2015 European Map Update for Pioneer AVIC-F30BT, F930BT, F9310BT, F40BT, F940BT, F840BT, F8430BT
By Flomsen · Aug 16, 2015in Hacks/Mods💬 789 posts👁️ 337,085 views
Page 29 of 32
Posted Feb 24, 2016 · 15:35 UTC#701
Hi everyone.
First of all, thanks to everyone who put time in this project. I'm in the process of downloading the update right now.
I have quickly read the threads and found very interesting stuff. But I don't get why the first post isn't updated with the accurate informations... Having everything found instantly is clearly better than having to repeat every information a thousand times for everyone who can't find them...
That's just my two cents...
Anyway, big thanks to everyone. I think I'll be the next to buy an update to share it with the community.
Posted Feb 24, 2016 · 15:54 UTC#702
Because only  Flomsen can edit his post, and OP was trying to control access to these files (for $$$). Notice that more than half the posts here are people begging for the password?  When that failed or became too cumbersome, he abandoned this thread.
Edited Feb 24, 2016 by RonS
Posted Feb 24, 2016 · 21:27 UTC#703
RonS,
Okay, finally found some spare time yesterday.
To be 100 percent sure, I went to my local computer store and bought brand new 4GB SD Kingston card.
On my computer I formatted that card to FAT32 with 16KB cluster size.
Then I copied two folders (FIRMWARE, UPDATE) and CARDINFO.cif file directly to freshly formatted SD card.
Inside FIRMWARE folder I have another folder named BT. Inside BT folder – 3 files (bootloader, CK5050P.plf and updater.plf).
Inside UPDATE folder I have two folders (NDATA and USER) plus 4 files (ALLDATA.HTM, ALLDATA.VER, AUTHINFO.DAT and VERINFO.DAT).
Inside NDATA folder – 106 files named NDATA.001 - NDATA.106
Inside USER folder I have 2 folders (PRG and SYSTEM) and 1 file named VOLUME.DAT
And guess what? Nothing! I inserted SD card with the update into SD card slot on my head unit, started the engine (just in case) and my F840BT booted up as usual. Unit sees the card for sure, then I press “eject†button it shows me that SD card is inside.
Honestly, I have no idea what to do next…
Does your HU have the parking brake bypassed? Otherwise I believe you need the PB detection correctly wired and the PB set. The first step in the Pioneer installation instructions is to set the parking brake. Now, that may be just to cover their ass from potential damage/liability suites, but many functions won't work if the HU doesn't detect PB. I can't easily test this theory since mine is bypassed and has been from day-1.
Edited Feb 25, 2016 by RonS
Posted Feb 25, 2016 · 07:09 UTC#704
I believe it does, I can watch movies while driving.
Posted Feb 25, 2016 · 16:03 UTC#705
I'm running out of ideas - I've never had any issues getting updates installed. It's probably something really basic.
What app version are you currently running? See Settings/System Settings/System Information.  Make sure it is less than 6.0
When you format the SD, uncheck "Quick format" - that has caused problems.
What happens if you insert the SD while the HU is already up? If it doesn't start the upgrade process, the "normal" operation would be to scan the SD and start playing some test audio files that are buried in the upgrade. If it doesn't do either of these, something is wrong with the SD.
Next obvious problem is using the wrong CardInfo.cif file. I can't help with that. I only know the internal tags for the Z and X series units. So I can't verify whether your F840-BT is listed. BTW, does it actually say F840-BT on the face of the HU? Some people refer to their HU by the software they are running and not the actual hardware. It matters for CardInfo
Posted Mar 02, 2016 · 09:11 UTC#706
RonS,
Currently I'm on version 5.
I was aware about full formatting of SD card and 16KB cluster size allocation.
If I insert SD card into the HU when it is already running it plays some strange music file.
And for sure, I have AVIC-F840BT.
Maybe you can advise how to install a third party software on my unit? I would gladly use something like "Navigon" or "CityGuide".
Thanks a lot for trying to help me. I really appreciate it.
Posted Mar 02, 2016 · 13:57 UTC#707
Pirrama,
More specutlation here, if your F840BT is wired directly to the battery instead of the ignition, it may be that you unit never gets turned off so it doesn't actually boot the sd card when you turn on the ignition.
If you find that is true, put the sd card in your unit and remove one of the battery cables for 30 seconds or so and then reconnect and see if your unit boots.
Posted Mar 03, 2016 · 13:41 UTC#708
Pirrama,
Thanks for the suggestion. I will give it a try. Should I remove the password first?
Posted Mar 03, 2016 · 14:11 UTC#709
If you know the password, then there's no need to remove it but some people just delete it anyway.
Posted Mar 04, 2016 · 07:11 UTC#710
Just a thought. Is there any way that my password prevents unit from the update?
Posted Mar 04, 2016 · 14:43 UTC#711
Doubtful, but it's not hard to re-make it if you delete it for testing.
Posted Mar 07, 2016 · 22:18 UTC#712
Hi!
What´s files I need for update bluetooth in F930BT??
Thank.
Posted Mar 21, 2016 · 11:56 UTC#713
Hi!
Thank.
Only the folder with Bluetooth. The device will find it if you copy the folder to root and go to update.
Regards
Posted Mar 27, 2016 · 19:51 UTC#714
Hi folks, late to the party! does anyone have a working link for map update for my f9210, only working link i can find has a non working zip file, I already have password.
thanx.
Posted Mar 27, 2016 · 19:57 UTC#715
Regards
Sorry, Where´s the folder with bluetooth?
Thank.
Edited Mar 27, 2016 by jaog2003
Posted Mar 30, 2016 · 14:52 UTC#716
thanx.
Try link from Blakestones post #656 and password from #679. Worked like a charm on my F9220BT :-).
And a big thanks to all who have contributed in this post and forum, you guys have helped med a lot!
Posted Apr 02, 2016 · 00:14 UTC#717
Files deletet
why delete this when we paid for it
Posted Apr 02, 2016 · 00:25 UTC#718
Like I said, you don't have to do any thing like copying files into folders... just put the folders and file from the zip onto your sd card as they are.
I don't know anything about the TTS files as I didn't use them, so you'll have to read the forums to figure that out.
lets hope flomsen dont delete this hole page in thisforum is there a way to save all these 700- 800 posts very usefull info here
Posted Apr 02, 2016 · 00:47 UTC#719
Here is the VERINFO.DAT file
hi thanx u saved me to
but in my alldata.htm file is also zero bytes, is this right
Posted Apr 02, 2016 · 01:13 UTC#720
It isn't zero length on mine (2015 US/CAN). Not sure if it matters. Just a text file in html format.  Here's mine for the Z140:
<html><head><title> Navigation Data </title></head><body bgcolor="#ffffff" text="#000000"><pre>
[Navigation All Data Record]
Product         : T1000-23348
DataType        : All Data
BulidTime       : 2015/04/20   11:29:22
Release Version : 06.000000
</pre> </body> </html>
For the Z120 the Product tag and BuildTime are different:
Product : T1000-23346
DataType : All Data
BulidTime : 2015/04/16 17:45:29
Don't know what your's is. Probably only the Product tag is important.
Edited Apr 02, 2016 by RonS
Posted Apr 03, 2016 · 01:03 UTC#721
Hi mate!
You will find everything you need here. Italian language is included in additional TTS zipped file.
this never works for me
i even paid flomsen for this and the guy never answers not cool i even have a recipt
Posted Apr 03, 2016 · 01:04 UTC#722
where else is the download i can not download it breaks at 52 percent all the time is it anywere else with the password
i have the original fils he gave me but the password not working ever
Posted Apr 09, 2016 · 08:35 UTC#723
were do i put the maps
Posted Apr 09, 2016 · 08:50 UTC#724
DataType        : All Data
DataType : All Data
i was wondering were does the maps rar go in the sd card what folder
Posted Apr 12, 2016 · 07:13 UTC#725
Files deletet in first post?? i can't dl the file.
Page 29 of 32
