Thanks RonS I have a Z120 so I guess I can't use that. I guess ill have to wait until someone cracks it and shares it here.
2015 Avic Z120 map update
THE LINKS FOR THIS 2015 AVIC Z120BT MAP UPDATE ARE BROKEN...CAN ANYONE REPOST WITH A WORKING DOWNLOAD LINK PLEASE?
THANK YOU!
This seems more complicated than it is because there are two different AVIC series that use this upgrade: Z-series (Z110/120/130/140) and X-series (x920/930/940). Each series has its own forum. Most of us have been reading both forums ( plus the F-series one) since the knowledge needed is spread out and it is a common solution. To complicate it even more, there are two different sets of files for the US/CAN 2015 upgrade. One set only works with the older units (Z110, Z120, x920) and the other works with newer units (z130, z140, x930, x940).
With previous upgrades (normally released annually) we only needed one set of files (UPDATE, FIRMWARE directories) and only needed to place on the SD the CardInfo.CIF file for the older or newer units. For some reason that didn't work this year. Many of the UPDATE files differ between the older and newer units. I still don't understand why.
Keep in mind that you are reading a thread in the Hacks sub-forum which is a work-in-progress - not a how-to procedure. It presumes a certain level of expertise. However it seems that the messy details have finally been sorted-out. We now have a very simple process which only requires a little knowledge on using your computer - basically how to download, extract the compressed files, and copy them onto your installation SD.
Unfortunately links to files sometimes get stale. They all do eventually. For the time being, get your files here:
- z110bt, z120bt, x920Bt - older units update: stale link. Get "newer units" file below then see post #140
- z130bt, z140bh, x930bt, x940bt - newer units
Then extract the files, copy UPDATE, FIRMWARE, and CardInfo.CIF to the root of a freshly formatted FAT32 SD, and insert it into your unit.
Hi, So i did all that RonS mentioned and I did manage to update the firmware of my bluetooth and I thought I update the firmware of my device but after double checking it appears that I still run 3.0 version and yes I am running 3.32 bluetooth. What happened here? lol does the file updates the bluetooth firmware but not the device?
I did all of this on my x930bt unit.
Thanks in advance!
Thanks in advance!
No idea what went wrong. Not gonna waste any time thinking about it since this is old software. Try installing the 2017 version. Just run the ShortFuse script first.
No problem! I understand, Thank you!
PD. I searched but i couldn't fine the 2017 version in the forum..
Yeah, its hard to find since its right at the top. 2017 v7 US/Can Update available for Z110/120/130/140,X920/930/940
