dubs_17 Posted June 28, 2008 Report Share Posted June 28, 2008 So...Avic works well and everything is doing what it should; however, when I turn the car off for more than 30-45 seconds, everything resets. I mean, the illumination is cycling, the radio presets are gone, the navi is all reset, everything is back to initial startup! Any ideas what is going on? The funny thing is, it remembered my 'home' setting, but nothing else! Shouldn't it retain everything via the constant +12V supply??? All my wiring is soldered, and trust me, I've been soldering for years...there's no way anything came undone. Quote Link to post Share on other sites
smithegl Posted June 29, 2008 Report Share Posted June 29, 2008 Some new cars Power down after a short time when you turn off the ignition try a new constent source or go to the battery Quote Link to post Share on other sites
RICExIZxGOOD Posted June 29, 2008 Report Share Posted June 29, 2008 What's the make and model of your car? Quote Link to post Share on other sites
HiFiSi Posted June 29, 2008 Report Share Posted June 29, 2008 Simple. It is not getting a constant source of power to the yellow power wire. Either find out why that wire cuts off the power, or run a new one from the fuse panel. Quote Link to post Share on other sites
dubs_17 Posted June 30, 2008 Author Report Share Posted June 30, 2008 Figured it out. Must have been some drunk dillweed at the Metra factory one day. The yellow wire coming from the Metra adapter ('Constant +12V') was actually matching with the ignition source on the VW harness, and the red wire on the Metra adapter ('Ignition') was matching up wit the constant 12V on the VW factory harness. A quick snip of the wires and some new solder, and I'm in business. Now, if I could only get that pesky video bypass to work...arghhhh.... Quote Link to post Share on other sites
