Hi I tried to update my AVIC-F920BT, it's ok until 93% after I have : "carte sd incorrecte, inserer la carte SD correcte" where is the problèm and how i can go back ? or solve this problèm ? Many thanks in advance.
New Release F20BT F30BT F40Bt F920BT F930BT F840BT Etc 2017 Releastechnologye
Hello
I want to ask WAS for help, I downloaded all the files from post about map updates and software Pioneer Map Update Europe 2017 to pioneer avic - f920BT and kind of ok after all
1 radio required the password I entered PIONEERAVIC and went
2 after entering the name of the radio went and 94% of the problem was written on the screen "INCIDENT SD CARD. PLEASE PRESERVE CORRECTLY AND CONTINUE" remained 2 min. to end ....
... now I have nothing because the radio is locked
will you help and what?
Regards
I made a full 32 card format and then loaded on it soft ... did not help as well as the same attempts on other cards, the same message asking for card insertion
I tried to replace PRO, etc. what you described above and it is so
Now is the new entry:
an error occurred and the update failed
i installer files not found. Is SD/USB still in device..
someone something HEEELPPPPP !!!!
Read post #166. QRASKA2006 where did you see to use PIONEERAVIC to install on the unit?
Hello
in the instructions nowhere was the idea was my password hanging ... but it was successful
... where I find those peaks with these maps and soft
I have no idea what you are asking. So obviously we can not communicate. Maybe you can find someone here who speaks Polish.
However, the point I was making on post #166 was:
"I recommend unzipping the map update from godzillz again. Be sure to enter the zip password 'Dracarys' including the single quote characters. If you do not enter the password correctly, some of the files will not unzip and the installation will fail."
I ask where I find these files with maps and soft
AS I said - we are not communicating. I'm talking about the files you said stopped installing at 94%. That is what I translated your statement to mean. Are they files extracted from godzilla's zip? If not, why are you posting in this thread?
Ron I did everything as described by ayan at http://avic411.com/index.php?/topic/82391-avic-f10f20f920f9210f9220bt-evrope-maps-update/page-3.
However, after the whole operation to point. 5 I did not turn off the radio as I wrote from point. 6 and there is a message installer files not found. Is SD/USB still in device
You are doing something wrong. I can't tell what from your message. Find a friend who is good with English and have him help you. The instructions are very simple but you must understand English.
You only need to install the Shortfuse hack one time. Follow the instructions from step 5. Make sure you use the correct password to unzip the map files or files will be missing. After step 8 you SD should only have Cardinfo.cif and two directories: FIRMWARE and UPDATE
If your radio has errors with updating it might be stuck in update mode. There are simple instructions on how to fix it in the Shortfuse Hack post #1 http://avic411.com/index.php?/topic/83535-map-update-hack-using-shortfuse-method-z110-z140x920-x940/
Ron if I copied the files according to the ayan instructions - and the files should I remove RenewalIFLib.dll from PGR0 and PRG1 ??
And if uploading radio maps do not want to enter a password it is ok or at this stage there is something wrong?
sorry for my english ... but i use google translator ![]()
and you are the only person who has taken the topic to help
in Poland no one since 26.10.2017 can not help me.
Do not remove any files. It does not say to remove any files in the instructions. But you must replace CardInfo.CIF because you have an F920BT. If you removed the RenewalIFLib.dll files, the update will fail. If you did, then you must go back and run the Shortfuse script.
in the file 2017 update after unpacking the zip and entering the password 'Dracarys' I have only 3 files:
FIRMWARE
UPDATE
CARDINFO which turns CARDINFO.cif file from ayan
I do not know if I should remove USER \ SYSTEM \ Download \ StartKnd.log ???
thank you for doing so much for me
FIRMWARE
UPDATE
Only delete USER \ SYSTEM \ Download \ StartKnd.log if you give-up trying to install the update. Then your old firmware/maps will be used and the update will be aborted. At least you will be able to use the radio.
So, you should be able to copy the two directories and Cardinfo.cif to the fresh FAT32 SD. Do not change any other files.
After applying the previous recommendations ... I wanted to upload maps but after inserting the SD card I got a message
ScriptFile execute error!! please check your storage contants
on a red background
If you can advice what in this case I do not know what I do I think I will give up and go to PIONEER.
on a red background
Are you talking about the ShortFuse script? If so, make sure the SD is not Write Locked.
If you are talking about the maps, did you format the SD before copying the 3 files? There is should not be any scrip file or testmode.key on the SD - only the 2 folders and CardInfo
If you can't get it to work, get http://mybyteideas.com/x9310bt/supertestmode.zip, unzip and put TestMode.key on a SD. This should boot into TestMode. Go to file maintenance and delete USER\SYSTEM\Download\StartKnd.log
it have i many time try no succes on my F930BT
i have one request from where will get CARDINFO.cfg ?? i have download the map 2017 sould i use this CARDINFO??
second:
on my 3. point wiche hexeditor:
- Offset 000019F0: 0350A0E3 replace with 0050A0E3
- Offset 00001A10: 0350A0E3 replace with 0050A0E3
- Offset 00001A3C: 0350A0E3 replace with 0050A0E3
- Offset 00001AD8: 0350A0E3 replace with 0050A0E3
- Offset 00001C1C: 0250A0E3 replace with 0050A0E3
- Offset 00001C24: 0150A0E3 replace with 0050A0E3
i have only found on my Pioneer Offset 000019F0: and Offset 00001A10: and nothing other their and both PRG0 and PRG1
what my problem is only this messeg come carte sd incorrecte, inserer la carte SD correcte
what is the reason how will fix it
second:
Just download and run the script. No need to patch your files for the Shortfuse hack. For F930BT you don't need to replace the Cardinfo.cif. Just use the one from godzilla. I don't know how it could be easier. Doesn't anyone read instructions? DO NOT CHANGE ANY FILES FROM GODZILLA's ZIP.
Folks, I'm done here. Everything works if you can read and follow instructions. I will not be responding to any more questions in the F Series forum.
So I made sure and the SD card is not locked ...
So SD card will upload 3 files ie 2 files and CardInfo
so i did all the time and the message after removing the sd card and resetting the radio. When you try to reboot the radio is the same message
i did some what u said
first ShortFuseScript press any button it was done, then i put sd card out and put the other sd card with 4GB, reboot
now it show incorrect SD message
Does it works with Bluetooth 5.0?
Hello there!
I have the Pioneer F10BT and done the following steps:
I downloaded the shortfuse script, put the 3 files on a SD memory card, ran the script which saved the two renewall files on the memory card. I pulled the SD memory card out of the unit, put the SD memory card with the update (from Godzilla) where it had 2 folders and the Cardinfo file which I changed the OE9R75LQ2MJ2X72EUR with the X07EURX27EURX30EUR and saved it on the SD memory card. It started after the update asked me for the password, put the PASSWORDPASSWORD and afterwards the update went where 93% and see the message that the card is wrong and I have to put it right. What I am doing wrong and you are not completing the upgrade?. Inside the unit I have the 2015 maps with Version 6.0000
I tried upgrading and without changing the cardinfo file, but the upgrade did not progress and I did not get the message to put some password
Please help!
Hello there!
Please help!
Hi Guys
some help from someone??
At my first attempt the unit stalled during installation. The fault was caused by a cheap sd card. Removed file in user directory. New sd card. And after 20 min. happy camper!! Thanks super update!
Wow,
update went marvellous with the shortfuse script. It took me some time to find the source for the update (the one with the ' ' as a part of the password
but then it was a picknick on my F930BT
Thank you, Godzilla and RonS !!
