I still have the image file but it is too big to upload directly to this message board. Try this Google Drive link.
https://drive.google.com/file/d/1FhhDuE2QdXU0mvF_G7n_8hURPUZ0Jb7R/view?usp=sharing
One thing to note with this file. I have a Maestro RR unit to integrate the factory steering wheel controls and get the OBDII data to the Pioneer head unit. After I used this image the iDatalink feature stopped working. I reached out to Auto Motive Data Solutions (ADS) tech support and got the following response:
I have seen this is a few times now and while you were able to swap the SD card that is only one part of the fixing your original issue, the other step requires Pioneer sync the embedded information from that SD card to the radio. The only way I have seen this done successfully is by sending the unit into Pioneer Warranty or an authorized Pioneer service center to complete this side. Once done you should be able to pull the new serial number on the radio flash the RR.
Justin Ferroni I Maestro Technical Support
Automotive Data Solutions Inc.
8400 rue Bougainville Montreal, Quebec H4P 2G1 Canada
T 514.807.2888
TF 866.427.2999
All the best...
Jeff
