I am in need of a AVH-4200NEX image. If someone has one, please post or pm me.
I ended up buying the firmware needed for my AVH-4200NEX on eBay. However, it was loaded on another cheap flash card. Unfortunately, I cannot find an ISO image for this model if it goes bad again.
Does anyone here know how to copy the file images from one compact flash (as source), onto another compact flash for backup using a PC?
Thanks for any help.
Good Morning!!!
I have a Pioneer AVH-Z9280TV device and the SD card is corrupted, could someone pass me the image to be able to record another SD card?
On 6/16/2020 at 12:39 AM, brazen1445 said:Pioneer AVH-W4400NEX, firmware version 1.02
Internal SD card backup: https://mega.nz/file/SdJCgKCJ#13zrFlogMCWNohCvuFsDFcC1uniHgufVZJxZlQPHUag
I used this in a AVH-Z9100DAB (European version of AVH-W4400NEX) and it worked perfectly. Thank you very much
If someone can procure a factory image for the w4500 I will pay $25. Please and thank you!
Can anyone provide the F9880bt-C Image file or backup?
Thanks for your help.
I have a problem with my AVIC-Z830DAB. Seems that something wrong with the internal SD-card. IGO - nav wont start, say can't find: global_cfg. I'l be happy if some can help me with internal SD-card img file for this unit or even bettet, instruction how to global_cfg back into the SD-card.
Great thanks for all help.
Reinstall the latest firmware
Hello, I'm in need of an AVIC-8100 image because of the boot loop. If anyone has that file and is willing to help, it would be most appreciated
Sorry, there is some firmware available for the AVIC-Z830DAB. I think firmware inc. IGO cannot fix this little problem. IGO SW. After checking carefully through the file manager, the folder: global.cfg \ global_cfg.zip is missing inside IGO \ content \. I need some help creating a small script to copy the folder: global.cfg \ global_cfg.zip (I have this folder and the file inside the old backup) back to IGO \ content \. Since I have updated all the maps, I do not want to put the old backup into the device, only global_cfg.zip.
So, a small script will be nice.
I need some help with software error on a avh-4000nex
I need the 4000nex can anybody help with ut
On 3/22/2019 at 3:09 PM, Dookie said:Anyone have the Backup image for the avic-7200nex?
Did you find? I need
Need an image for avic 5201 nex stuck in boot loop, any help would be much appreciated. [email protected]
I've been trying to find a copy of the 5201NEX SD back up as well. Please let me know if anyone has one. [email protected]
On 6/16/2020 at 1:55 PM, Hoangnova said:
Do you know the password of the .rar file but images downloaded from MEGA? tks
On 7/8/2021 at 7:57 PM, sofmeright said:If someone can procure a factory image for the w4500 I will pay $25. Please and thank you!
Same here!!!
On 10/20/2021 at 9:37 PM, Randym1020 said:Same here!!!
i need something to fix my 4500 too. stupid thing won’t forget my old phones and every time i add a new one now it wont auto connect. only works with the 2 that wont delete
On 11/7/2021 at 5:35 PM, biohazard said:i need something to fix my 4500 too. stupid thing won’t forget my old phones and every time i add a new one now it wont auto connect. only works with the 2 that wont delete
Same thing here. Pioneer will do nothing. Best Buy couldn’t figure it out. I tried clearing cache and everything. Can’t use wireless Bluetooth which is why I bought this model!
email me at: [email protected] to assist me!
I assume there has not been a 4500nex file uploaded yet. I’ve tried the 4400nex software. I have no touchscreen. I have an sd card on the way from eBay with the software that is suppose to work. Is there anyone that can guide me on how to copy the image in order to share it? My Mac doesn’t want to read the corrupt sd card.
On 1/10/2022 at 9:37 PM, Ryan9403 said:I assume there has not been a 4500nex file uploaded yet. I’ve tried the 4400nex software. I have no touchscreen. I have an sd card on the way from eBay with the software that is suppose to work. Is there anyone that can guide me on how to copy the image in order to share it? My Mac doesn’t want to read the corrupt sd card.
I would like to know if you get this card or not. I ordered it on October 5th and have yet to receive it.
The 4400 img file works on the 4500. You just need to update the sysd.config file. Change the 8500 from capacitator to resistance. You will need linux to access the image on the sd card.
For anyone who may be interested - I can confirm that the AVH-W4400NEX image works fine on my Australian AVH-Z9150BT.
Swapped out the SDCard today and it fixed my issues with my unit not being able to save settings. Everything is working perfectly now.
