Hey All, I'm trying to make a back up of my internal SD for my AVIC 5201nex, I "successfully" made a back up using the script but the file was only 4gb which I feel is WAY too small compared to other backup files that are 7GB - 8GB, when I tried to flash it to an SD card it just messed up the SD card and would not boot. I realized that the USB was FAT32 so the max file size is only 4gb, but when I format the USB to NTFS for the bigger file size, the radio will not boot up into test mode, it seems the USB has to be in FAT32 mode for dev. mod to work.
How is everyone else getting these big file size back ups on their USB?
EDIT: Figured out a way, not sure if its what everyone does.. but I take a FAT32 formatted usb, to boot into the script, remove that USB, insert a NTSC formatted USB, then hit copy script and it worked. Feel free to correct me if there is a better way to do it.
