2015 European Map Update for Pioneer AVIC-F30BT, F930BT, F9310BT, F40BT, F940BT, F840BT, F8430BT
By Flomsen · Aug 16, 2015in Hacks/Mods💬 789 posts👁️ 337,085 views
Page 30 of 32
Posted Apr 14, 2016 · 15:59 UTC#726
Hi I hope someone can help me I have a F30BT
I downloaded the file copied into the sd but not part of the upgrade.
The problem is definitely on VERINFO.DAT and cardinfo file.
someone could give me the files?
Sorry for my English
Posted Apr 15, 2016 · 20:39 UTC#727
There is no one ? please help me...
Posted Apr 22, 2016 · 10:47 UTC#728
AVIC-F840BT with some 2012 firmware updated to 2015.
I took the files and PW from post #336820 put on fresh SD-card,
card in navi,
turn on,
choose 'yes' to update,
waited approx. 20 minutes for the update to finish.
No further hacks needed, worked smooth - thank you clever guys in this forum. :)
Sounds easy, right? It was, when I finally succeeded, but I had to read like a million posts about different revisions of maps for different units, different versions of testmode, editing dll-files, cardinfo, verinfo and what not, it actually took me a full night until I figured it all out - and then it only took about 30 minutes, and voila! This forum is full of information, and it takes a good portion of patience to deduct the core of what you actually need.
Posted Apr 22, 2016 · 14:59 UTC#729
Just to be sure :) ,
For my F930BT all i have to do is put the files from "2015_European_Map_Updat_for_Pioneer.zip" to a sd and put in in my F930BT?
No need to use supertestmode or something like that?
Do i have to make a backup before updating? and how can i do that?
Edited Apr 22, 2016 by ruud660
Posted Apr 22, 2016 · 15:51 UTC#730
I read all the pages but I can not start the update of the F30BT
with copied to sd files as well as download does not start I tried to replace VERINFO.DAT and cardinfo part of 2013 but came to 100 tells me that's not good for my F30BT.
Can anyone let me have those two files please.
Posted Apr 23, 2016 · 12:08 UTC#731
Hi,
That was what I did on F840BT (FIRMWARE, UPDATE and CARDINFO.cif should be in the root of a fresh FAT32-formatted SD card).
According to this post it should also work with F930BT.
Best guess: No. :)
Sorry, I don't know about backup.. I didn't do it...
If you want to do so, I guess that you need to enter testmode in order to copy contents from the unit, but someone else might have a better answer for that.
koks
Posted Apr 23, 2016 · 20:07 UTC#732
Someone is kind enough to help me?
No one to my own model?
No one knows where to find everything you need?
Posted Apr 30, 2016 · 04:30 UTC#733
No one can help me?
Posted May 06, 2016 · 16:17 UTC#734
Nobody has these files?
Posted May 08, 2016 · 10:33 UTC#735
Hello. With all the files on the sd, do i need to enter a password before the update procedure starts?
Thanks.
Posted May 16, 2016 · 12:38 UTC#737
Upgrading my F940BT was very straightforward.
No PW, no Hexediting
just copy the folders UPDATE, FIRMWARE and the file CARDINFO.cif to an empty SD card and udating will take about 25 min.
How do I use this file 'Germany_HERE_2014.Q3_141210.poi' ?
Posted May 16, 2016 · 13:01 UTC#738
where can i get the download link ? :)
Posted May 26, 2016 · 08:57 UTC#739
Hi all,
I'm back!!! Sorry I was over 15 Months on the way and had not time. I have already tried all the descriptions to update my F20BT but it always fails, as usual a new SD Card fully formated copied the whole files Firmwar, Update (With Verinfo.DAT) the modified CARDINF.CIF not success. I have also modified the .ddl file with no success.
I have downloaded the files were offered in the first mail with the patched .DAT and modified .CIF
After update I got "An error has occured and the update has failed" I can then repeat the update and it won't go out of this loop.
I have also tried to go back to 2013 and at the end after 99% I get the same error. Any suggestion?
Thanks in Advanced for any help
Edited May 26, 2016 by Travolta
Posted May 26, 2016 · 19:01 UTC#740
After a lot of testing and trying I have the 2013 working again. I will test the 2015 again and let you know.
For other who has the issue with " Wrong SD Card or insert SD Card"..... Please boot into test mode and go to the option to write the firmware (Before you have to copy the folder from the 2015 firmware, update/user/ copy the PRG folder and rename it to ((AVICZ110)) put it to the root of sd and copy the testkey to the root, then choose from SD and rewrite all positions then reset the user settings.
Reboot and it will say no available application program. Boot again to test mode and write the firmware without resetting the settings, do a .dll replacement from Pionara and insert the 2013 update SD Card, then reboot, it will update back to 2013.
This is the solution to all ppl who has the error with no application program.
Regards
Posted May 26, 2016 · 19:35 UTC#741
I can confirm the firmware is working on my F20BT after all modifications. I have now version 6.0
Posted Jun 15, 2016 · 20:03 UTC#742
Hi guys, so have pioneer avic 9220bt and with that update have problems too. Last tried update was with error (broken file) tested 2x and 2 another sd cards.
Can some up that update please?
Posted Jun 25, 2016 · 11:26 UTC#743
Hello Jimmibondy
You have take the Files from guizmo/spijun ,put it on the sd card and it goes without anything to do on the files??
My F940bt is, with no updates, from 2012.
CU
Digger500
Posted Jun 29, 2016 · 05:08 UTC#744
I updated a F9310BT from 3.0 to this 6.0.
Hey, I am new here.
I have also 9310 with 3.0 version (old). Can You confirm how You did upgrade? Was it according to manual given here? Which files you modified? (Cardinfo.cif and verinfo.dat). Just to ease my operation. THX
Posted Jun 29, 2016 · 05:15 UTC#745
Hey Guys,
Any idea if this update will work on AVIC-F3210, according to original update info it should be folder: T1000-23350, but I think here we have T1000-23347, so there is some difference. I suppose that update (map) is the same, but I am not sure of this. Did anybody try to do update on F3210??? If Yes please respond. THX
Posted Jul 01, 2016 · 05:20 UTC#746
I have the F930BT with the old 2011 firmware ,  and tried the 2015 update , but it failed , incorrect sd card notification , after a lot of research succeeded installing the 2013 version. Does anyone know if you have to upgrade first to 2013 in order to make the 2015 update?.
I would like to have the 2015 update but am a little afraid i might brick the system again.
It's a bit confusing here because most of the topics are old and or the links are dead , and most of the members English grammar isn't that great...
Edited Jul 01, 2016 by pojjo73
Posted Jul 01, 2016 · 14:03 UTC#747
Has anyone had any luck with removing the 'nag' in this software version?
Cheers,
Paul
Posted Jul 07, 2016 · 14:17 UTC#748
Hi,
Someone help me to find this file? the
Posted Jul 07, 2016 · 17:06 UTC#749
I got the F20BT, butI read that it could be used with the right files. Right?
But I got none :sad: either the main file or the ones for F20BT....
Posted Jul 13, 2016 · 16:07 UTC#750
I updated my F920BT about 4 months ago and the update went down fine. New maps show the new Street in my neighborhood, so that's fine. But there's one right now major concern: I can't get it in night mode anymore. In the menu there's only the choice between day and automatic but when I put it in Auto it will still remain in day mode. And at night the screen is really bright.
Somewhere in the middle of this thread someone had the same problem and he seems to have solved it somehow. But he didn't say how. I already wrote a PN but I'm not sure if I will get an answer.
Did anyone have the same problem and/or knows a solution?
Regards
Alex
Page 30 of 32
