Backups and Images
By Pilotgirlie · Sep 09, 2016in NEX Series💬 358 posts👁️ 182,362 views
Page 11 of 15
Posted Oct 24, 2022 · 18:01 UTC#251
what is the password of the rar
Posted Oct 24, 2022 · 18:21 UTC#252
On 5/2/2019 at 16:30, photo_mikeyy said:
¿Puedes enviarme un enlace?
Posted Nov 11, 2022 · 02:01 UTC#253
Anyone got a 9200DAB image? 4500nex works but have lost DAB AM/FM radio!
Posted Nov 11, 2022 · 06:34 UTC#254
Which 4500NEX image did you use?
Posted Nov 11, 2022 · 06:42 UTC#255
it was one from here, by user called honda something had a guide with a link to the sd image
Posted Nov 11, 2022 · 06:56 UTC#256
I’m pretty sure that’s a 4400 image because there isn’t a genuine 4500 image on here if there was though I think it would work perfectly with the Z9200DAB. I am also looking for the same as you.
Posted Nov 11, 2022 · 07:33 UTC#257
Not 100% sure says 4500nex in system info. thought maybe as 4500 has hd radio and 9200 is dab am/fm they change the hardware and the software changed to suit. using a 4400 image loses touch from what I've read. Most likely end up doing the avh2avic mod when I get hold of the guy that does them.
Posted Nov 11, 2022 · 19:13 UTC#258
There are at least 3 different versions with tuners
NA: radio (200Mhz step) + HD radio (built-in tuner) + SiriusXM tuner (external)
EU5: radio (step 50/100 MHz) + DAB tuner (built-in tuner)
UR\ASIA\BR\AU: Radio (50/100 MHz step)
For all versions of AVIC, a 2nd radio tuner is available, which is used in navigation for TMC (traffic)
PS version AVH-Z9x00DAB(EU5) was also sold in AU region.
there are also 3 versions with iDataLink(CanBus) port
only available in NA*\EU5**\UR*** regions.
But the software implementation is different.
NA-MaestroRR
EU5\UR - CAN adapter that displays climate\parking sensors
ASIA\BR\AU - no iDataLink\CanBUS
2 firmware versions available: AVH(8Gb) and AVIC(16Gb)
the difference is only in navigation.
In each firmware, configs are available for all models
firmware from AVH can be run on AVIC. The navigation icon in the main menu will be available, but the navigation will not work, as it is not in the firmware.
AVH2AVIC Version: This is firmware from AVIC-W8600NEX\AVIC-Z930DAB with corrected config for each AVH model.
+ update W4400=>W4500, W8400=>W8500, Z910=>920, Z9100=>Z9200
+WebLink
+ patch for access to the Debug Menu.
There are no differences between x500\x600, only model numbers
Navigation requires iGO activation
Activation is individual for each SD card
*NA - North America
**EU5 - European, also sold in Australia/New Zealand, AVH-Z9100/9200 models only
***UR - Russia
Posted Nov 18, 2022 · 01:57 UTC#259
Looks like there are some eBay sellers selling OEM SD cards for w4500nex. Cheaper than pacparts...if links aren't allowed, please delete. But can eBay search "OEM AVH-w4500NEX"
https://www.ebay.com/sch/i.html?_nkw=oem+avh-w4500nex
Posted Dec 15, 2022 · 04:23 UTC#261
Thank you so much!
I'll try it in my AVH-W4500NEX.
Posted Jan 08, 2023 · 14:10 UTC#262
Hello everybody
in mid-december I had to send my z9200dab for assistance due to problems with the SD card. Being under warranty, they fixed it with no problems. Today I extract the SD card to do a clone/backup without success. The PC does not detect the SD card. How can I fix this or how can I do this clone/backup?
On the Piooner website I found the FW update for the z9100.
If this FW is compatible with my z9200, how can I make it bootable?
thank you all and happy new year
Posted Jan 13, 2023 · 15:02 UTC#263
I purchased a Kenwood 9707s after my 4500NEX issues and it’s been as bad of a debacle/experience with my Mazda 6. Can’t use factory backup cam and volume on phone calls and even regular tuners are awful. I’m actually considering going back to a Pioneer wireless CarPlay like the DMH-W4660NEX. Does it have the software/SD card image issues like the AVH-4500NEX?
Posted Jan 13, 2023 · 18:39 UTC#264
Posted Jan 13, 2023 · 18:40 UTC#265
I believe it's a flash memory. So no SD card problem. But you also lose DVD drive.
Posted Jan 13, 2023 · 19:55 UTC#266
I lost the dvd/cd drive with the 9707s already.  But if it doesn’t die like the 4500, I may switch. It’s on sale at Best Buy as a Total Tech member. At least with the 4500 when it worked, I could listen to music at a decent level, use factory camera, and don’t have to max out volume on a phone call or get static on 1/3 of max volume. I know it’s partly a Bose Amp issue but way worse volume issues with Kenwood and factory Bose amp than Pioneer and factory Bose amp.
Posted Feb 01, 2023 · 19:44 UTC#267
Hello. Where can I get firmware for AVH-Z9200DAB?
I can't find it anywhere
Posted Feb 11, 2023 · 20:06 UTC#268
On 6/27/2019 at 2:29 AM, Zovering said:
Does anyone have the 6200nex files
Did you find this?
Posted Feb 24, 2023 · 12:25 UTC#269
On 4/28/2020 at 9:47 AM, vasili_84 said:
Reloaded link added the image of avh x8800Bt thanks Vladonius from a neighboring forum.
https://mega.nz/folder/46ISTKAC#JGj_lJWtP2LvLD1GuaQ8zA
image added avic F970Bt
I need the Password please. :/
Posted Mar 02, 2023 · 03:54 UTC#270
On 8/21/2022 at 9:42 AM, Datsun said:
In the configuration file of the software I got. It had multiple units in there. If I get the chance today I will look in there and see if the 4100 was in there.
@Datsun did you find avh-4100nex file in the config file or was it a bust?
Posted Mar 02, 2023 · 13:17 UTC#271
I did not. Here is the listing.
List of Units in sysd.conf part #QXX3352
Avh-w4400nex
Avh-z9100dab
Avh-z9100bt
Avh-z9150bt
Avh-z9190bt
Avh-z9180tv
Avic-w8400nex
Avic-z910dab
Avic-z810dab
Avic-w6400nex
Avic-z710dab
Avic-z610bt
Avh-w4500nex
Avh-z9200dab
Avh-z9200bt
Avh-z9250bt
Avh-z9290bt
Avh-z9280tv
Avic-w8500nex
Avic-z920dab
Avic-z820dab
Avic-w6500nex
Avic-z720dab
Avic-z620bt
Posted Mar 14, 2023 · 23:45 UTC#272
Saludos,tengo un Pioneer AVH-Z9250BT funcionando,como hago una copia de seguridad para compartirlo?
Posted Mar 15, 2023 · 16:35 UTC#273
English: Greetings, I have a working Pioneer AVH-Z9250BT, how do I make a backup copy to share it?
Posted Apr 07, 2023 · 09:59 UTC#274
On 11/24/2022 at 9:45 AM, atomkahu said:
Hello!
I downloaded  the Pioneer Avic_F77 file twice from here.
https://mega.nz/folder/46ISTKAC#JGj_lJWtP2LvLD1GuaQ8zA/folder/luoC2Qob
I tried to extract it, but the file is corrupted.
Can someone re-upload it somewhere?
the image isnt corrupted your PeeCee just doesnt understand what it is
Posted Apr 16, 2023 · 21:02 UTC#275
Hello
I'm looking for an image for AVH Z9200 Dab  Europe. Thank you in advance
Page 11 of 15
