Skip warning on 2015 EU Update?
By osiris · Aug 29, 2015in Hacks/Mods💬 35 posts👁️ 9,986 views
Page 1 of 2
Posted Aug 29, 2015 · 16:27 UTC#1
Is there a way to skip the warning at startup for the 2015 EU Version (6.0) ?
Posted Sep 03, 2015 · 09:08 UTC#2
have u tested with the navi.exe of the 2013 version?
Posted Sep 03, 2015 · 09:21 UTC#3
Did you?
Posted Sep 04, 2015 · 11:10 UTC#4
Did you?
I didn't becuase at the moment I haven't intalled the new map version (2015).
U can try it easy and if doesn't work u can return again with the testmode.
Tell us ;)
Posted Sep 04, 2015 · 17:10 UTC#5
NAVI.exe from 2013 for skip warning works fine in 2015 as well.
Only remove NAVI.exe from USER\PRG0\APL in your 2015 version and copy the NAVI.exe (pionnara mod version for 2013 version).
Hope  help u
BT,
Posted Sep 04, 2015 · 20:56 UTC#6
Thx, can´t test it before sunday :(
Posted Sep 05, 2015 · 09:23 UTC#7
Its not working on my f930bt 2015 maps.
I still get warning ad startup.
Posted Sep 05, 2015 · 12:52 UTC#8
try in USER\PRG1\APL
i think prg1 is your active version. you could take a look at the EU090APL.HTM file in the folder. 2015 version is 6.000000
Posted Sep 06, 2015 · 08:43 UTC#9
I first change 05 00 00 0A -> 00 00 A0 E1 in my navi.exe in user/prg0/apl. Still nag.
Downloaded the old modified navi.exe. Still nag.
Will try it in prg1
Posted Sep 06, 2015 · 15:18 UTC#10
Will try it in prg1
it worked!!
Posted Sep 06, 2015 · 16:00 UTC#11
Did you only changed prg1? Or both?
Posted Sep 06, 2015 · 17:38 UTC#12
Did put back the orginal navi.exe in prg0, and the put modded navi.exe in prg1.
Posted Sep 06, 2015 · 19:25 UTC#13
I'm curious how the unit knows that there is an update available.
Posted Sep 06, 2015 · 20:32 UTC#14
if USER\PRG.FLG file exists you have to patch USER\PRG1\APL\Navi.exe.
Hex edit navi.exe 6.0 @ offset BEC64 0500000A -> 0000A0E1
Posted Sep 07, 2015 · 18:40 UTC#15
Thats it?
Edit navi.exe from prg1 if user/prg.flg exists?
Posted Sep 07, 2015 · 19:14 UTC#16
nvm, its working.
Changed only on prg1 because i have user/prg.flg
Posted Sep 14, 2015 · 20:36 UTC#17
Hello, i tried the modification without having the file "user/prg.flg". Unfortunatelly, it doesn't work.
Is there an other way to fix correctly the Navi.exe file? or do you know how i can generate this famous "user/prg.flg"?
thank you in advance. I have update my F930BT with 2015 Maps.
Posted Sep 15, 2015 · 05:12 UTC#18
Hİİ
Posted Sep 15, 2015 · 15:08 UTC#19
if USER\PRG.FLG file exists you have to patch USER\PRG1\APL\Navi.exe or else you have to patch USER\PRG0\APL\Navi.exe
Posted Sep 17, 2015 · 19:06 UTC#20
thank you corvus, i did it but "USER\PRG.FLG" does not exist.
Posted Sep 23, 2015 · 08:20 UTC#21
Hi,
I can confirm that the old navi.exe (provided as a rar file in this forum) works on a patched F930BT with Map 2015 update.- It removes the nagging warning screen when going to navigation mode.
Thanks to this forum.
I like.
What I now would appreciate is an update of the speedcams (internally, not on SD card).
Posted Sep 23, 2015 · 13:28 UTC#22
Hi chaps,
Can you point me in the right direction of the 2013 nag bypass thread? I've found another thread with a link but the link is dead and no amount of massaging the URL seems to coax a live thread.
Thanks in advance,
Paul
Posted Sep 23, 2015 · 18:19 UTC#23
Hi,
I downloaded and tried that old navi.exe, and it worked for me to,
but when I checked the file, I found out that it has to be navi.exe file from ver 4.01 or something.
I diddent want to have that so I checked the 6.0 file.
After som fiddling I found the offset to change.
Posted Sep 24, 2015 · 10:48 UTC#24
This is really easy to do yourself.
Open your navi.exe 6.0 file in HxD hex editor (tiny program)
Browse down to offset bec64. Change 0500000A -> 0000A0E1.
Save file on sd.
Put testmode.key on sd and fire up your device.
if USER\PRG.FLG file exists you have to swop USER\PRG1\APL\Navi.exe or else you have to swop USER\PRG0\APL\Navi.exe
Remember to delete the navi.exe on device before you start copy it from sd because testmode.key dossent suport overwrite.
The you copy navi.exe from sd to device.
No more nag, and you the latest ver off navi.exe.
Posted Sep 27, 2015 · 17:18 UTC#25
It worked perfect for my F840BT. I had to change USER\PRG1\APL\Navi.exe in my case. No mor nag. Thanks!
Page 1 of 2
