taichi2134 Posted March 1, 2008 Report Share Posted March 1, 2008 I bought a ND-BT1 for my avic-z1 -> z2 on ebay, but after installation it will not pair with my phone. I have a Samsung SGH-T809, is there a known problem with pairing with this phone. Should I get a new phone?? Quote Link to post Share on other sites
dominick367 Posted March 5, 2008 Report Share Posted March 5, 2008 I just got my Z2 installed today also. I usually dont read instructions but I did on this one. You need to make sure voice privacy is off on your phone. You then need to make sure you"register" you phone with the Z2 under info>phone settings. See if that helps BUT- Help me on this- Its paired. voice privacy is off.. I can hear them, they cant hear me. Help? Quote Link to post Share on other sites
whtcrxghst Posted March 5, 2008 Report Share Posted March 5, 2008 Is your mic plugged in securely? Quote Link to post Share on other sites
taichi2134 Posted March 5, 2008 Author Report Share Posted March 5, 2008 Hey, thanks for all the help. I got it to work, it looks like it was having problem detecting the bluetooth ND-BT1. I reseated the connector and it works like a champ. It is pairing the phone with all the functions working. Quote Link to post Share on other sites
dominick367 Posted March 6, 2008 Report Share Posted March 6, 2008 Is your mic plugged in securely? It is externally from what I can see. Should I take it back to the shop and have Tech fix or look at it from under dash? Quote Link to post Share on other sites
whtcrxghst Posted March 6, 2008 Report Share Posted March 6, 2008 Does your voice recognition work to do other functions? Can you press the little blue circular icon at the bottom left hand corner of the screen to activate it? Quote Link to post Share on other sites
dominick367 Posted March 6, 2008 Report Share Posted March 6, 2008 Does your voice recognition work to do other functions? Can you press the little blue circular icon at the bottom left hand corner of the screen to activate it? No blue icon Quote Link to post Share on other sites
whtcrxghst Posted March 6, 2008 Report Share Posted March 6, 2008 Then your mic isn't plugged in Quote Link to post Share on other sites
dominick367 Posted March 9, 2008 Report Share Posted March 9, 2008 Thanks--- took it to tech and he fixed the connection. Mic is now hooked up. But now I got a freakin echo for the person on the other end. Any suggestions there? Quote Link to post Share on other sites
whtcrxghst Posted March 9, 2008 Report Share Posted March 9, 2008 Try different mic placements and/or making the voice come out of one side or the other Thanks--- took it to tech and he fixed the connection. Mic is now hooked up. But now I got a freakin echo for the person on the other end. Any suggestions there? Quote Link to post Share on other sites
dominick367 Posted March 9, 2008 Report Share Posted March 9, 2008 Thank You Thank you. Moved it and changed speaker output. Tested once and other party said it was ok. Quote Link to post Share on other sites
