cable guy Posted July 26, 2006 Report Share Posted July 26, 2006 Does the Pioneer CDRB-20 Aux input Adapter require power or is it simple an IP pass-through unit ? I've seen two differebt pictures online and some show a power cable while some don't. If it is powered, is this something that is easily installed or, being car radio installation retarded, should I get a "pro" to do it ? Quote Link to post Share on other sites
whtcrxghst Posted July 27, 2006 Report Share Posted July 27, 2006 Simple pass through. Easy install [quote name="cable guy"]Does the Pioneer CDRB-20 Aux input Adapter require power or is it simple an IP pass-through unit ? I've seen two differebt pictures online and some show a power cable while some don't. If it is powered, is this something that is easily installed or, being car radio installation retarded, should I get a "pro" to do it ?[/quote] Quote Link to post Share on other sites
cable guy Posted July 27, 2006 Author Report Share Posted July 27, 2006 Great. One more question. I have an XM tuner (GEX-P10XMT) currently installed. I've read that if you use the CDRB-20 along with the GEX unit that you will hear the audio from both the XM and the AUX input at the same time. Is this true ? Quote Link to post Share on other sites
jimmy303 Posted August 5, 2006 Report Share Posted August 5, 2006 The CD-RB20 does require power and ground connections to work properly. It has a pass-through P-Bus connection and 1 set of RCA connectors. Quote Link to post Share on other sites
JasonH Posted August 5, 2006 Report Share Posted August 5, 2006 [quote name="jimmy303"]The CD-RB20 does require power and ground connections to work properly. It has a pass-through P-Bus connection and 1 set of RCA connectors.[/quote] No it dosn't. It's only connections are IP Bus and L&R Audio in. There are no power connections. Quote Link to post Share on other sites
cable guy Posted August 5, 2006 Author Report Share Posted August 5, 2006 I picked one up at my local Best Buy and it does have power and ground connectors. Quote Link to post Share on other sites
JasonH Posted August 6, 2006 Report Share Posted August 6, 2006 Really? I installed one in a RV not too long ago and it did not have any power connections. Maybe they changed the design recently? EDIT: oh... my bad, I was thinking of the CDRB10. [img]http://akamaipix.crutchfield.com/products/2001/130/l130cdrb10_DG.jpeg[/img] Quote Link to post Share on other sites
