New Release F20BT F30BT F40Bt F920BT F930BT F840BT Etc 2017 Releastechnologye
By godzilla · Jul 20, 2017in Hacks/Mods💬 385 posts👁️ 195,164 views
Page 2 of 16
Posted Aug 30, 2017 · 18:57 UTC#26
Psydon, do you recall if PRG0 was the Active one before doing the map update? I'm trying to collect data one which works best: blindly patching PRG0, or patching the Active one. I'm starting to think it needs to be the Active one but need more data. My Active was PRG0 so it doesn't add any info.
Unfortunately i dont remember which was the active folder. I just took dll from the first PRG0 folder and the copied back patched one in both of PRG0 and PRG1 just to be safe.
Posted Aug 30, 2017 · 19:04 UTC#27
Yes, so in reality I only patched the one in prg1. The one in pgr0 is the original file (as mention already "new" offsett)
OK, since the already patched PRG0 had no effect, that's further evidence that we need to get/patch/replace the one in the Active PRG, not always PRG0. I've updated the Shortfuse instructions.
Edited Aug 30, 2017 by RonS
Posted Aug 30, 2017 · 21:28 UTC#28
Succeed !!!   I've update my F940BT, I edit RenewalIFLib.dll from the unit end replace it. Than I copy the update on SD-Card and run it with the Pioneer PW: PASSWORDPASSWORD end wait for 25 min.
Offset 000019F0:  0350A0E3 replace with 0050A0E3
Offset 00001A10:  0350A0E3 replace with 0050A0E3
Offset 00001AD8:  0350A0E3 replace with 0050A0E3
Offset 00001C1C:  0250A0E3 replace with 0050A0E3
Offset 00001C24:  0150A0E3 replace with 0050A0E3
Offset 00001A3C:  0350A0E3 replace with 0050A0E3
Now I've the 2017 maps from Europe.
Very big thanks to godzilla.
Edited Aug 30, 2017 by TimdeJongh
Posted Aug 31, 2017 · 09:18 UTC#29
password per zip? non riesco ho provato : PASSWORDPASSWORD ma senza risultato perche?
Posted Aug 31, 2017 · 12:08 UTC#30
Can someone put this on a mini sd card for me? That its ready for installation. is for the f930bt. I will pay for it
I am from holland,.
Posted Aug 31, 2017 · 13:46 UTC#31
Corvus, please instructions ?
Posted Aug 31, 2017 · 15:12 UTC#32
Updated my previous post...
Posted Sep 01, 2017 · 12:48 UTC#33
AVIC-F20BT Update Success!
So, here is what i did:
First i have edited CARDINFO.CIF.
You need to search for:
OE9R75LQ2MJ2X72EUR
and replace with
X07EURX27EURX30EUR
Then save CARDINFO.CIF and replace the one on update SD Card.
(I'm providing already edited CARDINFO.CIF, so you can just overwrite it)
Then i used TestMode to get RenewalIFLib.dll from HU to edit it.
I copied one from following location \USER\PRG0\APL
Then edited it on PC with HxD.exe and made following changes:
Replaced all (hex) 0350A0E3 with 0050A0E3.
Saved the file, copied to SD Card, then back on HU copied on:
\USER\PRG0\APL
and
\USER\PRG1\APL
Booted SD Card with 2017 update, then for update password entered: PASSWORDPASSWORD
and bam, update installed after 25 minutes.  :cool:
Thanks to Godzilla for providing update files and to RonS for instructions.
Hello, I followed the instructions but on RenewallFlib.dll the HxD doesn't find "0350A0E3". What I have to do? Thanks
Posted Sep 01, 2017 · 13:01 UTC#34
Why don't you try following the detailed ShortFuse instructions instead of this abbreviated summary. Sounds like your problem is with using HxD. Also, when using Find or Replace make sure you set to Hex Values. It defaults to string data type. Also, put spaces between the hex bytes (a byte in hex has two numbers....03 50 A0 E3).
ShortFuse hack
Edited Sep 01, 2017 by RonS
Posted Sep 01, 2017 · 15:52 UTC#35
Can not update my f930 bt how do i do it? Help
Posted Sep 01, 2017 · 19:09 UTC#36
Nag screen removed, patched navi.exe v7.0 @ offset BEC18 0500000A -> 0000A0E1, replace in pgr0
(just found the rigth offset then I already saw RonS found it in Z forum so I can confirm its the same offset)
I attach the patched navi.exe v7.0 taken from the 2017 release file.
Instructions:
Copy the pached navi.exe and tesmode.key on a SD
Fire the unit, testmode will start.
If USER\PRG.FLG file exists you have to swop USER\PRG1\APL\Navi.exe or else you have to swop USER\PRG0\APL\Navi.exe
Remember to delete the navi.exe on device before you start copy it from sd because testmode.key dossent suport overwrite.
The you copy navi.exe from sd to device.
No more nag, and you the latest ver off navi.exe.
 step by step:
1. MMC 1GB fat32 copy two file testmode and NAVI.EXE
2. MMC 4GB fat32 copy MAPS2017
We run the device in mode and look for the file in the directory USER\PRG1\APL\Navi.exe  and delete it later copied from the memory card Navii.exe then remove the card and insert with maps. Do I understand correctly?
Sorry for the mistakes but I use the translator, I'm from Poland
Posted Sep 01, 2017 · 19:22 UTC#37
Have somebody het password voor het 2017 Maps??
Posted Sep 01, 2017 · 19:49 UTC#38
 step by step:
Forget about Nag screen until you get 2017 installed. Read the Shortfuse hack instructions http://avic411.com/index.php?/topic/83535-map-update-hack-using-shortfuse-method-z110-z140x920-x940/
Posted Sep 02, 2017 · 09:52 UTC#40
Does it also work for the F9220BT? I also don't fully understand where and how to install it..
Posted Sep 02, 2017 · 11:36 UTC#41
ShortFuse hack
Hi, finally I replaced with HxD, copied with testmode. Insert SD with 2017 Maps, choose PASSWORDPASSWORD, BUT WHEN AVIC RESTART SHOW ME "wrong sd card insert right sd".  Help me PLEASE!!
Posted Sep 02, 2017 · 12:48 UTC#42
The most common reason for  "wrong SD" is because you modified a file on the SD. CardInfo,CIF (if necessary for your model) is the only file that should be changed. The second most common  reason is an error reading the SD. Reformat the SD FAT32 then extract the files from the original zip and try installing again.
Edited Sep 02, 2017 by RonS
Posted Sep 02, 2017 · 14:52 UTC#43
The most common reason for  "wrong SD" is because you modified a file on the SD. CardInfo,CIF (if necessary for your model) is the only file that should be changed. The second most common  reason is an error reading the SD. For reformat FAT32 then extract the files from the original zip and try installing again.
It is a problem that I have installed navi.exe before change Renewfile.dll and install 2017 Maps?
Posted Sep 02, 2017 · 14:57 UTC#44
From the instructions on installing Nag Screen hack: "Note: Install the 2017 map update before installing this hack. Do not patch the file on the 2017 installation SD before installing the 2017 Update. If you do, the installation will fail."
Similar warnings are found in the ShortFuse hack instructions. I guess I write detailed instructions for myself to read because so many people ignore them, or repost incomplete instructions that others pick-up and use.
If you are new to this, don't blindly follow those "it worked for me and this is what I did..." instructions.  They are just summaries and leave out important warnings and details. Read the full ShortFuse and Nag Screen hack threads in Z Series Z110/12/13/14/150 Hacks & Mods. Those instructions also apply to most F series.
Edited Sep 04, 2017 by RonS
Posted Sep 02, 2017 · 15:03 UTC#45
Does this map work on F10bt?
Posted Sep 02, 2017 · 15:37 UTC#46
Do what I said.
You have a reason. FInally I updated F920BT! But what's mean nag screen?
Thank you so much!
Posted Sep 02, 2017 · 18:52 UTC#48
Hi RonS, can you check my file and prepare? Thanks
Thhis my Renevallib https://mega.nz/#!o05WibKD!gOZILQDUB0u29Qdg66vfVU1PpZHNxBHJ4gX7DeZQd_I
No, if I start doing that, I'll get hundreds of people asking for it. I'm done here in the F series. Let some of the experienced EU people step in to help.
Goodbye folks, And be sure to show your appreciation to godzilla.
Posted Sep 02, 2017 · 19:11 UTC#49
I know how to do just that my file does not have these values offsset. Of course he would thank Godzilla.
  • 00001A3C
  • 00001AD8
  • 00001C1C:
  • 00001C24:
Posted Sep 02, 2017 · 19:20 UTC#50
@tarnos here you are.RenewalIFLib.rar
Edited Sep 02, 2017 by detlef12
Page 2 of 16
