Upgrading NEX4000 to NEX4100 - Work in Progress
By Covert_Death · Mar 24, 2015in NEX Series💬 624 posts👁️ 179,956 views
Page 21 of 25
Posted Aug 01, 2015 · 07:32 UTC#501
Also it turns out the 4000's have 4GB internal sd cards so a single dd on an ntfs usb stick succeeded in about an hour. I verified I could mount the partition and I am uploading now and will share a link when it is available.
Posted Aug 01, 2015 · 07:40 UTC#502
[deleted post]
Edited Aug 05, 2015 by whatisbypass
Posted Aug 01, 2015 · 08:16 UTC#503
Gotcha. Dding and will try in the morning.
Also I am convinced on this USB_OTG_ID function under usb test making it a device for adb. Looking at the board there is no other pin and if my research is correct, Regular OTG devices have a sense pin that tell the device which mode. I think the nex has this except it is virtual somehow and is this setting.
Changing it changed the first usb in the test mode settings to switch to function (or Device) mode. However the usb pin still sends 5v which I don't believe is correct.
If anyone has some thoughts here I'm open to them.
Posted Aug 01, 2015 · 11:13 UTC#504
I really appreciate all the hard work here guys! Hey anyway we can get a overall update on progress for us non smart guys.. U know kinda like a OP like you would see on the xda forums. Yes I'm a android geek. Thanks again!
Posted Aug 01, 2015 · 11:14 UTC#505
Noone has tried Drive maintenance => Dump by Sector => Storage SD ? :) I'm not speaking about Copy Device menu function. I can try to disassemble this Dump by Sector mode functions and screens.
Yeah. Which sector would you like? I can get any sector on the disk... All 16G of sectors are available... One at a time.
Posted Aug 01, 2015 · 11:18 UTC#506
You can update bootloader in Write Program Forcedly => Write BootLoader. Also here is bluetooth update.
Also I have found what Write Program Forcedly => Copy device sets something in BSP area (NOR flash) and reboots. So it looks like this copy function is in NOR.
I've developed a safer solution for this. https://play.google.com/store/apps/details?id=com.adamoutler.extremebricksimulatorprofessional
Be very careful.
Posted Aug 01, 2015 · 11:34 UTC#507
[deleted post]
Posted Aug 01, 2015 · 19:19 UTC#508
I mean is it possible to boot device without internal sd card (with original firmware).
For example, is it possible to get new sd card, write data (what your dd produced), insert this sd card into external sd card slot and try to boot from this card without internal sd card inserted?
This opens ability to restore device's internal sd without removing device from car.
Nope didn't work. Just got the u-boot error screen
Posted Aug 01, 2015 · 19:28 UTC#509
[deleted post]
Posted Aug 01, 2015 · 19:48 UTC#510
Usually it is accessible through uart. I'm waiting on a new bus pirate to tackle this job. I keep blowing them up.
Posted Aug 01, 2015 · 19:53 UTC#511
[deleted post]
Posted Aug 02, 2015 · 19:24 UTC#512
I got the image from the deck.  Attached is a picture.
adamoutler@adamoutler-desktop:~/Desktop/Untitled Folder 3$ fdisk -l ./fullsd.img
Disk ./fullsd.img: 16.1 GB, 16130244608 bytes
128 heads, 16 sectors/track, 15383 cylinders, total 31504384 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
       Device Boot      Start         End      Blocks   Id  System
./fullsd.img1         1050624     1071103       10240   83  Linux
./fullsd.img2         1071104     1091583       10240   83  Linux
./fullsd.img3         1091584     3573759     1241088    5  Extended
./fullsd.img4         3573760    30197759    13312000   83  Linux
./fullsd.img5         1091585     1153023       30719+  83  Linux
./fullsd.img6         1153025     1214463       30719+  83  Linux
./fullsd.img7         1214465     2263039      524287+  83  Linux
./fullsd.img8         2263041     2525183      131071+  83  Linux
./fullsd.img9         2525185     3573759      524287+  83  Linux
upload will take a while.
Edited Aug 02, 2015 by AdamOutler
Posted Aug 02, 2015 · 19:42 UTC#513
[deleted post]
Posted Aug 02, 2015 · 23:06 UTC#514
As we start acquiring system images, is there a collective place we can store these for all? I tried uploading mine to mega but it kept failing. So uploading to google drive right now.
Posted Aug 03, 2015 · 08:57 UTC#515
Can anyone confirm is iGo license will fail after cloned sd card replacement? I'm asking about hardware identification information for iGo. This hardware id data exists only on sd card or in nor flash too?
Is it possible to get SD card image with latest iGo maps from another man and write this image into my device? Will iGo licenses work with it?
Course,hardware identification information for iGo exist,NNG insert its own ID on sd card as well as strict dependance of the unique SWID of the device (nor flash) and sd card S.N.
So, the iGO shouldn't work with out "special" manipulations... 8)
Posted Aug 03, 2015 · 09:24 UTC#516
[deleted post]
Posted Aug 03, 2015 · 11:31 UTC#517
oh guys
i have a rar archive with a lot of licenses
download it and try to use
In Brazil, we have HERE MAPS 2015 Q1, but i can't update it because i don't know how to generate update stm archive in synctools folder
IGO generate a md5 and stm file to indicate files to update.
if it missed, update will be fail
After use naviextra software to performe some update, the software generate two new files
here the .stm file structure
Edited Aug 03, 2015 by ils15
Posted Aug 03, 2015 · 11:48 UTC#518
[deleted post]
Posted Aug 03, 2015 · 11:56 UTC#519
This *.stm-files is not license files. This files is instructions for igo with information what to copy and where to copy. *.md5-files is MD5 checksums. It was possible to use naviextras toolbox to generate this files with my own contents to upload my own contents to device, but this is useless now as we can copy files directly to device using testmode.
below there are some license files for diferent gps products
you can donwload and test  it
look for that
http://www.datafilehost.com/d/4f7fdff3
Posted Aug 03, 2015 · 12:05 UTC#520
It seems that you are well versed in this. Is there any chances to upload different or updated maps? Uploading new maps into internal flash isn't problem using testmode. Problem is getting licenses for this maps.
Tnx Mate!
To completely finish the work (to enable online services [wheather,fuel,local search & online parking]),I need the one missed license (Pioneer_NA_Connected_Services_2014_Q4.lyc).May be someone,have been updated via toolbox,can share it with me !?
If so - wellcome to PM. :)
Edited Aug 03, 2015 by Lucca
Posted Aug 03, 2015 · 12:17 UTC#521
[deleted post]
Posted Aug 03, 2015 · 13:47 UTC#522
[deleted post]
Posted Aug 03, 2015 · 15:02 UTC#523
I have tested USB-UART devices (FT232RL and CP2102) and USB-Ethernet adapter:
<7>[  155.086565] ehci_fsl_bus_resume begins, Host 1
<7>[  155.098306] ehci_fsl_bus_resume ends, Host 1
<6>[  155.358341] usb 2-1: new full speed USB device number 3 using fsl-ehci
<6>[  161.273178] usb 2-1: USB disconnect, device number 3
<7>[  163.498318] ehci_fsl_bus_suspend begins, Host 1
<7>[  163.498395] ehci_fsl_bus_suspend ends, Host 1
<7>[  167.296746] ehci_fsl_bus_resume begins, Host 1
<7>[  167.308316] ehci_fsl_bus_resume ends, Host 1
<6>[  167.558301] usb 2-1: new full speed USB device number 4 using fsl-ehci
<6>[  170.422095] usb 2-1: USB disconnect, device number 4
<7>[  172.618383] ehci_fsl_bus_suspend begins, Host 1
<7>[  172.618550] ehci_fsl_bus_suspend ends, Host 1
<7>[  202.275666] ehci_fsl_bus_resume begins, Host 1
<7>[  202.288316] ehci_fsl_bus_resume ends, Host 1
<6>[  202.548341] usb 2-1: new full speed USB device number 5 using fsl-ehci
<6>[  208.890184] usb 2-1: USB disconnect, device number 5
<7>[  211.428366] ehci_fsl_bus_suspend begins, Host 1
<7>[  211.428462] ehci_fsl_bus_suspend ends, Host 1
<7>[  223.007508] ehci_fsl_bus_resume begins, Host 1
<7>[  223.018323] ehci_fsl_bus_resume ends, Host 1
<6>[  223.268310] usb 2-1: new high speed USB device number 6 using fsl-ehci
<6>[  230.009255] usb 2-1: USB disconnect, device number 6
<7>[  232.428337] ehci_fsl_bus_suspend begins, Host 1
<7>[  232.428364] ehci_fsl_bus_suspend ends, Host 1
<6>[  246.524370] usb 1-1: USB disconnect, device number 2
<7>[  249.468365] ehci_fsl_bus_suspend begins, DR
<7>[  249.468670] ehci_fsl_bus_suspend ends, DR
<7>[  251.608627] ehci_fsl_bus_resume begins, DR
<7>[  251.628292] ehci_fsl_bus_resume ends, DR
<6>[  251.878310] usb 1-1: new full speed USB device number 3 using fsl-ehci
<3>[  252.034812] usb 1-1: device v10c4 pea60 is not supported
<6>[  255.825946] usb 1-1: USB disconnect, device number 3
<7>[  258.428354] ehci_fsl_bus_suspend begins, DR
<7>[  258.428672] ehci_fsl_bus_suspend ends, DR
<7>[  262.078712] ehci_fsl_bus_resume begins, DR
<7>[  262.098319] ehci_fsl_bus_resume ends, DR
<6>[  262.348311] usb 1-1: new high speed USB device number 4 using fsl-ehci
<3>[  262.512100] usb 1-1: device v0b95 p772b is not supported
<6>[  265.213849] usb 1-1: USB disconnect, device number 4
<7>[  267.428406] ehci_fsl_bus_suspend begins, DR
<7>[  267.428841] ehci_fsl_bus_suspend ends, DR
<7>[  269.338706] ehci_fsl_bus_resume begins, DR
<7>[  269.358322] ehci_fsl_bus_resume ends, DR
VID 10c4 PID ea60 from CP2102
VID 0b95 PID 772b from ASIX ethernet adapter
Looks like this devices has no drivers.
But there is no "not supported" line for FT232RL USB-UART adapter. So it supported or I do something wrong?
Also I have tried to change USB OTG ID to HIGH. After this change device reboots and USB Host/Function field of USB1 (device calls USB1 = Port1 and USB2 = Port0) is changed from USB Host to USB Function. After this change, USB1 is working like slave device, it is not possible to insert and use USB-flash in this USB1. I think this can help finding USB ADB, but I do not unserstand how to connect, for example, my laptop (I need USB-male<>USB-male cable?). Also maybe I need to change debug serial setting to ON (default is OFF). update: there is not very clear scheme of work, you should select port number (0 = USB2, 1 = USB1) in submenu and then use other menus of USB test.
Also I have tried to change product information. (Write product information (manual) menu). It is possible to change long 16-digit number (something like serial), but I think this product info is not affects iGo license. I changed last digit from 2 to 3 and reboot device. iGo software ID's isn't changed, licenses still working, so I revert this digit back to 2.
Using copy_script.sh, get the output of 'netcfg' before and after the usb device is connected.   if that doesn't work, check "ifconfig eth0", "ifconfig usb0", and "ifconfig wlan0", then change the 0's to 1s
Posted Aug 03, 2015 · 15:11 UTC#524
[deleted post]
Posted Aug 03, 2015 · 16:24 UTC#525
Thank you, I'll try later.
How to connect pioneer device in device (not host) mode to laptop? I must use USB-male <=> USB-male cable?
Is it possible to check is pioneer's USB ADB enabled and working using USB-microUSB cable and my Samsung Galaxy Note 3 phone ? Is it possible to view usb device information from USB-OTG connection from my phone?
You should be able to but you will need a USB-A to USB-A cable. I bought one but when I switch my Radio to Device mode my computer does not detect it.
As for the ethernet, I have noticed the device as network drivers of some sort, have you tried connecting it and then running a scan of your network and seeing if the network lights turn on?
Page 21 of 25
