IGO Nextgen 9.19.5.584533 - Is it possible to port?
By weresgyufa · Mar 22, 2016in Hacks/Mods💬 34 posts👁️ 31,482 views
Page 2 of 2
Posted Nov 06, 2016 · 15:28 UTC#26
Hallo weresgyufa mine also working but has no screen and Kajoe does n=ot know an solution do you have one.
Greetings Fred
Hi, what is this means? Can u share a picture what do you see?
Stock navi is Working? What ani issues you have?
Posted Nov 07, 2016 · 13:10 UTC#27
I can't find the one anymore, but can I ask you how quick it is starting mine takes several minutes and stops with the picture what is in the mail.
Posted Nov 07, 2016 · 15:27 UTC#28
Jesus :) This is normal, the AVIC NET does this, because the start screen is this. This is because if you drive @ night, then this splash screen won't burn out your eyes :)
If you hit the button on the "Kaart" then the normal "stock" map appears.
If you push menu button then the stock menu splash appears = Avicnet, Contact, Audio if i remember...
If you push long the MENU button then NEXTGEN starts.
If you push long MAP button, then backgroung light adjust comes in.
So, i hope i helped with this, but this is not a BUG, this is a feature.
BR
Posted Nov 07, 2016 · 15:39 UTC#29
Oke thanks for the explanation
Posted Nov 07, 2016 · 15:51 UTC#30
YW. so don't be afraid, this is normal, and i think if you read the AVIC Net topic this can change back, only some file needs to modify i think...
Edited Nov 08, 2016 by weresgyufa
Posted Jan 17, 2017 · 21:06 UTC#31
I tried to make a nextgen version for F900BT again. Maybe you can test it. Follow there instructions. Download link below. I have changed some files and now it is for European devices F900BT. Test it and let me know.
I only made it for Dutch. So TTS files and voices are only for Dutch and English.
I am not responsible when you brick your unit.
Installation Instructions
1) Back up your unit! Copy the entire "My Flash Disk" onto a SD card and keep it in a safe place.
2) Ensure you are running Windows CE version 5.0 or above. You can check this by booting into testmode, going to the control panel and tapping on system. It will tell you your CE version there.
3) Download the file. Extract, copy to a SD card.
4) Delete "My Flash Disk" on your unit from testmode.
5) Copy "My Flash Disk" from your SD card to your unit.
7) You have to copy maps/ POI etc to the folder in iGO/ Content. Do NOT copy them in Primo3/ Content
6) Reboot. Your unit will auto reboot once more to initiallize AVICnet.
If GPS cannot be found, change port in sys.txt to GPS port of your device. And go to \My Flash Disk\User\UserData\iGo\SAVE folder and delete the SAVE folder.
Hello~.
I have done everything you said but iGo won't open.
When I press to open it, the screen turns black and apperas "Please wait. Loading" Then it goes back to the main menu. If I press to open it again it repeats the process and never opens the iGO Nextgen.
What is the problem?
Thanks in advance.
Posted Jul 31, 2017 · 07:07 UTC#32
Hi,
Is there a new working version? If yes can somebody please share the flashdisk with avicnet and working Igo Primo 2.4 and Igo Primo NextGen? Would be awesome.
Posted Sep 21, 2017 · 20:50 UTC#33
Support that.. and can someone tell me if there is a version for a F930BT ?
Thanks..
Posted Jan 05, 2020 · 15:35 UTC#34
Hi there. There is another version, i have made a try and it is running too, I only have issues with TTS or TTS PRO, they are still not working, TMC I thing not but I can't test it fully.
Page 2 of 2
