Does this update also work voor the F30BT?
It should. You'll need the right CARDINFO.CIF file. Maybe just skip step 4. If the CARDINFO file doesn't match your model, nothing will happen when you insert the SD.
Hi
The update ran up to 51% followed by a message about an invalid SD card.
What to do next - because the radio does not work ![]()
I have Avic F9220DT
Hi
I have Avic F9220DT
Use 4GB SD. Format & test for errors before putting all the files as in the instructions.
Hi
I have Avic F9220DT
Why are you installing the 2015 maps when the 2017 are available?
To recover the use of your AVIC unit:
this will kick the unit out of upgrade mode, and should restart into regular mode on next power up (remember to remove the TestMode SD).
Hey guys. 2017 maps are here for F10/F20/F920/F9210/F9220BT. Here's a quick guide for installing successfully.
1. Format a SD card (4-8GB) in FAT32
2. Download this file, unzip contents and move to the root of SD. This the ShortFuse hack to overcome registration for personalized password.
3. Insert in your Pioneer and follow on-screen instructions
4. When finished move the SD contents back to your PC. It includes backup files in case of issue (but you will have no issues if you pay attention to all the details).
5. Delete all contents of SD, or format again
6. Download maps from here
7. Unzip using password 'Dracarys' exactly as you see it, including the single quotes. Copy-paste to be sure!!
8. Move all map contents to the root of SD
9. Download and replace this file in the root of SD. This is the proper CARDINFO.cif file for F10/F20/F920/F9210/F9220BT family.
10. Insert SD in Pioneer, follow on-screen instructions and enter PASSWORDPASSWORD when prompted for a password
11. Be patient for 25 minutes, then go for a ride and enjoy!
Why are you posting this here and an identical one in the 2017 thread? You aren't adding any new information. There's already a 2017 thread with detailed instructions. And there seems to be dozens of people posting their own instruction summaries.The problem with posting summarized instructions is - while they might make sense to experienced people - they leave out details. I'm probably going to clean-up and delete many of those posts unless they add value to the discussion.
