Backups and Images
By Pilotgirlie · Sep 09, 2016in NEX Series💬 358 posts👁️ 182,362 views
Page 5 of 15
Posted Apr 20, 2020 · 18:30 UTC#101
On 3/21/2020 at 4:34 PM, vasili_84 said:
https://mega.nz/#F!ezY1FYhb!ued2oydxeZula3ZTm6p1ng
Hallo,reloaded link check update
Will one of these fix the update error im getting on my avic-8000nex?
It won't take to any update no matter which USB stick I try.
Edited Apr 20, 2020 by KyleMonroe — Reason: Grammatical errors.
Posted May 21, 2020 · 03:46 UTC#103
On 4/16/2020 at 5:23 PM, T-ROCV said:
I need one for an AVH-4200NEX unit.. stuck in boot loop and needs the image.
Was anyone able to find the image for AVH-4200NEX?
Posted Jun 03, 2020 · 08:46 UTC#104
Hi
im searching for an AVIC Z920DAB or W8500NEX image.
can someone help me?
Edited Jun 05, 2020 by enigmaphone
Posted Jun 15, 2020 · 18:05 UTC#105
Please add AVH-Z9150BT Please. My deck is deaded today. It show Loading...
Posted Jun 16, 2020 · 06:28 UTC#107
On 4/28/2020 at 2:47 PM, vasili_84 said:
Reloaded link added the image of avh x8800Bt thanks Vladonius from a neighboring forum.
https://mega.nz/folder/46ISTKAC#JGj_lJWtP2LvLD1GuaQ8zA
image added avic F970Bt
Can you reup x8800bt? it is show me error when extract. Thaks you
And what is the password unrar for:  AVIC_F860 (F60)
Edited Jun 16, 2020 by Hoangnova
Posted Jun 29, 2020 · 11:19 UTC#110
Hey, I have F970Bt Indian version with internal SD card of 8GB.
This file, when extracted, the file is 16gb.
Can anyone help me with F970 BT 8GB image? thankyou
Posted Jul 20, 2020 · 03:32 UTC#112
do you know what format? cuz that 4400nex sd card backup is bigger than 4gb.  and fat32 only supports upto 4gb single file transfer.
Posted Jul 20, 2020 · 15:22 UTC#113
On 6/15/2020 at 7:39 PM, brazen1445 said:
Pioneer AVH-W4400NEX, firmware version 1.02
Internal SD card backup: https://mega.nz/file/SdJCgKCJ#13zrFlogMCWNohCvuFsDFcC1uniHgufVZJxZlQPHUag
I tried imaging this, but my pioneer unit said this was an AVIC-W8400 software image. Is there anyway you or anyone can DM me either a Pioneer AVH-W4500NEX or a AVH-W4400NEX image file please? I have the former, but the 4400 should work as well.
Edited Jul 21, 2020 by antoshka
Posted Jul 23, 2020 · 17:42 UTC#114
This is an image of the internal sd card of a AVH-W4400NEX. You will need to dissemble the unit to access the card. It is android based receiver so will have a android partition layout.  If you try to copy it to a fat32 formatted card it will fail.
To write the image to a sd card:
1. download zip and extract the img somewhere
I extracted the image to /tmp/AVIC.img
2. find the device name of your sd card
sudo fdisk -l
Take note of how the SD card is identified.
In my case it is /dev/mmcblk0
3. Write the image to the sd card
dd if=/tmp/AVIC.img of=/dev/mmcblk0 bs=1048576
4. insert the card into the receiver and your done
Posted Jul 24, 2020 · 12:47 UTC#115
that's odd. I used that one on my 4400 and it worked fine. Initially it didn't though, it was either my microsd card or the adapter that the radio didn't like.
I tried a new card and a new samsung adapter, went to disk manager and removed all partitions and created a new simple volume, formatted to ext3 (probably not necessary)
then ran the image with win32 disk imager.
put it in stereo, put everything back together and threw it in the truck, got the nex screen and then loading, and bam, software was up and running.
It was TONS faster with a better sd card. It took probably 4 or 5 seconds to boot up.
Anyway, the image he posted does work on 4400.
Posted Jul 24, 2020 · 14:40 UTC#116
I am figuring my error is most likely caused by me. I'm on a mac and have to use Balena instead of win32.
Initially when I put it in the radio did boot up but the touch screen wouldn't work and when I looked up CarPlay or bluetooth on my phone it came up as AVIC-W8400.
I think I'll give it another go with a different SD card.
Posted Jul 24, 2020 · 19:22 UTC#117
If anyone has an AVH-W4500 image, I would greatly appreciate it.
Posted Aug 13, 2020 · 12:23 UTC#118
how can I format/erase my SD card in the unit ?
I want it to be readed in my pc after that.
thanks for the help
Posted Aug 31, 2020 · 03:42 UTC#119
I second this. w4500 needed thnx
Posted Aug 31, 2020 · 19:20 UTC#120
On 28.04.2020 at 10:47, vasili_84 said:
Yeniden yüklenen bağlantı  , komşu forumdan Vladonius sayesinde avh  x8800Bt'nin görüntüsünü ekledi .
görüntü eklendi avic F970Bt
Merhaba
avh-x8750 bt software error hatası verdi
yazılım konusuna yardım lütfen
Posted Sep 07, 2020 · 17:58 UTC#121
sudo fdisk -l
Followed these exact instructions 4 times and I can't get it to work. Are we sure this image is still valid?
Posted Sep 20, 2020 · 19:00 UTC#122
Hallo, yeniden yüklenen bağlantı kontrolü güncellemesi
Hi avh-x8750bt software down Can I get help with the backup image?
Posted Sep 22, 2020 · 03:40 UTC#123
Hi
First of all, I would like to thank you very much!
I have 1 Pioneer AVH-Z9150BT
it just shows logo and loading
Do you have files.img for me to download
Thank you very much!
Posted Sep 30, 2020 · 09:07 UTC#124
HELP ME ! PLEASE !
THANKS FOR ALL!
Posted Oct 12, 2020 · 18:49 UTC#125
sudo fdisk -l
I attempted this on a windows computer using WIN32 disk imager and head unit boots but there is no response from the touch screen. Any recommendations?
Page 5 of 15
