alright guys I'm going to post up what I have so far since I now have a way to go back to 1.08
after further playing around the process is a bit easier than I originally thought. All you need to do is take the firmware you want to flash and change the names of the files and folders to that of what version the device THINKS it is.
for example. if going from 4000 to 4100, the 1.03 FW is named AVIC5100NEX, this needs to be AVIC5000NEX. inside this folder there are a bunch of other files and folders with the name 150 in it, every 150 must be changed to a 140 so that the NEX4000 thinks it is the correct file for it.
When flashing back to 1.08 you simply need to change the 1.08 file structure so that it looks like a NEX4100 update.
At this moment ALL BT Audio is not working. you cannot get any audio that functions over BT to work, this means pandora / Android Auto (just the audio) / phone calls, and anything else that uses BT as the means for audio.
As far as I can tell this is due to the user not being able to toggle BT Audio from "off" to "on" in the settings of the device like you can on 1.08, it is stuck off and this is apart of the USERDATA folder which I don't currently have a way of reading.
What I am hoping is that this is a problem for the 4100 too and the will release a new FW soon that we can play with.
If anyone has any idea of how to open the .prj files to view and edit its content please advise!
4000 (1.08) to 4100 (1.03)
http://www.filedropper.com/4000to4100_1
4100 (1.03) to 4000 (1.08)
http://www.filedropper.com/4100to4000test1
Both me and newtonfb have gone to 1.03 and back without a problem.
I'll take a look at the 6000 and 8000 units now to make sure its structure is the same.
