Yes!!! F930BT
Succesfull and even simpeler then i thought.
step 1: download download shortfusescript.zip and 2017 update file
step 2: unpack shortfusescript on a fat32 SD card
step 3 Run script on F930BT ( just place SD card and touch a key when asked.
Step 4: unpack 2017 update on at least 4GB sd card.
step 5: place sdcard in F930BT and restart
step 6: choose update procedure yes. When asked use PASSWORDPASSWORD as password.
enjoy... for this F930BT type no other steps are needed. ( probably because its the original for this type and several others)
Many thanks to Godzilla and RonS!
New Release F20BT F30BT F40Bt F920BT F930BT F840BT Etc 2017 Releastechnologye
Updated my F920BT without any problems ![]()
Edited CARDINFO.CIF in Godzilla 2017 update file
OE9R75LQ2MJ2X72EUR
and replace with
X07EURX27EURX30EUR
Then used ShortFuseScript from RonS and flollowed the steps ![]()
Thx to Godzilla and RonS
Before update :
OE9R75LQ2MJ2X72EUR
and replace with
X07EURX27EURX30EUR
Don't forget to update the Bluetooth Firmware through the BT settings menu.
Thx RonS, I have done that now ![]()
Any list of changes/fixes in the firmware anywhere ?
I am amazed that people install software without reading release notes and installation instructions. https://www.navigation.com/is-bin/intershop.static/WFS/Navteq-Site/Navteq/en_GB/Pioneer/CRD5007A.pdf
Hi Guys glad everyone is having fun with the files
just a re minder of password for people you must include the parenthesis - Password is 'Dracarys' exactly as shown
Did it today on my F940BT.
Worked like a charm.
No errors; in 20 minutes complete up to date.
Thanks.
Hey.I need a step by step Instruction for the avic f30 with all download links.....Please.Thanks
Yes!!! F930BT
These steps for F930BT were exactly the same as I used to update my F30BT.
I want to add that the NAG screen is disabled as well
@mani1980
step 5: place sdcard in F30BT and restart
enjoy... for this F30BT type no other steps are needed. ( probably because its the original for this type and several others)
I forgot to thanks to GODZILLA and RonS!!!!!
This works on F940BT
Thanks you guys!!
Hi Guys I only check for updates and messages in the evenings so bear with me send password to all requests here is the link to the TTs Cd Image ISO
Here: https://drive.google.com/open?id=0B8anve6eLs7YZFo5N1ozTkJqNjQ (no Password)
The update is for the systems F30BT – F930BT –F9310BT – F40BT - F940BT – F840BT – F8430BT - Straight out of the box
Good Luck Guys
Godzilla
Hi guys,
You all are THE mans of this situation!
Lots of thanks.
I'm currently performing the update on an AVIC-F9310BT, and seems to run good thanks to ShortFuse script.
@godzilla, I'm French and I got some difficulties to understand what your post above is intended for?
Shall I perform additional step once the MAP update done?
Many thanks in advance for your help and have a nice day!
Edit: update worked perfectly. Just a question, how to check I got the new MAP, as visually I have the same display?
He to all
I have an F920BT with 2.000000.
I start the ShortFuseScript and remove the SD, i insert the Map SD and than comes the massage " something is wrong with the Installation.... tray again"
I press a lot of times "tray again" than comes " Update in progress" but nothing happens...
I change the SD, cardinfo, format the SD...
Now i have no idea more.
Thank you for your help and sorry for my english
He to all
Since you give little detail of what you did and it is hard to make sense of your description, I'll guess that you are getting a message saying something about incorrect SD. I've never seen that message so I don't know exactly the words used.
I recommend unzipping the map update from godzillz again. Be sure to enter the zip password 'Dracarys' including the single quote characters. If you do not enter the password correctly, some of the files will not unzip and the installation will fail.
Avic-F920BT succesfully updated
DONE
Thanks too all
What files do you see in the root directory of your 2017 map SD?
2017 map SD -FIRMWARE,UPDATE,CARDINFO.cif = 3 627 220 992 bajtow
2015 map SD -FIRMWARE,UPDATE,CARDINFO.cif = 3 627 220 992 bajtow
is that so good ?
is that so good ?
We don't seem to be able to communicate. Maybe someone can help who speaks your language.
If the 2015 worked for your F20, then copy that CardInfo.CIF file to the 2017 SD and put it into your F20.
Should be just 2 directories (FIRMWARE, UPDATE) and CardInfo.CIF (the correct one for your model).
You didn't follow the directions. I don't know how it could be simpler. What password did you use to extract the ZIP files?
Avic F20bt succesfully updated
Unzip the map files again. Be sure to enter the zip password 'Dracarys' including the single quote characters. If you do not enter the password correctly, some of the files will not unzip and the installation will fail. I'm getting tired of having to post this again and again.
Thank you soooooooo MUCH. Its working
F920bt succesfully updated
Everything worked fine on F30BT. Thanks!
