28 minutes ago, v0rtex said:Hi Guys,
Tried to update F30BT step by step:
1 - using formated fat32 SDcard 4GB and unzip all shortfusescript files to sd root
2 - go to unit, start, insert sdcard, ask to updated by pressing any key, Done without errors. turn off unity after (I have a backup off all files inside SDcard afterrun this script)
3 - Format again the same SDCARD 4GB fat32
4 - unzip 2017 update with pass 'Dracarys' and copy firmware/update/cardinfo to sdcard root (I did not edit nothing, just copy/paste)
5 - insert sdcard into unit (detects update), insert PASSWORDPASSWORD ok and the unit informs, the unit need to restart in oder to install the update
6 - unit restart, update starts ok, but at 8%, got stucked on SD card error message
Now do I need to run unit in testmode to continue or can I use another SDCARD or format the same one, unzip again the map, copy and try to continue from 8% because unit cannot move after 8% message
Working ok now.
Just reformat again SDCARD, unzip again map update and continue from 8% ok
