New Release F20BT F30BT F40Bt F920BT F930BT F840BT Etc 2017 Releastechnologye
By godzilla · Jul 20, 2017in Hacks/Mods💬 385 posts👁️ 195,164 views
Page 3 of 16
Posted Sep 02, 2017 · 19:38 UTC#51
This is to F930BT nothing will happen?
Posted Sep 02, 2017 · 19:40 UTC#52
Make backup from your files first so you are save.
Posted Sep 03, 2017 · 14:08 UTC#54
Hey.Jemand aus Deutschland hier?Hat jemand eine einfache idiotensichere Version für das Avic f30bt Modell?
Posted Sep 03, 2017 · 16:43 UTC#55
Hi All.
Can one help me with password to the zip file "2017 update.zip" ?
Best regards
Asger
Posted Sep 04, 2017 · 16:58 UTC#57
finaly updated my F930BT today:
-  edited RenewallFlib.dll and copied back to the unit
- tried to update with 8GB SD card, FAT32, 8KB, and all files from the SD copy, but with modified CARDINFO. Did´nt work !
- use the CARDINFO fron the original Update and 25minutes later success. Used Password 'PASSWORDPASSWORD'
- copied modified navi.exe to the unit and no nag screen at startup
unanswerd question till now:
- Blueooth update required?
- works also on F900BT ? thinks F900 is an other platform or?
Greets
osiris
Posted Sep 04, 2017 · 17:41 UTC#58
can i update my f9220 bt ?
and first message be edit true files.
Edited Sep 04, 2017 by aksneo
Posted Sep 04, 2017 · 19:04 UTC#59
Can someone send me the zip file password please?
Thank you
Posted Sep 05, 2017 · 09:06 UTC#60
Can someone please send me a pm with a password for the ZIP file.
Thank you
Posted Sep 05, 2017 · 10:29 UTC#61
i think godzilla give password for PM
Posted Sep 05, 2017 · 14:48 UTC#62
I've very old maps in my F20BT navi. I think its 2010. Will my Renevallib have changes in the same offset - its constant across all versions?
Can I update with this procedure?
Posted Sep 05, 2017 · 17:02 UTC#63
You can try. I have also F20BT and my RenewalLib had those hex offsets. I've successfully updated to 2017.
Posted Sep 06, 2017 · 05:37 UTC#65
Does not work on F10bt. It shows "wrong sd card insert right sd.
Try with different micro SD, card quality is the problem in your case.
Posted Sep 06, 2017 · 07:29 UTC#66
If the update fails and you are stuck with "Wrong SD" message:
-boot into testmode.
-go into file maintenance
-remove the file USER\SYSTEM\Download\StartKnd.log
tesmode.key indir
Posted Sep 06, 2017 · 19:22 UTC#67
...working on f30bt without any probs....thanks guys...rock on...peace
Posted Sep 06, 2017 · 19:29 UTC#68
I hope that pionara joins this forum in a few day's, he is the man who fixed the verinfo.dat @ the 2015 maps
Let's shout his name PIONARA!!! :)
Dit someone try'd to use the verinfo file from the 2015 update? don't know if it works but worth a try ?
Edited Sep 06, 2017 by Sjarrel
Posted Sep 06, 2017 · 21:46 UTC#69
Hi Guys here is the password the mail server is getting overloaded I do not want to see this being shared on any other forum  apart from this one as i have done this to help everyone on this forum because its helped me so much in the past please respect this and hope the master PIONARA helps out
details here
Hi Password is 'Dracarys'  exactly as shown
Regards
Godzilla
Lol Game Of Thrones Fan :)
Posted Sep 06, 2017 · 21:54 UTC#70
THNX for sharing godzilla!!!!!
Posted Sep 06, 2017 · 22:59 UTC#71
details here
Regards
Godzilla
But we'll still get hundreds of posts asking for the password and/or complaining that it doesn't work.  :wacko:  HINT: " 'exactly' as shown".
Edited Sep 07, 2017 by RonS
Posted Sep 07, 2017 · 01:22 UTC#72
Flawless updated the F940! Thanks and keep up the good working!
Posted Sep 07, 2017 · 18:38 UTC#73
Thanks for sharing godzilla and other people who helped.
Edited Oct 13, 2019 by navgeek60
Posted Sep 07, 2017 · 22:13 UTC#74
Hi, do i need to change anything before installing Godzilla's 2017 update on my F920BT?
Thx in advance!
Posted Sep 08, 2017 · 11:03 UTC#75
is it version:6.00 ?
Page 3 of 16
