josh99ta Posted May 28, 2008 Author Report Share Posted May 28, 2008 I'll have to look into resetting the D3. Changing the way the cables are hooked up definitely effects whether the D3 picks up on the modules being connected, and I've had the BT hooked up first and now the XM hooked up first, and neither way worked. Quote Link to post Share on other sites
josh99ta Posted May 29, 2008 Author Report Share Posted May 29, 2008 OK, called Pioneer and it took 2 seconds to fix the problem. I had the order wrong. I was going D3 to XM in, XM out to BT in. Should have been BT out to XM in, XM out to D3. Swapped those cables (even though the directionality, if thats even a word, of the cables is not blue-to-blue and black-to-black) and everything works flawlessly now. I'm pumped. Thanks for all the help guys. Quote Link to post Share on other sites
stankinls Posted June 5, 2008 Report Share Posted June 5, 2008 i have the same problem, i dont have xm just the bluetooth on the ip any other solutions??? Quote Link to post Share on other sites
Join the conversation
