dantheman6985 Posted March 4, 2008 Report Share Posted March 4, 2008 i got a the D3 yesterday, and i searched this forum, but didnt find the exact answer i was lookin for, i want to be able to have the dvd player workin while i drive, is there anyway to undo the parking break wire so i can, without removing the headunitl, thanks a lot for the help Quote Link to post Share on other sites
whtcrxghst Posted March 4, 2008 Report Share Posted March 4, 2008 You need to pull the deck out to move the pin so you're going to have to take it out anyway http://www.avic411.com/forum/viewtopic.php?t=4670 Quote Link to post Share on other sites
dantheman6985 Posted March 5, 2008 Author Report Share Posted March 5, 2008 well i heard all u have to do is ground out the emergency brake wire, and if that doesnt work just run it to a constant power, i never heard of anything like haveing to move the wire Quote Link to post Share on other sites
HiFiSi Posted March 5, 2008 Report Share Posted March 5, 2008 Well what you heard is wrong. To do the bypass, look at 1 of the 4 sticky topics here: http://www.avic411.com/forum/viewforum.php?f=11 You have to ground the parking brake wire to the body of the car. But you WILL have to remove the unit because to do the bypass, you also have to move the mute wire to a different pin position on the D3' harness and ground that as well. That is the ONLY way to bypass the lockout. Also, DO NOT hook up the parking brake wire to a constant power source. That would be very bad. Quote Link to post Share on other sites
dantheman6985 Posted March 5, 2008 Author Report Share Posted March 5, 2008 ok thanks, im just to scared to do it casue i spent so much money on it and i dont want to mess it up Quote Link to post Share on other sites
dantheman6985 Posted March 6, 2008 Author Report Share Posted March 6, 2008 how u ground the mute wire after u move it Quote Link to post Share on other sites
HiFiSi Posted March 6, 2008 Report Share Posted March 6, 2008 Attach it to a bolt or screw on body of the car or to the radio's ground wire. Quote Link to post Share on other sites
