New Release F20BT F30BT F40Bt F920BT F930BT F840BT Etc 2017 Releastechnologye
By godzilla · Jul 20, 2017in Hacks/Mods💬 385 posts👁️ 195,164 views
Page 9 of 16
Posted Oct 19, 2017 · 16:05 UTC#201
Password  'Dracarys' with ' 10 characters . Im used 32 GB SD Card Werde jetzt mit 8 GB versuchen
Posted Oct 20, 2017 · 14:06 UTC#202
So Feedback von mir. Installation ist immer bei 99% unterbrochen worden, egal was für SD Karte ich benutzt habe ! Danach ist überhaupt nichts mehr gegangen: Aktualisierung Fehler  :evil:  ! Habe auf Festplatte Update von 2013 gefunden und dachte  :idea:  versuche mal ....Und das hat Funktioniert mit 32 GB Card !!! :razz: Habe dann von RonS ShortFuseScript ausgeführt und weiter alles nach Anleitung !!! Hat super geklappt !!!
Einen besonderen dank an RonS und Godzilla für eure Arbeit!!!!
Edited Oct 20, 2017 by vampir13
Posted Oct 20, 2017 · 15:23 UTC#203
hello
   avic f10bt
step 1: download download shortfusescript.zip and  2017 update file
step 2: unpack shortfusescript on a fat32 SD card
step 3 Run script on F20BT ( just place SD card and touch a key when asked.(wait 1 minute eject sd card .do not turn off avic!!!
Step 4: unpack zip 2017 update on at least 4GB sd card. password 'Dracarys'
step 5: place sdcard in F20BT and RESTART !!!
step 6: choose update procedure yes. When asked use PASSWORDPASSWORD as password.
(sd card fat32 4gb -shortfuse
sd card fat32  4gb - 2017 update (FIRMWARE.UPDATE,CARDINFI.cif 2015 for avic F10,F20)
 maps does not update bluetooth update if updated
What can be?
Posted Oct 20, 2017 · 19:25 UTC#204
updated¡¡¡ avic f10bt
thank you very much
godzilla
rons
and
     bubuu77
thank you very much
Posted Oct 20, 2017 · 20:03 UTC#205
Good luck :smile:
Posted Oct 22, 2017 · 08:17 UTC#206
The update has worked great at F940BT
Thank you for the great work on Godzilla and Ron!
Posted Oct 29, 2017 · 16:28 UTC#207
thanks to everyone .... can anyone tell me the steps for the successful installation of the 2017 update for avic f940bt? Do you also need to replace the string in the cardinfo file? thanks for the collaboration in advance!
Posted Oct 30, 2017 · 07:54 UTC#208
Yes!!! F930BT
Succesfull and even simpeler then i thought.
step 3 Run script on F930BT ( just place SD card and touch a key when asked.
Step 4: unpack 2017 update on at least 4GB sd card.
step 5: place sdcard in F930BT and restart
enjoy... for this F930BT type no other steps are needed. ( probably because its the original for this type and several others)
I confirm it works on a F840BT and it takes about 20 minutes to complete.
I would like to thank you Seth and all the other who contributed with lots of useful technical stuff, Godzilla and Rons at first.
Thanks again
Posted Oct 30, 2017 · 16:07 UTC#209
it's possible to have instruction for to install on f940bt please?
Posted Nov 02, 2017 · 19:38 UTC#210
F930BT and F940BT are same models. Thus the same procedure as above.
Posted Nov 03, 2017 · 08:50 UTC#211
Nope, didn't tried it yet. I dont have the car during the day, will try it tonight.
Btw, here is CARDINFO.CIF file for update to be recognised on AVIC-F20BT (and F10BT i assume) unit.
NOTICE: I dont take any responsibility if the update bricks your device, since i havent tested it myself yet.
(Thats work in a progress).
Hello, do you know if it work for Avic F910BT ? Thanks you ;)
Posted Nov 03, 2017 · 11:52 UTC#212
This is from the Pioneer/her site:
Official Map update for the following Pioneer device:
- AVIC-F30BT
- AVIC-F930BT
- AVIC-F9310BT
- AVIC-F40BT
- AVIC-F940BT
- AVIC-F840BT
- AVIC-F8430BT
Edited Nov 03, 2017 by seth_space
Posted Nov 03, 2017 · 21:13 UTC#213
Tried the update on my F920BT, short fuse patch worked, update started afterwards but stopped at 93%
Will try another SD card but it would be nice if someone can confirm which cardinfo.cif I would need for the 920BT.
Cheers!
Posted Nov 03, 2017 · 21:27 UTC#214
Cheers!
You have the correct cardinfo if the update started. Once that happens, it doesn't matter. Are you sure you didn't change any other files? Use an 8GB SD.
Posted Nov 03, 2017 · 21:40 UTC#215
Thanks for the quick reply!
Only have a 4Gb and a 32Gb one to try, will try on the 32Gb one.....hopefully I have more succes.
I trust the original files from godzilla's zip are fine for the F920BT and need no altering.
The initial string in my cardinfo was (i believe) #PioneerEL4YD12
Have tried other cardinfo.cif files without succes.
Will keep you posted
Posted Nov 03, 2017 · 22:21 UTC#216
Guys (and girls?)
How do you format your SD cards?
Fat32 16kb sector size?
Posted Nov 03, 2017 · 22:35 UTC#217
Guys (and girls?)
I'd use the 4GB one and I always used the default. Maybe try unchecking quick format. However, I think some have gotten 32GB to work. IDK what sector size they used.
Posted Nov 03, 2017 · 22:39 UTC#218
If I would manage to go in testmode (assuming I can launch it with the testmode.key file) which file would I need to delete to recover my unit to old/previous state?
Giving up for the moment so would like to hand my wife back a working radio for tomorrow :smile:
Posted Nov 03, 2017 · 22:43 UTC#219
Read the ShortFuse post #1 in the Z110/Z120/Z130/Z140/Z150 Hacks & Mods.
BTW, I hope you used single quotes around the godzilla's password when unzipping. That has been the single biggest (and most likely) problem in this whole thread. That would also cause this problem.
Edited Nov 03, 2017 by RonS
Posted Nov 03, 2017 · 22:48 UTC#220
Used the quotes before and after the pw, did see others get that wrong :smile:
Hopefully for me it is a combination of ffing around too much with the cif file and using cheap chinese sd knock off cards.
Will go and get a real SD tomorrow and start fresh, now read up on shortfuse's post how I can get out of the update loop.
thanks sofar for the great help!
UPDATE: recovered boot via supertestmode, happy! Will attempt upgrade again when I have a new SD card
Edited Nov 03, 2017 by FransdV
Posted Nov 03, 2017 · 22:56 UTC#221
OK. As I said earlier, if the update actually starts running, the CardInfo is good. BTW, I just noticed you have a US IP address (T-Mobile USA), but have an F 920 and are installing EU maps. What's up?
Edited Nov 04, 2017 by RonS
Posted Nov 04, 2017 · 08:21 UTC#222
 to my avic f20bt used CARDINFO.cif 2015 for avic F10, F20,F920
Posted Nov 06, 2017 · 17:58 UTC#223
i have problem wrong SD card after enter PASSWORDPASSWORD my F930BT Firmnware 6
Posted Nov 07, 2017 · 10:13 UTC#224
Hi, I have a Pioneer AVIC-F160 + AVH X5600BT, where can I found a new release for this model ? Thanks
Posted Nov 07, 2017 · 19:04 UTC#225
witam
chciałem poprosić WAS o pomoc ściągnąłem wszystkie pliki z posta odnośnie aktualizacji map i oprogramowania Pioneer Map Update Europe 2017 do pioneer avic - f920BT i niby wszystko ok jednak po
1 radio zażądało hasła wpisałem PIONEERAVIC i poszło
2 po wpisaniu nazwy radia poszÅ‚o i na 94% powstaÅ‚ problem napis na ekranie "NIEPRAWIDÅOWA KARTA SD. PROSZĘ WÅOÅ»YĆ PRAWIDÅOWÄ„ I KONTYNUOWAĆ" pozostaÅ‚o 2 min. do koÅ„ca ....
...teraz nie mam nic bo radio jest zablokowane
pomożecie jak i co??
pozdrawiam
zrobiłem pełny format karty na 32 i potem wgrałem na nią soft, ...nie pomogło, jak również te same próby na innych kartach, ten sam komunikat żądający włożenia karty
próbowałem zamienić PRO itd to co opisywaliście wyżej i jest tak
teraz jest nowy wpis o treści:
an error occurred and the update failed
i installer files not found. Is SD/USB still in device.
ktoÅ› coÅ› HEEELPPPPP!!!!
Page 9 of 16
