Skip warning on 2015 EU Update?
By osiris · Aug 29, 2015in Hacks/Mods💬 35 posts👁️ 9,986 views
Page 2 of 2
Posted Nov 07, 2015 · 15:14 UTC#26
Worked like a charm on F940BT. Thank you very much
Posted Dec 31, 2015 · 13:48 UTC#27
HI,
bit confused, can't seem to be able to locate BEC64 in navi.exe in PRG1 or PRG0, am I missing something ( F-30bt) with 2015 maps.
cheers
Posted Jan 04, 2016 · 20:40 UTC#28
HI,
cheers
To find the rigth offset if your not familiar with hex can be confusing.
Locate offset 000BEC60. On that row in column 4 you find offset 000BEC64. Column 4 starts with 05, column 5 with 00 and so on.
Or use the search, goto function. Punch in 000bec64...
Posted Jan 05, 2016 · 21:12 UTC#29
Perfect,.  thanks! What a noob! :)  the code was different in PRG0, but looked right in PRG1, so will look to copy that, and hope it works!
Edit: Works perfectly, many thanks again!
Edited Jan 05, 2016 by giblets46
Posted Jan 28, 2016 · 15:38 UTC#30
Hi All!
Just a quick one.
Is it possible to replace original "Navi.exe" with edited one and then run the 2015 update? Or AVIC will detect the change?
I just thought that it would be more convenient to replace exe file on SD card before the update, rather than struggle with copy/paste after the update?
Thanks.
Best Regards,
Alex.
Posted Jan 28, 2016 · 18:35 UTC#31
Hi All!
Just a quick one.
Thanks.
Best Regards,
Alex.
Don't ever change any files on the original upgrade unless you are told to. The files to be installed are listed in a manifest file along with their CRC values. If the file has changed,   the installation will not work and leave you in an ugly state.
Posted Jan 29, 2016 · 07:03 UTC#32
Thanks mate! I will modify .exe file after the update.
Posted Feb 21, 2016 · 15:49 UTC#33
Cheers guys.  Works like a charm.  I was having issues with the touch screen losing its calibration and not being able to do anything (like recalibrate) until the OK button was pressed.  Now there is no button to press... yay!
Posted Feb 21, 2016 · 18:32 UTC#34
This is working with F70DAB?
Thank you
Posted Nov 26, 2016 · 16:21 UTC#35
Worked like a charm on my F940BT Version 6. Thx Corvus for the good explanation!! :smile:
Now i just need to find How to get safemode activated to get rid of the brake issue (physical move of the mute wire doesn't work) and also find where to insert speedcam files to have them on the map and hear them !
Edited Nov 27, 2016 by treker
Page 2 of 2
