AVIC Development Mod - Device Backup
By bass_rock · Aug 10, 2015in NEX Series💬 56 posts👁️ 49,778 views
Page 3 of 3
Posted Jun 05, 2023 · 13:21 UTC#51
what radio do you have?
Posted Jun 05, 2023 · 14:00 UTC#52
OK, Im making progress.
I can type now and it pauses window data ;-)
I tried easyrecovery - nothing.
Tried bsp init and it had some effect. (below)
Now I have no boot loop but have the standard software error - contact pioneer service center.  :-( Does that mean I need new sdcard ?
MX6SDL JUPITER KT 4.2.2 U-Boot >
U-Boot 2009.08 (Jan 06 2014 - 16:32:44)
CPU: Freescale i.MX6 family TO1.1 at 792 MHz
Thermal sensor with ratio = 181
Temperature:   40 C, calibration data 0x57c4c97d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock   : 198000000Hz
emi_slow clock: 99000000Hz
ddr clock     : 396000000Hz
usdhc1 clock  : 198000000Hz
usdhc2 clock  : 198000000Hz
usdhc3 clock  : 198000000Hz
usdhc4 clock  : 198000000Hz
nfc clock     : 24000000Hz
Board: i.MX6DL/Solo-JUPITER: unknown-board Board: 0x61011 [POR ]
Boot Device: NOR
I2C:   ready
DRAM:   1 GB
Flash:  8 MB
MMC:   FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2
Using default environment
In:    serial
Out:   serial
Err:   serial
***** display DDR calibration result *****
Display result(register) of WriteLeveling
   MMDC registers updated from WriteLeveling
   MPWLDECTRL0 (0x021b080c) = 0x00310037
   MPWLDECTRL1 (0x021b0810) = 0x0018001E
Display result(register) of DDR calibration
   MMDC registers updated from calibration
   Read DQS Gating calibration
   MPDGCTRL0 PHY0 (0x021b083c) = 0x42230217
   MPDGCTRL1 PHY0 (0x021b0840) = 0x0177017B
   Read calibration
   MPRDDLCTL PHY0 (0x021b0848) = 0x47494C49
   Write calibration
   MPWRDLCTL PHY0 (0x021b0850) = 0x413F4041
Net:   got MAC address from IIM: 00:00:00:00:00:00
FEC0 [PRIME]
BSP A is valid
BSP B is valid
imx6 core num: 2
BSP A is valid
BSP B is valid
match invalid password 2.
main loop boot env = run bootargs;booti mmc1 ${bootpartition}
Hit any key to stop autoboot:  0
mmc1 init failed
boot error, will boot easyrecovery!!
BSP A is valid
BSP B is valid
-launch mode
. done
Erased 1 sectors
. done
Erased 1 sectors
boot easyrecovery !!
main loop boot env = run bootargs;booti ${bootaddr}
kernel   @ 10808000 (2829424)
ramdisk  @ 11800000 (877890)
kernel cmdline:
        use uboot command line:
        console=ttymxc0,115200 init=/init androidboot.console=ttymxc0 video=mxcfb0:dev=ldb,bpp=32 video=mxcfb1:dev=ak8814,BT656-NTSC,if=BT656,bpp=32 video=mxcfb2:off fbmem=6M,6M vmalloc=400M androidboot.hardware=freescale arm_freq=800 printk.time=1 printk_console=off
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Posted Jun 05, 2023 · 14:06 UTC#53
use "warp" command
Posted Jun 05, 2023 · 14:49 UTC#54
No MMC card found ?
and its looping again ??
Posted Jun 05, 2023 · 15:00 UTC#55
17 hours ago, asd255 said:
SDHC2 'SU32G'  30436MB  4bit  50.0Mbit/s (HS)  block: 512  sect: 127  spec: 3
0080000
I see in the log that the SD card is available
Posted Jun 05, 2023 · 16:04 UTC#56
Hi yes this is weird. I'm not so familiar that I no whats going on. But it is still boot looping unless I type bsp init. Then it seems to run a script, sorts itself out and brings up the software error on the radio screen. Putty then goes blank.
Typing warp when it boots brings the error 'no mmc'. So i tried adding a new blank sdcard in the user slot, but no change.
(could it be looking for update / firmware ? )
I also tried putting the original factory sdcard back in but no change. Also I noticed that the screen wont open now by the buttons. So may have some loose ribbons or could be as it hasnt fully booted. Unit is F60DAB
Page 3 of 3
