RidinaZ Posted February 14, 2008 Report Share Posted February 14, 2008 My gps antenna broke off(the plastic connecter to the console) and there is a scrawny wire exposed. is it even worth it to try to solder this back together or would it be a waste of time? Quote Link to post Share on other sites
HiFiSi Posted February 14, 2008 Report Share Posted February 14, 2008 The plastic connector on the end of the antenna cable or the plasic connector on the unit itself? Pics? Quote Link to post Share on other sites
RidinaZ Posted February 14, 2008 Author Report Share Posted February 14, 2008 at the unit end where connects to avic d3. Sorry no pics. The plastic lock in connecter is seperated from the wire wire looks sorta like the mute wire when you change it for the bypass. Quote Link to post Share on other sites
deepissues Posted February 15, 2008 Report Share Posted February 15, 2008 Mine did the same thing, but its easy to fix. I unlocked the clip in the plastic connector, than take a pair of pliers and open the clamped metal end opposite the end that goes to the radio, slide the wire in till it stops and recrimp the metal around the wire. Slide the wire into the plastic housing again (noticing that the metal insert has a metal nub on one side to orient it. Than reattach it to the radio. Deep Quote Link to post Share on other sites
RidinaZ Posted February 15, 2008 Author Report Share Posted February 15, 2008 thanks ill try that when i open it again Quote Link to post Share on other sites
