ugadawgs311 Posted March 7, 2008 Report Share Posted March 7, 2008 How exactly do you hook up the power wire? Can I clip it to the same power wire I'm using for the radio itself? Quote Link to post Share on other sites
HiFiSi Posted March 7, 2008 Report Share Posted March 7, 2008 Yes, the ground as well. Just make sure to use the constant power wire going to the D3 and not the switched power wire or the BT unit will lose memory every time you turn the car off. Quote Link to post Share on other sites
ugadawgs311 Posted March 7, 2008 Author Report Share Posted March 7, 2008 So clip the yellow and black wire from the Bluetooth to the yellow wire on the radio? Quote Link to post Share on other sites
asianman35 Posted March 7, 2008 Report Share Posted March 7, 2008 no the yellow goes with yellow and black with black, your radio harness should have a black wire that is the ground. Quote Link to post Share on other sites
