Avic F920bt succesfully updated
Many thanks to Godzilla and RonS!!
New Release F20BT F30BT F40Bt F920BT F930BT F840BT Etc 2017 Releastechnologye
please help me. dont start update maps...what i make dont right:
- make sd with shortefuse - insert, it work OK
- make sd with folders FIRMWARE and UPDATE and file CARDINFO.cif in root.
and..... Nothing happens...
HU - f930t
What size SD? Best to use a 4GB or 8GB. Which Cardinfo.cif did you use?
I do remember someone with an F930 saying they had to use the other CardInfo, but it shouldn't be necessary. Worth a try if nothing else works.
Sorry, other that the above, I have no idea.
16GB sd... cardinfo try replace... fw - 3.001, 3.002, 5, 7 ![]()
find 8gb...try it now...
My system keeps asking me to repeat the password... F920BT
Anyone?
Anyone?
And you entered ......???
PASSWORDPASSWORD
PASSWORDPASSWORD
Did yo install the Shortfuse hack? If so, did you do it by patching it and installing it yourself, or by running the script?
No, i just unpacked the files on a sd card and changed the cardinfo with mine from 2015... Like i read in an earlier post.
But i still have to do the hack then... Ok, hope it will work out.
anyone can upload files from the folder with nav.program to torrent? (after 2017s map updates)
Worked like a charm!! Thank you sooo much!!
this update without Russian... f**k
Updated my old F930BT... everything went flawlessly (hack, update & nonag).
Thanks a lot!
EDIT : is there something new with this update ?
Hi Leute,
also so kompliziert war das Update bis jetzt noch nie.Hab das Map Update von GODZILLA von Seite 1 runtergeladen aber weder das Passowrt: Dracarys noch PASSWORDPASSWORD funktionieren.Jemand ne Idee?
@mani1980
Use this pw : 'Dracarys'
Dracarys and PASSWORDPASSWORD is false
It is not Dracarys, it is 'Dracarys' That has been expressed at least a dozen times in this thread. You don't seem to be capable of following detailed instructions. And your attitude seems to imply your incompetence is our fault. You even reported those posts to the moderators as "fake". I find that offensive.
Ahhh.Ok.Now it goes.Sorry,I am an idiot ![]()
Good news that you got it to work. I'm sorry that I got so heated in my response. It wa because I was irritated that this issue has happened so often. That and a few glasses of wine ![]()
It was a very bad idea to use apostrophes in the password. It is just asking for confusion. But since godzilla paid for and provided the files, I have no basis to object. And it was his right to do it. But the worst part is that, when the incorrect password is entered, the archive still partially unzips. So many people aren't even aware of the problem until the update fails with xx% completed. Of course then they post about the problem and someone needs to diagnose and help fix it. Guess who usually does that?
In my opnion it makes no sense to lock the zip file, then provide the password publicly. Once he made the decision to publish the password, I wish he would of replaced the zip file with an unlocked one. The US maps have no zip password and we have very few problems.
No Problem.I think so too.Good work.Thanks
Hi Leute habe versuch auch von mir AVIC F30 updaten ,aber bei 99% kommt Fehlermeldung :Ein Fehler ist aufgetreten und die Aktualisierung ist fehlgeschlagen! Neu versuch hat nichts gebracht bricht immer bei 99%.Alte version kann ich auch nicht mehr installieren -gleiche Fehler!
Gemach alles nach Anleitung :
step 1: download download shortfusescript.zip and 2017 update file
Kann mir jemand behilflich sein? MfG
You left off the most important info. What exactly did you enter for the map unzip password? How many characters were there?
Map from godzilla whit Password : 'Dracarys' !
Muss ich auch CARDINFO.CIF. ändern ?
Map from godzilla whit Password: 'Dracarys'!
I also need CARDINFO.CIF. to change ?
OE9R75LQ2MJ2X72EUR
and replace it with
X07EURX27EURX30EUR
Was the password you used 8 characters or 10? No, your problem is not with CardInfo.CIF If it was wrong, the update would not even start running. You would not be asked for a password. CardInfo only controls whether the update is for your model number.
The fact that you got to 99% means that there is something wrong with your update SD. The most common problem is not using 'Dracarys' (all 10 characters) to unzip. Another common error is that you modified any file from what was in the zip. With the exception of CardInfo (if needed). The last problem is an I/O error reading the SD. Use a 4GB or 8GB FAT32 SD. The installer program has trouble with larger SDs.
