Hyrul Posted August 1, 2008 Report Share Posted August 1, 2008 Hey all, quick question. I had to uninstall my N1 unit and send it in for the flex cable repair. I asked Pioneer how long it would take and they mentioned 2 weeks. So now my car has no audio for the next 2 weeks so i figured Id try and put the stock unit back in. Problem is, when I bought the car, it came with the N1 unit... I never saw the installation and never played with the wiring or anything at all. When trying to reinstall my stock deck, the proper cable connectors are obviously not there... My question is for those who have installed these units... does it require you to modify the stock connectors to fit the N1 connectors? Or are my stock connectors and cables somewhere in the dashboard and have nothing to do with the installation of the N1 unit? Thanks! Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted August 1, 2008 Report Share Posted August 1, 2008 Hey all, quick question. I had to uninstall my N1 unit and send it in for the flex cable repair. I asked Pioneer how long it would take and they mentioned 2 weeks. So now my car has no audio for the next 2 weeks so i figured Id try and put the stock unit back in. Problem is, when I bought the car, it came with the N1 unit... I never saw the installation and never played with the wiring or anything at all. When trying to reinstall my stock deck, the proper cable connectors are obviously not there... My question is for those who have installed these units... does it require you to modify the stock connectors to fit the N1 connectors? Or are my stock connectors and cables somewhere in the dashboard and have nothing to do with the installation of the N1 unit? Thanks! it depends on if they hardwired it or used wiring harnesses. if they used a harness your stock plugs should be right there....if theyre not, chances are they hardwired it and you would need at least basic knowledge and alot of patience to get the OEM connectors and install them Quote Link to post Share on other sites
Hyrul Posted August 1, 2008 Author Report Share Posted August 1, 2008 CatchMe, youre right, they were there... well, at least the power one was. I connected it and the stereo got power, but there was nothing coming from the speakers... do you happen to know if the Avic unit requires any work with the speaker cables? When i try connecting my stock unit, the only cable I could find was the "power" cable... do stock decks typically have a "speaker" cable or is that usually in the same head as the power? Quote Link to post Share on other sites
Hyrul Posted August 1, 2008 Author Report Share Posted August 1, 2008 by the way, the car has aftermarket speakers, subwoofer and amp. Not sure if that makes a difference Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted August 1, 2008 Report Share Posted August 1, 2008 CatchMe, youre right, they were there... well, at least the power one was. I connected it and the stereo got power, but there was nothing coming from the speakers... do you happen to know if the Avic unit requires any work with the speaker cables? When i try connecting my stock unit, the only cable I could find was the "power" cable... do stock decks typically have a "speaker" cable or is that usually in the same head as the power? the speakers wires consist of 8 wires, 2 per quadrant. front left is white front right is gray rear left is green rear right is purple look for those 8 wires and let me know and you wont be able to get sound to your amp for the sub with the stock radio. stock radios dont have RCA outputs. youd have to buy and install a special piece to enable them Quote Link to post Share on other sites
Hyrul Posted August 1, 2008 Author Report Share Posted August 1, 2008 Thats fine if the amp and stuff doesnt work... I just want music for these 10 days while the unit is getting repaired This is what I have in front of me... #1 is what gives power to my stock cd player #2, 3 and 4 connect only to the Avic unit, and I have no clue what they do But the stock deck is only powering up, no music sound coming from speakers Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted August 1, 2008 Report Share Posted August 1, 2008 take off the electrical tape, i can see the green speaker wires. Quote Link to post Share on other sites
Hyrul Posted August 2, 2008 Author Report Share Posted August 2, 2008 CatchMe, what exactly am I looking to do with the green wires? Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted August 2, 2008 Report Share Posted August 2, 2008 its more than green wires. its the 4 colors i mentioned and i was looking to see if those are in fact the wires that you said werent there. Quote Link to post Share on other sites
offroaderf150 Posted August 2, 2008 Report Share Posted August 2, 2008 looks like there is a 4 channel amp in the car? if so, it all depends on how that was installed. if they ran the wires from the amp to the back of the radio and tagged the speaker wires there, then you should be able to get sound if you unplug the harness that plugged into the stock one. but if the wires are going from the amp to the speakers directly, then youll have to rewire the system before you will get sound. Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted August 2, 2008 Report Share Posted August 2, 2008 looks like there is a 4 channel amp in the car? if so, it all depends on how that was installed. if they ran the wires from the amp to the back of the radio and tagged the speaker wires there, then you should be able to get sound if you unplug the harness that plugged into the stock one. but if the wires are going from the amp to the speakers directly, then youll have to rewire the system before you will get sound. good call i didnt even notice that all i saw was that green speaker wire. so assuming it is a 4 channel and those and the front and rear rcas hows he gonna get any sound if his stock deck has no rca output? Quote Link to post Share on other sites
offroaderf150 Posted August 2, 2008 Report Share Posted August 2, 2008 well, he can add line out converters to the factory plug in order to retain the amp. also, move the amp turn on lead to the accessory circuit in the factory harness as well. its a lot of work for a 2 week wait. if it was me in that situation, i would just bust out the ipod lol Quote Link to post Share on other sites
mazda_3 Posted August 17, 2008 Report Share Posted August 17, 2008 your best bet is to go without music for 2 weeks. i know it will drive you crazy but from the looks of it it will be harder to rewire everything then just to leave it Quote Link to post Share on other sites
michael pyrlik Posted May 16, 2012 Report Share Posted May 16, 2012 does anyone know what all the wires on the n1 are im trying to install n1 in my 85 s10 blazer but cant seem to get it to power up at all i need a wire diagram and cant find one i was told the best place to look and ask is on here Quote Link to post Share on other sites
VBLUE42 Posted May 16, 2012 Report Share Posted May 16, 2012 Search "AVIC N1" at the Pioneer site and download the install manual. Quote Link to post Share on other sites
