X930BT has new update, but bluetooth no longer functions correctly
By wascapsfan · Dec 30, 2016in Hacks/Mods💬 35 posts👁️ 18,798 views
Page 1 of 2
Posted Dec 30, 2016 · 03:46 UTC#1
I updated to the 6.0 with the 2015 maps, but now my One plus 3 can no longer connect to the X930BT.
I used
Then extract the files, copy UPDATE, FIRMWARE, and CardInfo.CIF to the root of a freshly formatted FAT32 SD, and insert it into your unit.
Any ideas??
Thanks in advance
Posted Dec 30, 2016 · 14:01 UTC#2
I used
Any ideas??
Thanks in advance
Try disconnecting the car battery for a couple minutes. Many BT phone problems are cured by this reset after an update.
Posted Dec 30, 2016 · 17:38 UTC#3
Thanks Ron. Unfortunately it did not help.
The media audio refuses to let me check it, and if it does (via getting lucky and not having the media sharing long with phone audio and media audio), it turns off after a few seconds.
Posted Dec 30, 2016 · 17:57 UTC#4
I'm assuming you've tried deleting the pairing on the phone, then re-pairing.
Do you know what software version you had before updating to v6.0? After installing the 6.0 update, did you manually update the BT software?
Some people were able to resolve BT issues by installing older BT versions. I know there's a thread with a link to were to get it.   I don't know, off the top of my head, what the version numbers are.
Edited Dec 30, 2016 by RonS
Posted Dec 30, 2016 · 21:42 UTC#5
Hi Ron,
I had 3.000.
I'm not sure how to downgrade to a different BT.  I keep seeing 3.32, but mine is 3.22.2.
All I know is that I cannot get bluetooth.
Any advice would be appreciated.
Thanks for taking the time to help
Posted Dec 31, 2016 · 00:20 UTC#6
Hi Ron,
I had 3.000.
So it sounds like you never updated your BT drivers. It is a manual step after you update the maps. V5 and V6 maps come with 3.32. Go to Settings/Bluetooth Settings/Firmware Update.
If you decide to back out of that, see this old post:
Since you didn't give any information about your HU, I can only guess. This BT streaming audio problem seems to have started with Android 5 (Lollipop). I don't think v6 (Marshmallow) improved the issue. There seems to be some incompatibility with the newer Android BT versions and AVIC head units. I recall someone with this problem stated that loading an older version of the AVIC BT firmware fixed the issue (but I think some other functionality was lost). You could try the older 2012 BT firmware by downloading and extracting CNSD-310-FM then copy the FIRMWARE directory to an empty SD (no Testmode.key). Insert into your HU, go to Settings/Bluetooth Settings/Firmware Update and install.  If it doesn't fix your problem, you can always reload the newest firmware. I figure its worth a shot. BTW, it appears that the latest AVIC 2015 map upgrade has the same BT firmware as 2013.
Posted Dec 31, 2016 · 13:31 UTC#7
Hi Ron,
Again, my deepest apologies.  You are so wonderful to help and all input has been greatly appreciated.
Please consider removing that last post where I was acting like an idiot.
I upgraded the firmware to the 3.32, but no change.  I'm going to try the downgrade to see where that takes me.
I have a One Plus 3 with the 7.0 Nouget, with Experience Rom v1.0  (Oxygen OS Version OP3_O2_Open_9)
Posted Dec 31, 2016 · 23:02 UTC#8
Downgrade completed and disconnected battery for 30 minutes. No change.
No media audio still.
It doesn't appear that I can go back to 3.00, is that correct?
Edited Jan 01, 2017 by wascapsfan
Posted Jan 01, 2017 · 14:55 UTC#9
You mean v3.x of the Nav software? Possibly. From what I understand, when you insert an update SD, the system checks the version number and only proceeds if the SD contains a newer version. Some have used Testmode  "Force Write" load older software. I've never done that so I can't help.
And from another post I got the impression that you have already tried the simpler method to revert to the previous installation - by deleting or creating (as the case may be) the PRG.FLG file in USER.
But before you do anything, have you tried powering off and on your phone? Even removing the battery for a few minutes (if possible with your phone). I know this has solved the issue for some people (IIRC iPhones - but who knows?).
Otherwise, I'm about out of ideas. Sorry. It would be interesting to know if anyone else with your make/model phone is having issues. It sounds like you are running a custom ROM, so that may complicate things.
Posted Jan 01, 2017 · 17:04 UTC#10
Good afternoon Ron, and Happy New Year to you and yours.
I did not delete the PRG.FLG file in user. I didn't know I was supposed to.
I do have a custom rom on my one plus 3.
It did work fine, and all media, phone and contacts worked properly with the 3.xx. The problems started after the 6.0 upgrade
Posted Jan 01, 2017 · 19:27 UTC#11
There are two separate copies of the software on the unit. Under User, there are folders named PRG0 and PRG1. If your unit has never been updated, they are both identical. Updating to v6 should of overwritten only one of them. The boot loader chooses which one to run using the presence or absence of a file in USER called PRG.FLG. If this file doesn't exist, the loader uses the files in PRG0. If it does exist, it uses PRG1.
To use the backup copy:
  1. On your PC create a file called PRG.FLG using any method you like. If usually is 0 length but it really doesn't matter
  2. Copy this file to your SD along with testmode.key. Having a PRG.FLG file handy is just in case you need it below.
  3. Boot your headunit into TestMode and go into File Maintenance.
  4. Navigate into User.
  5. If PRG.FLG already exists, delete it. Otherwise copy PRG.FLG from your SD into USER
  6. Don't do anything else - Testmode is dangerous
  7. Remove the SD and restart your headunit.
That's it. You should now be running on your backup firmware. Check in the settings to see. IDK which version of the BT firmware will be running. You may need to reload it from the method in my previous post.
Sorry for any typos - hangover.
Edited Jan 01, 2017 by RonS
Posted Jan 01, 2017 · 21:31 UTC#12
Thanks so much for everything.
I made it as far as going into user.
It will only allow me to add the PRG.FLG into one of the existing files. It won't let me paste into the file itself.
It has PRG0, PRG1, RW, Setup, and System..
Am I missing something? Enter, All, and Help are the only things that I can use in the path:
User
Posted Jan 02, 2017 · 00:28 UTC#13
User
So it sounds like you don't have the USER/PRG.FLG file and are having problems with TestMode.
First, make sure you have the correct Testmode.key. There are a few floating around and some won't allow pasting. I'm attaching one that works.  Be sure to unzip it first.
Sounds like you need remedial TestMode training. It is a very clumsy user interface - to say it mildly. There are several videos on Youtube that cover copying and pasting files. JASONH did an early one (WARNING - he refers to Hackmode  but he is demonstrating Testmode. Never install Hackmode) I really don't have the time or patience to turn this into a Testmode tutorial.  There are already several around AVIC411.
SUPERTESTMODE.zip
Posted Jan 02, 2017 · 01:00 UTC#14
You had that right. Mine was bad. Yours allowed me to successfully add PRG.FLG
Path:USER
VOLUME
PRG0
PRG1
RW
SETUP
SYSTEM
PRG
After doing great this, there was still no change. Do I delete one of the PRG0 or PRG1 files?
Posted Jan 02, 2017 · 02:52 UTC#15
Path:USER
VOLUME
PRG0
PRG1
RW
SETUP
SYSTEM
PRG
First, those are directories (folders), not files. Unless its a typo, you still don't have a PRG.FLG file. And never delete anything unless you are told to. It's a good idea to make a copy to SD of everything in USER - just in case.
Posted Jan 02, 2017 · 02:57 UTC#16
Oh.. I added the PRG folder. I haven't deleted anything. I didn't have a PRG.FLG folder before I added the last one
I will remove that PRG (PRG.FLG) folder that I added.
Where am I supposed to add the PRG.FLG folder? I only had the prior folders
Posted Jan 02, 2017 · 03:03 UTC#17
Per your previous:
Am I supposed to go into the PRG0 and PRG1 folders and look for PRG.FLG files?
Posted Jan 02, 2017 · 13:32 UTC#18
Per your previous:
No, if present it should be a file in the USER folder. You seem to be using terminology in a non-standard way, and it is confusing the situation. A folder (also called a directory on many computer systems) contains zero or more files or other folders. A file can be anything that you want. It can be empty or contain  binary data, text, music, pictures, or anything else that needs to be kept.
So if there was no file called PRG.FLG in USER (which also contains the folders PRG0, PRG1, and some others), you need to copy the one from your SD into the USER folder on the AVIC. That may be what you did, but from your description I couldn't tell.
After that is done, remove the SD and restart your unit. It should load normally. Then, go into Settings/System Settings/System Information, and see what the version is for Application.
Also check what your Bluetooth version is. I don't remember if it is on that screen, you my have to go into Bluetooth Settings.
Edited Jan 02, 2017 by RonS
Posted Jan 02, 2017 · 16:30 UTC#19
Sorry to be confusing.
Let me phrase it this way.
I installed the sd card with the proper testmode that you sent me.
I turned the knob to user and clicked on the button below the knob.  The only things I saw in User was:
Volume
PRG0
PRG1
RW
SETUP
SYSTEM
From there, per your prior instructions, I added the PRG.FLG (it only shows as PRG), to the User list and it showed up under SYSTEM.  It is empty.
There never was PRG.FLG in the original list.
The list now looks like this
Volume
PRG0
PRG1
RW
SETUP
SYSTEM
PRG
I did not add the PRG0 and PRG1 to this new PRG.FLG  (folder/file that is under System in the list above)
I restarted the unit and there is no change.
Here are my screens
Edited Jan 02, 2017 by wascapsfan
Posted Jan 02, 2017 · 17:55 UTC#20
Volume
PRG0
PRG1
RW
SETUP
SYSTEM
Volume
PRG0
PRG1
RW
SETUP
SYSTEM
PRG
Here are my screens
I don't know what you are doing wrong, but I can tell from the pic of your USER directory you did something wrong. It shows a directory <DIR> called PRG. I'm attaching a photo of my screen. Notice mine shows a file called PRG.FLG
It must be either how you are creating the file on your PC (it is a PC correct?), or how you copied and pasted it in USER.
I am also attaching a file you can use for PRG.FLG. You have to unzip it (for some reason I can't upload the file as-is). Copy it to your SD and try again. I hope you didn't destroy anything in PRG0 or PRG1.
PRG.zip
Posted Jan 02, 2017 · 19:09 UTC#21
Again Ron, you are so generous with your time, and I can't thank you enough for your help. I will report back after I try your zip file.
Quickly, my folder/file that says PRG, that I added to the user field did say PRG.FLG when I created it. The program shortened it to PRG when I copy and pasted it to that screen. When I clicked into it, it says PRG.FLG as it shows at the top of the one photo.
Regardless. I'll try your zip and report back.
I did not touch either PRG0 or PRG1. They are as they have been from day 1
Posted Jan 02, 2017 · 20:29 UTC#22
Ok.. Getting closer.
I copied the PRG.FLG file and the testmode that you sent me onto a formatted sd card.  I can copy the PRG.FLG file without issue as a + sign shows up next to the file, but when I try to paste the PRG.FLG file into the the path:USER\, all of the options are greyed out except for ENTER, ALL, and HELP
Here are my photos.  They each ungrey if I select any folder inside of USER, but will not let me add it to the lineup
Posted Jan 02, 2017 · 22:11 UTC#23
I have a Z series unit, which has different buttons. So Testmode works differently (no volume knob and the other buttons on the bottom). I'm sure it is just a problem with you understanding how this lousy user interface works. I just made a video showing how to do this on my Z110. Looks like the "command bar " at the bottom doesn't show up very well when it is highlighted, but it should be pretty obvious what I'm doing with my narration.
Test Mode Copy Paste video
If you get an error trying to play the link directly, download it (there's a down arrow on the right-top) and use whatever player you have.
Posted Jan 02, 2017 · 22:53 UTC#24
Ok great. Your tutorial was perfect and showed me where I was doing it wrong. I added the dots and we were good.
I'm still on 6.00 though, and I have no media.
Still no change, unfortunately.
Bluetooth 3.24.81
Posted Jan 03, 2017 · 16:22 UTC#25
I guess I have to assume that both of my PRG (PRG0 & PRG1) files have the 6.0??
I'm dying to get this sorted out once and for all.
Page 1 of 2
