Upgrading NEX4000 to NEX4100 - Work in Progress
By Covert_Death · Mar 24, 2015in NEX Series💬 624 posts👁️ 179,956 views
Page 23 of 25
Posted Aug 04, 2015 · 23:58 UTC#551
Oh yeah!  My AVIC-8100NEX works!
I managed to get it to copy by simply sticking the new SDCard into my deck and letting it boot.  It booted right into Android and brought up the selection screens!
After I rebooted using key 1, it went into this mode where i wrote the programs.
But.. I wrote the programs to a new SDCard.. 80X.
The darn thing boots in 10 seconds now!  and works great in Android Auto!
It lives again!
Posted Aug 05, 2015 · 00:02 UTC#552
It lives again!
Thats great to hear!!!
Posted Aug 05, 2015 · 00:06 UTC#553
It lives again!
Great Great Great!!!
Posted Aug 05, 2015 · 01:44 UTC#554
Does this mean having the Play Store, root access, overclock, etc.?  I wonder if anything can be done about the number files/folders limitation?
Posted Aug 05, 2015 · 03:07 UTC#555
Not yet. But that is one of the end end goals.
Posted Aug 05, 2015 · 03:41 UTC#556
Using copy_script.sh, get the output of 'netcfg' before and after the usb device is connected.   if that doesn't work, check "ifconfig eth0", "ifconfig usb0", and "ifconfig wlan0", then change the 0's to 1s
So without anything attached the following script:
#! /system/bin/sh
out="/mnt/udisk/log.txt"
echo "--ifconfig-- eth0" 2>&1 >>$out
ifconfig eth0 2>&1 >>$out
echo "--ifconfig-- eth1" >>$out
ifconfig eth1 2>&1 >>$out
echo "--ifconfig-- usb0">>$out
ifconfig usb0 2>&1 >>$out
echo "--ifconfig-- usb1" >>$out
ifconfig usb1 2>&1 >>$out
echo "--ifconfig-- wlan0" >>$out
ifconfig wlan0 >>$out
echo "--ifconfig-- wlan1" >>$out
ifconfig wlan1 2>&1 >>$out
echo "--id--">>$out
netcfg  2>&1 >>$out
Produces:
--ifconfig-- eth0
--ifconfig-- eth1
--ifconfig-- usb0
--ifconfig-- usb1
--ifconfig-- wlan0
--ifconfig-- wlan1
--id--
lo       UP                                   127.0.0.1/8   0x00000049 00:00:00:00:00:00
eth0     DOWN                                   0.0.0.0/0   0x00001002 1e:ed:19:27:1a:b3
tunl0    DOWN                                   0.0.0.0/0   0x00000080 00:00:00:00:00:00
sit0     DOWN                                   0.0.0.0/0   0x00000080 00:00:00:00:00:00
ip6tnl0  DOWN                                   0.0.0.0/0   0x00000080 00:00:00:00:00:00
What I find interesting is that a eth0 does seem to exist without anything connected. When I do connect a cheap wireless or ethernet adapter the output stays the same.  Time to look at the board. If anyone sees something let me know.
Posted Aug 05, 2015 · 06:24 UTC#557
[deleted post]
Edited Aug 05, 2015 by whatisbypass
Posted Aug 05, 2015 · 06:49 UTC#558
[deleted post]
Posted Aug 05, 2015 · 11:02 UTC#559
@AdamOutler what about iGo licenses? iGo in your "new" device is still working? Or licenses are invalid now? There is no maps now? As your firmware does not contain maps for iGo. How your EXTDATA partition is created without actual maps and data in firmware from pioneer?
If iGo is working but without maps, is it possible to update or upload free maps via naviextras? "First gps fix time" is changed to "now" or still older time? Can we "reset" iGo inserting new SD to update maps (free 45-day period after first gps fix)?
Can you now insert your old SD card into device, is it working or shows invalid password now?
What, like this?
Posted Aug 05, 2015 · 12:15 UTC#560
[deleted post]
Posted Aug 05, 2015 · 13:48 UTC#561
[deleted post]
Posted Aug 05, 2015 · 15:06 UTC#562
Great news, I found my SD Card password and found possibility to change all BSP settings, there is dump from my NOR flash:
This 16 digits is a serial number of your SD..,but not the pass.,the pass. must be 8 digits.
Posted Aug 05, 2015 · 15:17 UTC#563
Heh, they probably made the password a checksum of the serial.
Posted Aug 05, 2015 · 15:37 UTC#564
[deleted post]
Posted Aug 05, 2015 · 15:38 UTC#565
[deleted post]
Posted Aug 05, 2015 · 17:16 UTC#566
[deleted post]
Posted Aug 05, 2015 · 19:58 UTC#567
A5 5A 5A A5 // ulong ulSignature;
00 00 00 00 // ulong ulbootmode; // 0
00 00 00 00 // ulong ullaunchmode; // 4
00 00 00 00 // ulong ultestsubmode; // 8
00 00 00 00 // ulong ulbootimageflag; // 12
00 00 00 00 // ulong ulrecoveryimageflag; // 16
00 00 00 00 // ulong uldebugswitch; // 20
00 00 00 00 // ulong ulusbotgswitch; // 24
00 00 00 00 // ulong ulmemchkflag; // 28
00 00 00 00 // ulong ulwarpboot; // 32
02 00 00 00 // ulong ulsubbootmode; // 36
06 00 00 00 // ulong ulupdateflag; // 40
01 00 00 00 // ulong ulupdatesubflag; // 44
XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX // password
00 00 00 00 // ulong uluiupdateflag; // 64
FF FF FF FF // ulong ulreserved1;
FF FF FF FF // ulong ulreserved2;
D5 72 B1 12 // ulong ulcrc32;
Congratulation!
May I ask how did you dump NOR?
Did you use JTAG?
Posted Aug 06, 2015 · 02:30 UTC#568
I follow this thread since the start and this is awesome ! But now i see that all message by whatisbypass are [deleted post] ?? What is happening ?
Posted Aug 06, 2015 · 04:50 UTC#569
Could be he deleted them himself, normally if deleted by moderator, it just will disappear.
Posted Aug 06, 2015 · 11:33 UTC#570
now here in brazil we are working in Igo NextGen... We will try to crack license and use new Here Maps
In Brazil, last update is 2014.Q2 (Naviextras update)
But more recently Nokia Maps updated to Here 2015.Q1, and then working very well on old IGO units
If anyone have this new license files, please, send me inbox
thanks
Posted Aug 06, 2015 · 13:14 UTC#571
As I mentioned above,iGO NextGen works perfect with wordwide content including Brazil as well...
but!!! - here is a topic about general pioneer hardware/software problems and solutions! and not navigation only!
So - be patient to the end of work  and lets us all to stop flooding here!
Regards,
Lucca
Edited Aug 06, 2015 by Lucca
Posted Aug 06, 2015 · 15:24 UTC#572
sorry guy
i will search for this post
if you can send-me PM with post link, i will thanks you
thanks
Posted Aug 07, 2015 · 13:31 UTC#573
What happened? Did "whatisbypass" delete all his own posts, or was he pressured to do so? Like others, I was really enjoying following along, and the progress being made!
Posted Aug 07, 2015 · 14:53 UTC#574
Look like he had been pressured .... Did Pioneer stepped in ? I Hope not
Posted Aug 07, 2015 · 22:16 UTC#575
I've took everything i could in backup (Thanx Google cache) so i have 80% or more that whatisbypass erased. I will try some experiments on my 4100. Just have to buy a new SD Card.
Page 23 of 25
