDMI stick for €35 from Amazon. Installed the free version of AppRadio Unchained and paired it with the radio. It gets it's internet through personal hot spot on my iPhone.
I also paired my iPhone 5s with the radio as a special device so I can still make/receive calls through it.
I'll post a video later but it's great, I have all my apps installed on the hdmi stick, spotify, YouTube, Waze, Google maps, etc and I still have the ability to use my iPhone. Its actually easier than using the iPhone with the radio as all I have to do when I get in the car is turn on personal hot spot, I can then leave my phone in my pocket.
Edited Jan 19, 2015 by Cathaldub
Posted Jan 19, 2015 · 14:35 UTC#2
This sounds really interesting, could you also exsplain how you install the apps on the stick and a link to the stick you bought as i have just had a quick look and there are all sorts and prices so if i buy the same as you i know that one will be compaible with the unit
Posted Jan 19, 2015 · 19:58 UTC#3
I bought the MK809iii hdmi stick on Amazon for €35 inc postage.
The most difficult part is rooting the HDMI stick but I then found a program called Kingo which can pretty much root anything and it's simple to use. You just download the apps from the google play store.
95% of the apps I'd be using while driving are free anyway.
I do intend on installing the pay version of unchained as it includes gps injection so all apps can use the built in antenna for gps
Posted Jan 20, 2015 · 09:02 UTC#4
Cheers for that, I think I had better do a  bit more reseach as I can get buy on a PC but not brilliant and dont want to buy yet another thing for my unit that I dont use lol. I purchased the leads for my iphone 5S only to find it was very glychy so bought a second hand Iphone 4S which is jailbroken works far better
Posted Jan 20, 2015 · 10:39 UTC#5
Unchained on Android works far better then extensions or even pioneers software.
everything is much more smooth and responsive
Posted Jan 21, 2015 · 00:16 UTC#6
Hi Cathaldub,
So it is your secret weapon you were talking about. Interesting...
The cost of the dongle here in Canada is around $80, which is not so cheap, so I have to think  :idea: . Should I buy an AR4 and sell my old AR2 to compensate for a part of the trade over, or invest more $$ in the AR2 for a compromise...
One boring fact is that you have to enable the hotspot on the phone each time you want to use it. If there was a way to have an auto connect hotspot like what Apple introduced with iOS8 last summer, that would be nicer.
I have a few questions left in my mind...
What about playing music/podcast from your iPhone to the AR2? I bet you still need to connect the phone in the USB port.
How do you power the Android stick? Where did you find the USB port to power it?
I bet that most apps can be installed from the Google Play store, but you needed to root the device because the Unchained app requires it (based on a few reading on the web, it is not an "official supported app" on Android).
I hope you get some times to post your video eventually. That could be a good compromise...
Posted Jan 21, 2015 · 08:49 UTC#7
http://www.amazon.ca/MOGOI-MK809III-Quad-core-Rockchip-Accessory/dp/B00N9U50FI/ref=sr_1_11?ie=UTF8&qid=1421829556&sr=8-11&keywords=mk809
Yep, you've to root the device, takes about 5 minutes using an application called kingo. The app is installed through the play store though.
I used the USB that was on the radio cable for the iPod but you could power it straight off the Cig Lighter too. I do intend to install a small little USB battery pack behind the centre console which charges while the car is on, so it only needs to boot up when this battery dies. I drive the car every day so this battery should never really run out.
I would have bought the AR4 myself but think I'll wait a generation or 2 until the bugs are ironed out. I don't listen to any podcasts myself at the minute but podcast republic will let you listen to apple podcasts, I listen to most my music through Spotify and I also have an iPod in the car too which I can now use the iPod app again.
Edited Jan 21, 2015 by Cathaldub
Posted Jan 21, 2015 · 12:45 UTC#8
Cool nonetheless. Not sure it will help me appreciate my AR2 more than now. But there is a good investigation path there.
At one point in time, I was thinking about using a Raspberry Pi, but that would probably requires to much work...
Posted Jan 21, 2015 · 13:03 UTC#9
The pi is too slow and nothing written at present for it
Posted Jan 21, 2015 · 16:23 UTC#10
Have not thought about speed, but sure you're right that everything has to be done for it to make it useful.
That's why your solution is a good step in the right direction. It's just missing a few critical points. For instance, if there were a way to stream from an iPhone to it, that would be great.
How long does it takes to boot without a battery backup?
Posted Jan 21, 2015 · 16:25 UTC#11
I was also considering jumping ship from an ios to an android phone due to my buggy AR3 with ios8.  This may be a good alternative....
I noticed that there are various MK809iii hdmi sticks on Amazon.ca and other sites.  Should we be looking for any particular model to mate with AR3 & ARU-R?
Some mention "newest model" with android versions ranging from 4.1 to 4.4.2?
Also , if I intend to use my iphone 5 as the internet hotspot would I need any additional connectors?
I suspect that the MK809iii will sit on my glove box and connect to my AR3 Android usb and HDMI connections.  Will that power the the MK809iii?
I think I'm ready to give this a try - just want to ensure that I order the correct bits ;)
Thanks for sharing Cathaldub!
Posted Jan 21, 2015 · 16:34 UTC#12
ninja98r, you probably missed it but the link is in the post you quoted :-)
$60 Canadian, not too bad...
Posted Jan 21, 2015 · 16:48 UTC#13
90seconds until its ready and streaming a sing through spotify
Posted Jan 21, 2015 · 16:51 UTC#14
Thats' exactly what I am doing, any of the MK809iii model sticks will do, some of them have better wifi/bluetooth chips and can run alternative firmwares/roms, I think the one I have is the undesirable one as its the least supported one.
You can power the MK809 from the usb on the ipod cable on the AR2/3, the HDMI plugs straight into the radio with a standard hdmi cable
the only thing you might need which is not included is one of these, they are about $2-$5 on amazon
Posted Jan 21, 2015 · 16:55 UTC#15
Hi meall,
I did indeed check out that link but noticed that there are various android versions on the market.
The link Cathaldub provided was android 4.1 while others range up to android 4.4.2.
http://www.amazon.ca/RK3188-Android-Cortex-MK809-Bluetooth/dp/B00OL7N6QI/ref=sr_1_5?s=electronics&ie=UTF8&qid=1421856409&sr=1-5&keywords=MK809III
Posted Jan 21, 2015 · 17:52 UTC#16
Models with newer Android version may last longer in terms of supports, but it is worth paying more for features you may never need?
I also saw a few models at around $80-90 for which I cannot see a major difference for this usage...
Posted Jan 21, 2015 · 21:51 UTC#17
Just found this, coming in 2015:
http://www.mugibox.com/en/
That could be a great option too to connect the Android device to Internet. If you carrier allow shared plan, you probably can add this device to the plan on the cheap :)
Posted Jan 22, 2015 · 12:58 UTC#20
you can usually use update in settings to update to update to 4.4.2, I'm not sure what was stock on mine as I installed a new rom when I received it
Posted Jan 22, 2015 · 13:00 UTC#21
I'll test this out on my way home from work this evening
I looked at the Google Play store and could not find this app specifically, but searching for AirPlay I found a few related apps...
Posted Jan 22, 2015 · 13:01 UTC#22
Installed a new ROM? What do you mean? A physical chip or a software ROM?
Posted Jan 22, 2015 · 14:11 UTC#23
software rom/firmware
Posted Jan 22, 2015 · 18:20 UTC#24
Am I wrong assuming this means upgrading the android version?
I' not quite familiar with the Android versions, platform and upgrades. I just know that on cell phones that has to come from the manufacturer to the carrier then to the customers. But I'm not sure if those PC sticks can be upgraded to the latest versions without too much work.
Page 1 of 3
