The AVIC Development Mod
By bass_rock · Aug 10, 2015in NEX Series💬 720 posts👁️ 589,887 views
Page 29 of 29
Posted Aug 06, 2022 · 07:40 UTC#701
12 hours ago, asd255 said:
speedcam for France can be activated
Bonjour, merci pour le lien, peux tu me dire comment activer les radars pour la France ?
Hello, thank you for the link, can you tell me how to activate the speed cameras for France ?
Posted Aug 07, 2022 · 15:07 UTC#702
@asd255
Can we edit the sys.txt file, and add the [HVA] section to authorize speed cameras in France
Path:DATA/data/com.navngo.igo.javaclient/sys.txt
ex:
[hva]
hva_countries=""
Peut-on éditer le fichier sys.txt, et rajouter la section [HVA] pour autoriser les radars en France
Edited Aug 07, 2022 by visiteur57
Posted Aug 07, 2022 · 18:42 UTC#703
yes
Posted Aug 07, 2022 · 20:47 UTC#704
it's good, I added these lines in the sys.txt and everything is ok
voila c'est bon, j'ai rajouté ces lignes dans le sys.txt et tout est ok
[hva]
hva_countries = ""
[speedcam.disabled_countries]
_FRA = x, x, x, x, x, x, x
_SUI = x, x, x, x, x, x, x
Posted Aug 07, 2022 · 23:59 UTC#705
_FRA=1,2,3,4,5,11,7
_SUI=1,2,3,4,5,11,7
try
but i edit data.zip
but there is a problem with replacing it
Posted Aug 08, 2022 · 07:26 UTC#706
I would like to make a backup of my Pioneer.. an avic.img what should I do this with? I have InternalSDCardBackup, but the Pioneer does not start in testmode with the one I have.
Je voudrais faire une sauvegarde de mon Pioneer .. une avic.img
je dois faire ça avec quoi ?
j'ai InternalSDCardBackup, mais le Pioneer ne démarre pas sur le testmode avec celui que j'ai.
Posted Aug 08, 2022 · 07:28 UTC#707
j'ai InternalSDCardBackup, mais le Pioneer ne demarre pas sur le testmode avec celui que j'ai.
Posted Oct 01, 2022 · 17:26 UTC#708
On 12/19/2015 at 10:11 PM, asd255 said:
UART  Connect(change bsp, android consol)
You can buy compatible USB-UART adapter ex. PL2303
Just connect three wires (GND, TX, RX) from adapter to your head unit and you will get access to bootloader console where you can change BSP settings to restore boot process.
TX  - to EXTOMX (16)
RX  - to MXTOEX (17)
GND - GND           (26)
  Reveal hidden contents
 5aec0bc362d26_RGBInput.png.2d63b98e5ca361b8749c0cb22a104432.png 5aec0dbfe2c22_(2).jpg.5357a3bec327d35450d9cd19caee5fc3.jpg 5aec0dbf4af8a_UIART.jpg.66a069fdbf37779516af0185a10043a9.jpg
Use the PuTTY terminal to connect to the console
115200 8N1
you have a few seconds at the beginning that would press any button to enter the command.
you have 20 seconds to enter commands
U-Boot 2009.08 (Jan 06 2014 - 16:32:44)
CPU: Freescale i.MX6 family TO1.1 at 792 MHz
Thermal sensor with ratio = 174
Temperature:   25 C, calibration data 0x54e4a27d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock   : 198000000Hz
emi_slow clock: 99000000Hz
ddr clock     : 396000000Hz
usdhc1 clock  : 198000000Hz
usdhc2 clock  : 198000000Hz
usdhc3 clock  : 198000000Hz
usdhc4 clock  : 198000000Hz
nfc clock     : 24000000Hz
Board: i.MX6DL/Solo-JUPITER: unknown-board Board: 0x61011 [POR ]
Boot Device: NOR
I2C:   ready
DRAM:   1 GB
Flash:  8 MB
MMC:   FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2
Using default environment
In:    serial
Out:   serial
Err:   serial
***** display DDR calibration result *****
Display result(register) of WriteLeveling
   MMDC registers updated from WriteLeveling
   MPWLDECTRL0 (0x021b080c) = 0x002E0037
   MPWLDECTRL1 (0x021b0810) = 0x00150017
Display result(register) of DDR calibration
   MMDC registers updated from calibration
   Read DQS Gating calibration
   MPDGCTRL0 PHY0 (0x021b083c) = 0x421B0215
   MPDGCTRL1 PHY0 (0x021b0840) = 0x015F0167
   Read calibration
   MPRDDLCTL PHY0 (0x021b0848) = 0x44494848
   Write calibration
   MPWRDLCTL PHY0 (0x021b0850) = 0x3F3F3F37
Net:   got MAC address from IIM: 00:00:00:00:00:00
FEC0 [PRIME]
BSP A is valid
BSP B is valid
imx6 core num: 1
BSP A is valid
BSP B is valid
main loop boot env = 0
Hit any key to stop autoboot:  0
MX6SDL JUPITER KT 4.2.2 U-Boot > <INTERRUPT>
MX6SDL JUPITER KT 4.2.2 U-Boot >sdfsdf
List command:  help
MX6SDL JUPITER KT 4.2.2 U-Boot > help
?       - alias for 'help'
autoscr - DEPRECATED - use "source" command instead
base    - print or set address offset
bdinfo  - print Board Info structure
bmp     - manipulate BMP image data
boot    - boot default, i.e., run 'bootcmd'
bootd   - boot default, i.e., run 'bootcmd'
booti   - booti   - boot android bootimg from memory
bootm   - boot application image from memory
bootp   - boot image via network using BOOTP/TFTP protocol
bsp     - get bsp info, or set bsp info
clear_bootf- clear Warp!! bootflag
clk     - Clock sub system
cls     - clear screen
cmp     - memory compare
coninfo - print console devices and information
cp      - memory copy
crc32   - checksum calculation
dhcp    - boot image via network using DHCP/TFTP protocol
download_mode- download_mode - enter i.MX serial/usb download mode
echo    - echo args to console
erase   - erase FLASH memory
ext2load- load binary file from a Ext2 filesystem
ext2ls  - list files in a directory (default /)
fatinfo - print information about filesystem
fatload - load binary file from a dos filesystem
fatls   - list files in a directory (default /)
flinfo  - print FLASH memory information
go      - start application at address 'addr'
help    - print online help
i2c     - I2C sub-system
iminfo  - print header information for application image
imxotp  - One-Time Programable sub-system
imxtract- extract a part of a multi-image
itest   - return true/false on integer compare
loadb   - load binary file over serial line (kermit mode)
loads   - load S-Record file over serial line
loady   - load binary file over serial line (ymodem mode)
loop    - infinite loop on address range
md      - memory display
memchk  - memory check
mii     - MII utility commands
mm      - memory modify (auto-incrementing address)
mmc     - MMC sub system
mmcinfo - display MMC info
model   - get model info, or set model info.
mtest   - simple RAM read/write test
mw      - memory write (fill)
nfs     - boot image via network using NFS protocol
nm      - memory modify (constant address)
ping    - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
protect - enable or disable FLASH write protection
rarpboot- boot image via network using RARP/TFTP protocol
regul   - Regulator sub system
reset   - Perform RESET of the CPU
run     - run commands in an environment variable
setenv  - set environment variables
sf      - SPI flash sub-system
sleep   - delay execution for some time
source  - run script from memory
sspi    - SPI utility commands
tftpboot- boot image via network using TFTP protocol
version - print monitor version
warp    - Warp!! boot
asfasfsa
help bsp
MX6SDL JUPITER KT 4.2.2 U-Boot > help bsp
Usage:
bsp Usage:
bsp init - init bsp information to init value
bsp get  - get bsp information from nor flash
bsp passwd  <passwd> - set sd card password (16bytes)
bsp set  <item> <value> - set bsp information to nor flash
item
  -m: set boot mode
      value
        0: Normal
        1: Recovery
        2: EasyRecovery(CopyDevice)
        3: Re-EasyRecovery
  -l: set launch mode flag
      value
        0: APL
        1: TestMode.apk
        2: Slave TestMode
        3: Boot Error
  -t: set TestMode Sub Mode
      value
        0: Tech Mode
        1: Serv Mode
        2: TestMode_A.key
  -b: set bootimage active side flag
      value
        0: Side A
        1: Side B
  -r: set recoveryimage active side flag
      value
        0: Side A
        1: Side B
  -d: set debug on/off switch
      value
        0: OFF
        1: ON
  -u: set usb otg switch
      value
        0: Host
        1: Device
  -c: set memchk flag
      value
        0: No
        1: Yes
  -w: set warp boot active side flag
      value
        0: Side A
        1: Side B
  -s: set boot sub mode flag
      value
        0: Normal
        1: Catch snapshot
        2: Warp
  -f: set update flag
      value
        0: Recovery-Update
        1: uboot update
        2: boot.img update
        3: recovery.img update
        4: system.img update
        5: opening data update
        6: UI update
        7: All image update
        8: TESTMODE_N.KEY
        9: easyrecovery copy
        10: easyrecovery copy&verify
        11: password key copy&verify
        12: easyrecovery mode change
  -sf: set update sub flag
      value
        0: SD Card
        1: USB1
        2: USB2
  -uif: set ui update flag
      value
        0: non-updating
        1: updating
BSP get
MX6SDL JUPITER KT 4.2.2 U-Boot > bsp get
BSP A is valid
BSP B is valid
##  A Side BSP Information:
        Magic Number       :0xa55a5aa5(a55a5aa5:Valid, other:Invalid)
        Boot Mode          :0x00000000(0:Normal,
                                       1:Recovery,
                                       2:EasyRecovery,
                                       3:Re-EasyRecovery,
                                       default:Normal)
        Launch Mode        :0x00000000(0:APL,
                                       1:TestMode.apk,
                                       2:Slave TestMode,
                                       3:Boot Error,
                                       default:APL)
        TestMode Sub-Mode  :0x00000000(0:TextMode_A.key, 1:Serv Mode,        2:Tech Mode,     default:        Tech Mode)
        Bootimage Side     :0x00000000(0:Side A,         1:Side B,                            default:        Side A)
        Recoveryimage Side :0x00000000(0:Side A,         1:Side B,                            default:        Side A)
        Debug Switch       :0x00000002(0:OFF,            1:ON,                                default:        OFF)
        Usb OTG Switch     :0x00000000(0:Host,           1:Device,                            default:        Host)
        Memchk flag        :0x00000000(0:No,             1:Yes,                               default:        No)
        Warp boot          :0x00000000(0:Side A,         1:Side B,                            default:        Side A)
        Boot Sub-Mode      :0x00000002(0:Normal,         1:Catch snapshot,   2:Warp,          default:        Normal)
        Update flag        :0x0000000c(0:Recovery-Update,
                                       1:uboot update,
                                       2:boot.img update,
                                       3:recovery.img update,
                                       4:system.img update,
                                       5:opening data update,
                                       6:UI update,
                                       7:All image update,
                                       8:TESTMODE_N.KEY,
                                       9:easyrecovery copy,
                                       a:easyrecovery copy&verify,
                                       b:password key copy&verify,
                                       c:easyrecovery mode change,
                                       default:Recovery-Update)
        Update sub-flag    :0x00000001(0:SD Card,        1:USB1,             2:USB2           default:        SD Card)
        UI Update  flag    :0x00000000(0:non-updating,   1:updating,         default:non-updating)
        Reserved1  flag    :0xffffffff(default:0xFFFFFFFF)
        Reserved2  flag    :0xffffffff(default:0xFFFFFFFF)
##  B Side BSP Information:
                                       1:Recovery,
                                       2:EasyRecovery,
                                       3:Re-EasyRecovery,
                                       default:Normal)
                                       1:TestMode.apk,
                                       2:Slave TestMode,
                                       3:Boot Error,
                                       default:APL)
                                       1:uboot update,
                                       2:boot.img update,
                                       6:UI update,
                                       7:All image update,
                                       8:TESTMODE_N.KEY,
        Update sub-flag    :0x00000001(0:SD Card,        1:USB1,             2:USB2,          default:        SD Card)
If you have an error while updating the firmware.
Replacing the SD card will not solve the problem.
You need to change the boot from Recovery to Normal
set boot mode "normal"
bsp set -m 0
if you used "Catch snapshot" from Debug Menu - cyclic reboots
set boot sub mode flag "normal"
bsp set -s 0
Edited Oct 09, 2022 by f9uah
Posted Jan 28, 2023 · 10:20 UTC#709
Hello, i have tried to connect with UART to my PC (F960BT) and it opens an blank window, i insert the right speed and nothing happens, do i need to connect the headunit to some kind of power to boot it up in order to get in the bootloader with UART ?
Posted Jan 28, 2023 · 15:55 UTC#710
Yes
Posted Feb 07, 2023 · 20:33 UTC#711
Ik zou graag mijn f980dab willen patchen, wat kan ik hiervoor gebruiken. Ik kan het niet goed vinden op de vertaalde fora, ik zoek al 2 maanden iedere dag. Graag wat hulp
Posted Mar 09, 2023 · 20:43 UTC#712
Wow, and wow again. Reading back it seems like one or two really clever developers knew their stuff discovered the holy grail and made great strides.
But here in the future (2023), It's like the clever scientists back then discovered the true meaning of life, shouted out a few instructions for a while and then left the rest of the human race to fend for itself without a manual.
As much as I appreciated all the hard work, commitment and support from these clever people in keeping my unit working and updated, sadly I couldnt keep up with the understanding and conflicting procedures and files needed with even basic stuff like testmode, so like many I just gave up with pioneer long before this discovery and jumped to a better integrating / fitting / looking android unit, that I still use today. Maybe I wasn't alone ?
As I posted elsewhere I was shocked recently to see the decline in pioneer units. No question that even with the flaws and faults and same unchanged box fit, the hardware and quality was good despite win ce. But now for all but a very few models they now mostly depend on a connected phone for abilities and function.
Trying to repair a couple of several year old units for a friend, (2014)  I've found that without working links to needed files anymore or any kind of simple framework or information to follow still, there is little hope. judging by all the number of un replied posts over the last few years many must feel the same way.
The sad thing is, there seems to be a resurgence in these 'older' better quality navigation units as people shun the expensive rubbish peddled as 'car play ready' or whatever and look to buy and possibly one day mod them too.
I just hope the clever programmers, hackers and coders who left us so long ago might one day return to take pity and re-educate us. :-)
Edited Mar 09, 2023 by cleverdicky — Reason: spelling
Posted May 10, 2023 · 20:01 UTC#713
Thank you all for this hughe resource with information.
I just finished updating a Avic f980bt-c machine with the 2022 maps. And some extras.
Some issues i experienced and want to share.
I updated the firmware to latest version from the official website. 8.08
After that i tried to update the maps with the copy script method..
Did not work unable to write filesystem read only.
mnt/udisk/script.sh[8]: cat: <stdout>: Read-only file system
I tried to create an hacked SD card no password. this was not working for me somehowe.
Next step was to downgrade the firmware... You can just change the number in the URL for the pioneer website. So i was able to get the 8.04 version.
After installing this version i am able to do all the copy work to the device.
Now getting back the 8.08 version on there again.
Just to share. Might help some persons..
Edited May 10, 2023 by willempie
Posted Aug 04, 2023 · 12:31 UTC#714
Can someone reupload the patches for x000, x100 and x200?
Thanks.
Posted Aug 04, 2023 · 22:16 UTC#715
What patch?
Posted Aug 29, 2023 · 18:56 UTC#716
My unit refuses to enter normal boot mode. Only works in Warp mode. In normal mode, it shows password error...
"Jupiter MMC init failed, set password failed"
...and freeze in the Pioneer logo.
I must be removing the sd card incorrectly.
I do it using the testmode_N key. Or with the testmode_A, selecting the "mode change" option on the 7th page of the test mode menu.
Posted Sep 11, 2023 · 22:00 UTC#717
WARP - This is normal mode!
Posted Mar 15, 2024 · 09:21 UTC#718
hello
i want to update the maps on Avic f70dab
 i prepared the USB Stick, i can enter the test mode , i followed the steps but i cannot copy the files. the device is ready within a second. no data transfer. 100% complete message shows up instantly. last update 2019 worked, but none since then.
any idea?
Posted Apr 22, 2024 · 19:17 UTC#719
This !
Exactly what I mean.
It would be really nice if one skilled developer could make some kind of an app or website with all files, scripts, apps and instructions that are needed to keep those devices up and running or resurecting if failed already.
And explain it with words simple enough that people that are handy with computers and stuff but are not programmers could understand it and make it work. I know that servers, hostings etc costs money, so access to all the knowledge and database could be behind some few dollars paywall.
Posted Apr 24, 2024 · 18:17 UTC#720
On 1/28/2023 at 3:50 PM, iLexinho said:
Hello, i have tried to connect with UART to my PC (F960BT) and it opens an blank window. i insert the right speed and nothing happens, do i need to connect the headunit to some kind of power to boot it up in order to get in the bootloader with UART ?
It's possible that the headunit needs power to boot up fully and access the bootloader via UART. Try connecting it to power and then retrying the UART connection. Ensure the baud rate matches and check for any hardware or wiring issues.
Edited May 01, 2024 by nathan25
Page 29 of 29
