New Release F20BT F30BT F40Bt F920BT F930BT F840BT Etc 2017 Releastechnologye
By godzilla · Jul 20, 2017in Hacks/Mods💬 385 posts👁️ 195,164 views
Page 5 of 16
Posted Sep 11, 2017 · 18:25 UTC#101
Hi,
is someone working on the files (cardinfo,verinfo) like it was in verion 2015?
Kindest regards, bubuu77
Posted Sep 12, 2017 · 11:14 UTC#102
That's the correct whole process. Try it, and comment please.
You can find testmode.zip in this post:
http://avic411.com/index.php?/topic/83535-map-update-hack-using-shortfuse-method-z110-z140x920-x940/
Updated my F9220BT succesfully. Version is now 7.0. No problems during modifying and updating. Thanks for the help!
Btw.. does this update also have trafficradar/speedradars in it? If not.. what is the easiest way to update/edit those too?
Edited Sep 12, 2017 by harry_wit
Posted Sep 12, 2017 · 18:54 UTC#103
Found this links in another forum. Has product T1000-25815 - another as previous one here T1000-25817. If someone know the differences please comment.
HI!
This maps is available for F930BT?
Posted Sep 12, 2017 · 19:36 UTC#104
HI!
Yes this is for the AVIC-F30 930 940BT versions
Posted Sep 12, 2017 · 20:49 UTC#105
Thank!!
Posted Sep 13, 2017 · 11:29 UTC#106
Yes!!! F930BT
Succesfull and even simpeler then i thought.
step 1: download download shortfusescript.zip and  2017 update file
step 2: unpack shortfusescript on a fat32 SD card
step 3 Run script on F930BT ( just place SD card and touch a key when asked.
Step 4: unpack 2017 update on at least 4GB sd card.
step 5: place sdcard in F930BT and restart
step 6: choose update procedure yes. When asked use PASSWORDPASSWORD as password.
enjoy... for this F930BT type no other steps are needed. ( probably because its the original for this type and several others)
Posted Sep 13, 2017 · 18:51 UTC#107
Yes!!! F930BT
Hey i do exactly the same but i become every time the message after pw. SD Card wrong.
What can i do i have a avic-F840bt?
The older versions 2015 works but doesnt this.
Thanks for help!
Edited Sep 13, 2017 by Dean2302
Posted Sep 13, 2017 · 19:11 UTC#108
SD card wrong is often a format problem. Use a 4GB fat32 formatted sd card.
Posted Sep 13, 2017 · 19:12 UTC#109
Question.. how to change my F930BT to a F940BT after you did this update.
Any tips or howto's would be welcomed by me.
is it just replacing the verinfo.dat file?
And if so.. can i use the one used in 2015 update as shown on forum by sinbad or is there a newer version..
Edited Sep 13, 2017 by seth_space
Posted Sep 13, 2017 · 21:23 UTC#110
i know i do the same 4 gb fat32 sd card. these works always for 2015 update but only after the passwordpassword question the system start new an will install but before it comes these message. I formatet it but its the same problem> its a new card.
Posted Sep 14, 2017 · 06:35 UTC#111
Extract de files from zip again with the correct password. Use single quote ' at the beginning and the end.
I had the same problem.
Posted Sep 14, 2017 · 13:35 UTC#112
If the update fails and you are stuck with "Wrong SD" message:
-boot into testmode.
-go into file maintenance
-remove the file USER\SYSTEM\Download\StartKnd.log
THX aksneo
Edited Sep 14, 2017 by Michael_81
Posted Sep 14, 2017 · 16:23 UTC#113
I thank you very mutch. It works perfect.
Posted Sep 17, 2017 · 06:04 UTC#114
What instructions should I use for the F40BT?
Posted Sep 17, 2017 · 07:34 UTC#115
Yes!!! F930BT
THX
It works on my F40BT
It is very easy with the shortfusescript.zip.
http://avic411.com/index.php?/topic/83535-map-update-hack-using-shortfuse-method-z110-z140x920-x940/&do=findComment&comment=345382
Edited Sep 17, 2017 by chili-deluxe
Posted Sep 17, 2017 · 08:50 UTC#116
Avic-F9220BT succesfully updated, THANKS to Godzilla and RonS!
Posted Sep 17, 2017 · 09:02 UTC#117
And also THANKS to bompa (I use 'Navi_NoNag(F).zip' and it works perfectly!)
Posted Sep 17, 2017 · 10:46 UTC#118
Yes!!! F930BT
Greetings to everyone.
It worked for F840BT.
Good work of RonS script, all easy, many thanks to godzilla for the maps.
Sorry for my English, I used Google Translator.
Posted Sep 17, 2017 · 12:54 UTC#119
Hey guys.
I download the 2017 uodate zip. filet from google driver, but I can not unpack without the password. Did you send a "godzilla" password to you? Do you know the password?
Thank you vini1
Posted Sep 17, 2017 · 16:45 UTC#120
Yes!!! F930BT
it past for F10BT, F20BT ... or must use something else?
Best regards
Edited Sep 17, 2017 by Michael_81
Posted Sep 17, 2017 · 18:48 UTC#121
Hello to everybody.
The update is for the systemsF20BT, F30BT - F930BT-F9310BT - F40BT - F940BT - F840BT - F8430BT
'Dracarys' zip password.
You guys have to thank Godzilla for this very much.
Edited Sep 17, 2017 by RonS
Posted Sep 18, 2017 · 06:42 UTC#122
How about F920BT?
The headline of the downloads also mentions AVIC-F920BT.
Did anybody try this unit?
THX!
Posted Sep 18, 2017 · 12:23 UTC#123
How about F920BT?
Official update info:
2017 European Map Update for Pioneer MY09/10 - AVIC-F10BT, F20BT, F920BT, F9210BT, F9220BT - Catalog # T1000-25815
2017 European Map Update for Pioneer MY11/12 - AVIC-F30BT, F930BT, F9310BT, F40BT, F940BT, F840BT, F8430BT - Catalog # T1000-25817
Godzilla version is the second one. First one is here but i think nobody has tested it.
Posted Sep 18, 2017 · 12:56 UTC#124
How about F920BT?
At least one person was successful installing godzilla's version on a F20bt by editing the CardInfo.CIF file. He posted the file. I think you could also use the CardInfo from a previous version that worked for your unit. IIRC, the 2015 maps had CardInfo files posted.
Posted Sep 18, 2017 · 13:06 UTC#125
Hi guys.
It works perfectly with AVIC-F9310. The problem was that I tried to enter the password without the single quotes.
Thank you everyone.
Page 5 of 16
