Backups and Images
By Pilotgirlie · Sep 09, 2016in NEX Series💬 358 posts👁️ 182,362 views
Page 7 of 15
Posted Feb 02, 2021 · 15:52 UTC#151
On 1/24/2021 at 7:05 AM, GettinOld said:
I see a few responded but if you would be able to help me step by step that would be great. Then I’d be able to help otherwise that are in need of a functional 4500 image.  Cheers!
Shoot me an email and I'm happy to help: [email protected]
Edited Feb 02, 2021 by strength
Posted Feb 24, 2021 · 19:50 UTC#152
On 1/21/2021 at 7:54 PM, ruszip1 said:
I know a few people had unresponsive touchscreens,  I did too on mine using the 4400 file.
hey, did you ever get that image file for the 4500. The touchscreen didnt work on mine with the 4400 image. please post thanks in advance.
Posted Feb 26, 2021 · 13:54 UTC#153
Does anyone have a back up image for a Avic-7200 NEX? It is stuck in a reboot loop
Posted Mar 08, 2021 · 11:17 UTC#154
Does anyone have or know what will work with an AVH-Z9150BT (Australia)?
Posted Mar 11, 2021 · 04:20 UTC#155
On 3/9/2020 at 1:15 PM, ThaiBO said:
Did you get the image file? I need it too. Thanks
Still looking. How about you? Thanks
Posted Mar 11, 2021 · 14:55 UTC#156
Hi Avic families,
I am looking for the image file for the 5000NEX. I want to replace my memory card for a higher and better one.
if you do have it. Can you please send it my way.
Thank you in advance
Posted Mar 14, 2021 · 23:09 UTC#157
Anyone have a SD card image for AVIC-5201NEX? Mine is in boot loop.
Posted Mar 16, 2021 · 21:19 UTC#158
pretty sure 5201 takes the same as the 5200.. just usew that image
Posted Mar 16, 2021 · 23:20 UTC#159
touch panel wont work with 5200
Posted Mar 24, 2021 · 23:25 UTC#160
Is the AVHtoAVIC on eBay just a standard avic-w8500nex image or is it custom?
Posted Mar 24, 2021 · 23:44 UTC#161
custom.
Edited Mar 24, 2021 by bonee
Posted Mar 25, 2021 · 00:06 UTC#162
21 minutes ago, bonee said:
custom.
How would I update the maps?
Posted Mar 25, 2021 · 00:28 UTC#163
same way as normal.
Posted Mar 31, 2021 · 20:38 UTC#164
Anyone have the nex4000 firmware?
Posted Apr 01, 2021 · 02:08 UTC#166
On 1/18/2021 at 8:44 PM, ruszip1 said:
Hey, so I got the sd card for my avh w4500nex from Russia. Again, I had 2 of these radios, one crapped out but the other worked.  So I have a WORKING SD CARD for a AVH W4500 NEX. I will mail it to you, only one condition, It needs to be one of the people that can get this image out to the rest that need it. I don't have a clue how to get it able to backup. I tried the instructions, couldn't get it to do anything with the test files and all that. Maybe I wasn't holding my tongue right or something.  I will hold on to it. Maybe someone will respond. Send me a message.
Were you able to find someone to help and post an image file?  thanks
Posted Apr 02, 2021 · 01:44 UTC#167
Hi Guys, Can someone help me, I've expanded everything. But I can't find the image for the 8600BT model .. Can you download it here? And with what do I open these files? I hope someone can help me .. The device is brand new, it was around with me for 2 years and the first start and this mistake I'm really pissed off and disappointed.
Edited Apr 02, 2021 by francesco
Posted Apr 02, 2021 · 15:16 UTC#168
Hi Everyone,
I am new to this group and my Pioneer AVH-X8700BT is stuck on the loading screen during startup. I have managed to remove the internal SD Card and was hoping if someone could share with me the image file for my stereo?
I am not sure if i need any other files to get my system running again so would appreciate any other files/details for the SD CARD as i have never had this issue before.
Edited Apr 02, 2021 by Mr-knight
Posted Apr 02, 2021 · 15:24 UTC#169
On 4/28/2020 at 8:47 AM, vasili_84 said:
Reloaded link added the image of avh x8800Bt thanks Vladonius from a neighboring forum.
https://mega.nz/folder/46ISTKAC#JGj_lJWtP2LvLD1GuaQ8zA
image added avic F970Bt
Hi Buddy, Would you possibly have the files for an AVH-X8700BT? I will be ever so grateful.
Many thanks
Posted Apr 24, 2021 · 16:03 UTC#170
On 01/04/2021 at 21:44, francesco said:
Salut les gars, quelqu'un peut-il m'aider, j'ai tout développé. Mais je ne trouve pas l'image du modèle 8600BT .. Pouvez-vous la télécharger ici? Et avec quoi ouvrir ces fichiers? J'espère que quelqu'un pourra m'aider .. L'appareil est tout neuf, il était avec moi depuis 2 ans et le premier départ et cette erreur je suis vraiment énervé et déçu.
bonjour a tous...
as tu trouvé l'image pr le 8600bt?
Posted Apr 25, 2021 · 21:42 UTC#171
On 7/23/2020 at 10:42 AM, brazen1445 said:
This is an image of the internal sd card of a AVH-W4400NEX. You will need to dissemble the unit to access the card. It is android based receiver so will have a android partition layout.  If you try to copy it to a fat32 formatted card it will fail.
To write the image to a sd card:
1. download zip and extract the img somewhere
I extracted the image to /tmp/AVIC.img
2. find the device name of your sd card
sudo fdisk -l
Take note of how the SD card is identified.
In my case it is /dev/mmcblk0
3. Write the image to the sd card
dd if=/tmp/AVIC.img of=/dev/mmcblk0 bs=1048576
4. insert the card into the receiver and your done
During an attempt to update my AVH-W4400nex from 1.01 to 1.02 it failed.
1st attempt was on a mac using balenaEtcher = software error
2nd attempt used a different SD card and windows / win32 it went to the updating 0.00 to 0.00 = fail / repeat on restart
3rd attempt: I followed these instructions with the AVIC.img (yet another SD card) on linux and now its at the "software error" page. Any ideas?
IMG_8060.HEIC IMG_8058.HEIC
Edited Apr 25, 2021 by DUNC4N — Reason: Added more information.
Posted Apr 29, 2021 · 19:22 UTC#172
I have a AVH-4200NEX image, I would like to share as I see so many need it, it’s just under 8GB, can someone suggest what’s the best way to upload it and to what service? I see many use Mega, is that the best option? And will it support me uploading an almost 8GB file?
Thanks!!
Posted Jun 10, 2021 · 03:00 UTC#173
Boa noite! Preciso da imagem do SD do AVIC-F960BT ou AVIC-5000NEX, alguém tem o link ou pode subir ele por gentileza?!!
Obrigado!!
Posted Jun 12, 2021 · 13:50 UTC#174
How's it going? I shot you an email. I just realized I put the wrong name in message. my fault.
Posted Jun 16, 2021 · 17:48 UTC#175
On 9/21/2020 at 10:40 PM, ptran said:
Hi
First of all, I would like to thank you very much!
I have 1 Pioneer AVH-Z9150BT
it just shows logo and loading
Do you have files.img for me to download
Thank you very much!
Hi, i have the same problem with AVH-Z9250BT, please help me i need the SO Image, thanks
Page 7 of 15
