typhoon43 Posted April 28, 2008 Report Share Posted April 28, 2008 I just finished yanking my Z2 to ground the RCA's, and then thought about doing the bypass. Well I didn't get the "Audio 2" molex plug when I bought it, and I couldn't find a way to ground that one pin, so I jsut went ahead with the install. I gounded the Green EBrake wire because I hadn't done it and my DVD's would just give me audio and the infamous warning message about not viewing when driving. Well all I did was ground the Ebrake wire, and my DVD started playing. I then backed out of the garage, and the video kept going! I was under the impression this wouldn;t work until you did the 2 wire mod and the firmware disc. I'm not complaining at all, but I'm slightly confused. Anyone had this happen to them? Quote Link to post Share on other sites
whtcrxghst Posted April 28, 2008 Report Share Posted April 28, 2008 It will work for a while until it calibrates...then you are out of luck Quote Link to post Share on other sites
big-fokker Posted April 28, 2008 Report Share Posted April 28, 2008 Pre bypass, mine worked in reverse, but as soon as I hit drive it would blank out. Quote Link to post Share on other sites
typhoon43 Posted April 28, 2008 Author Report Share Posted April 28, 2008 It will work for a while until it calibrates...then you are out of luck Is this a fairly long process? I drove 30 minutes to work today with a DVD going and I'm still good. I'll check back at lunch. Quote Link to post Share on other sites
ducatiboy Posted April 28, 2008 Report Share Posted April 28, 2008 Is this a fairly long process? I drove 30 minutes to work today with a DVD going and I'm still good. I'll check back at lunch. Could be as much as 100 miles or so. Quote Link to post Share on other sites
typhoon43 Posted April 28, 2008 Author Report Share Posted April 28, 2008 Yup, did it to me at lunch. Oh well, going to yank the deck one more time and do the 2 wire for real. Quote Link to post Share on other sites
