wgm5286 Posted March 28, 2008 Report Share Posted March 28, 2008 I dont know if this is an antenna problem or system problem. I took a 1200 mi trip twice in the last 4 weeks. About 600 mi in, the system stopped tracking and all satellite icons went to gray. The antenna is outside on roof. I reset the system nothing changed. Then i cleared the hybrid status, did a reset, turned off the vehicle. Then when it was restarted everything came up after the hybrid 3d initalized. I took a look at the antenna and noticed it was beginning to leave a small rust stain on the magnet and the roof of the car. I then cleaned the stain and moved it down a few inches away form the spot. everything worked ok. Then on my second trip after about 600 mi of traveling it did it again. I went thru the whole procedure again and everything is fine for now. To be safe, I ordered a new antenna just in case. The unit has been in service since September. and is bypassed 2006 mercury mountaineer. Any ideas????????????????????????????? Also took out the backup disks and put the origional one back in. STUMPED Quote Link to post Share on other sites
HiFiSi Posted March 28, 2008 Report Share Posted March 28, 2008 You could always mount the antenna inside the car on the dash board. Mine's on there and I've always had full satellite signal. Then you don't have to worry about your nav antenna rusting up, or about ruining your paint job. Quote Link to post Share on other sites
lightsout Posted March 29, 2008 Report Share Posted March 29, 2008 my antenna is also inside the car on the dashboard close to the windshield. You hardly even notice it. Never had any problems with it. Quote Link to post Share on other sites
wgm5286 Posted March 29, 2008 Author Report Share Posted March 29, 2008 i think that is what im going to do when the new one gets here. I have mine under the dash in my expedition and it works fine, dont know why i didnt do it in the mountaineer. Could the rust be causing my problems? Quote Link to post Share on other sites
kruff10 Posted March 29, 2008 Report Share Posted March 29, 2008 Yea i have mines under my dash , SAFE AND SOUND, the elements are rough. Quote Link to post Share on other sites
HiFiSi Posted March 29, 2008 Report Share Posted March 29, 2008 Could the rust be causing my problems? Don't know, but it's a good place to start. Quote Link to post Share on other sites
wgm5286 Posted March 29, 2008 Author Report Share Posted March 29, 2008 ill let you know how it plays out after i get the new antenna installed. Thanks for the posts. Quote Link to post Share on other sites
